jaytcsd
router hacked?
Sat Nov 28, 2009 11:16 pm
I just noticed that my VRRP backup RB133 would not respond to winbox. I tried using the serial port and found my password is void. Using mac telnet from the IP neighbors window I see that my local IP address is 0.0.0.0, instead of my 192.168.x.x scheme, and the static public IP has been changed to a 192.168.x.x address.
I unplugged the public NIC and want to see if I can get into the router to check out the log file, but it looks like my only option is to use the router bios to reset the config. Does a soft config reset delete the log files, or is their a way to just to reset the password so I can get access again?
jwcn
Re: router hacked?
Sun Nov 29, 2009 7:07 am
Sounds like it reset to default. Have you tried using Admin and no password?
Smith
Re: router hacked?
Sun Nov 29, 2009 7:24 pm
If you are using CF card or ordinary hard disk you can mount it to any other linux and check log files.
jwcn
Re: router hacked?
Mon Nov 30, 2009 12:51 am
The OP stated he is using an RB133 which does not have an external drive.
