LinuxLoader
Performnce
Mon Jan 25, 2010 4:27 pm
What is the maximum traffic that someone puts true router with MT for PPPoE with rate-limit from radius
not RB , when using x86 based PC.
sergejs
Re: Performnce
Thu Jan 28, 2010 5:09 pm
RouterBOARD 1000 can provide you with extremely high traffic,
http://www.routerboard.com/pdf/routerbo ... _tests.pdf
Chupaka
Re: Performnce
Thu Jan 28, 2010 11:29 pm
it depends on active session count. if you have hundreds of dynamic simple queues, performance will degrade
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
LinuxLoader
Re: Performnce
Fri Jan 29, 2010 12:11 pm
Maximum count will be 1000+ current is about 400-500 active sessions traffic is ~500mb max with speed per PPPoE subscriber 12/36/48mb is the speed from the radius server that is set , i stopped the multi-cpu and got much more high cpu load 80-90% load but latency is fine , with multi cpu i got loss and high latency.
warach
Re: Performnce
Fri Jan 29, 2010 8:55 pm
Why multi CPU make problem? I think multi core should be better than single core.
What's wrong?
How can you stop multi core cpu and run only single core?
Please advise,
Chupaka
Re: Performnce
Mon Feb 01, 2010 1:39 pm
/system hardware set multi-cpu=no
LinuxLoader
Re: Performnce
Mon Feb 01, 2010 6:03 pm
I did some other tests , everything is fine , until pppoe session reaches ~500 active sessions with
xeon 1,6 ( 5030 think was the model ) and MB some Supermicro with 2G ram traffic is max 300mb , until session coun tis ~400 is fine but if it reaches more , all goes down , high latency and lot of loss.
Users browsing this forum: bahman, benc1337 and 120 guests
