InterMAN
Online speed (bandwidth usage) monitoring
Sun Jan 31, 2010 5:14 pm
I've created map of my network and I'd like to see usage of links online on the map. I can see it for specific routerboard's interfaces when I've got its settings window open. But when all settings windows are closed, the actual bandwidth usage is not updated at all. Is there some way to show the actual bandwitch usage on all links on the map?
Thanks for help and thanks to Dude Team for this outstanding product!!
sergejs
Re: Online speed (bandwidth usage) monitoring
Wed Feb 03, 2010 2:39 pm
I'm using Dude 3.5, information on the usage of the link are updated without any problems.
InterMAN
Wed Feb 03, 2010 5:45 pm
I upgraded to 3.5 now and it's not updating again. All links show 0bps until I open settings of its Mikrotik device. When I close it, the update stops again.
Isn't there some setting to let it update automaticaly all the time?
sergejs
Thu Feb 04, 2010 10:32 am
Which mastering type is used for monitoring on your Dude?
simple, SNMP, routeros?
InterMAN
Thu Feb 04, 2010 3:03 pm
I use RouterOS. I tried to switch to SNMP now and it works with it. So I can use SNMP. Is there any advantage of using RouterOS instead of SNMP or vice-versa?
conjurer
Wed Feb 10, 2010 4:30 pm
I think routerOs is faster.
This is old bug with routeros mastering. I think that mikrotik puts about 1% of time on developing dude. So stick with snmp, like we all did.
InterMAN
Wed Feb 10, 2010 7:04 pm
OK. Thank you both for help!
sergejs
Fri Feb 12, 2010 9:27 am
Yes, I can confirm that 3.5 Dude does not update too often the traffic, when mastering type is selected as RouterOS. We will see what we can do.
Users browsing this forum: No registered users and 31 guests
