MUM Europe 2020
fmekr2005
in local ACL,accept But not connected
Wed Dec 16, 2009 2:23 am
I have ROS 2.9.27,engenius3016s as AP and 50 clients. Maximum 24 clients are present in regestration table at the same time
I remove default authenticate and add mac addresses of clients in access list.
my problem when I reboot the server, no client can connect to AP
some clients can connect but others cannot connect
I change configurations of engenius card tell clients can connect But when reboot server the problem begin again and so on
this problem last for 1 month till yet and I cannot understand why clients cannot connect.
the signal of clients between -83,-65
/int wireless
R name="lan" mtu=1500 mac-address=00:02:6F:4D:39:1B arp=reply-only
disable-running-check=no interface-type=Atheros AR5213 radio-name="00026F4D391B"
mode=ap-bridge ssid="Badr" area="" frequency-mode=superchannel
country=no_country_set antenna-gain=0 frequency=2412 band=2.4ghz-b
scan-list=default rate-set=default supported-rates-b=11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=11Mbps
basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
max-station-count=2007 ack-timeout=60 tx-power=15 tx-power-mode=all-rates-fixed
noise-floor-threshold=default periodic-calibration=default
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100
wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=no default-forwarding=no default-ap-tx-limit=0
these are logs indicate acceptance of clients by access list But not connected.It must tell <mac>@lan connected so clients can be shown in regestration table, but this is not occur
fmekr2005
Re: in local ACL,accept But not connected
Wed Dec 16, 2009 2:28 am
also in this picture show four clients want to connect
but there is delay for connection. They connected together in 4:52
fmekr2005
Wed Dec 16, 2009 2:40 am
this picture show no delay for connection
fmekr2005
Sat Dec 19, 2009 2:13 pm
please, Normis
Can you tell me what happens?
npero
Sat Dec 19, 2009 4:32 pm
Update to 2.9.51 it is free of charge not cost anything but resolve many bugs and add new feature or if your license allowed update to 3.30.
3 version have many many improvements in the wireless, wireless perform much better :) . You are using very old version.
balimore
Forum Veteran
Forum Veteran
Sat Dec 19, 2009 7:07 pm
I have ROS 2.9.27,........
ok fren,..
i thing,. it's better when you will stop working with those version..., try to make update to newest version... :wink:
here, all our unwire and centralized aaa is stable and enough with v2.9.49..since several years ago...nice!
thanks to mikrotik and team, you made us nice to sleep..
regards
Hasbullah.com
fmekr2005
Sat Dec 19, 2009 9:14 pm
thank you very much
I can upgrade
But I want to know why this happens?
we must know every thing about mikrotik system
thanks very much
balimore
Forum Veteran
Forum Veteran
Sun Dec 20, 2009 9:18 am
oh thanks,
as far as i remeber those version is crecked version[ilegal] and many bugs,...
ideal client signal between -45 til -76
don't worry many friends will help you about your problem... :wink:
regards
Hasbullah.com
fmekr2005
Sun Dec 20, 2009 4:54 pm
thanks very much, balimore
But Iwant to know what happens?
thanks
angboontiong
Sun Dec 20, 2009 5:36 pm
You should respect the Mikrotik copyright...
npero
Sun Dec 20, 2009 8:45 pm
Upgrade to 2.9.51 it is free. Resolve many bugs. If you license allowed go to 3.xx wireless work much better.
Users browsing this forum: networkfudge, yannick and 29 guests
