Eising
RB1000, metarouter, crash with > 512MB ram
Mon Feb 01, 2010 12:56 pm
Hi there,
I have a consistent issue on RB1000 units, where the ram has been upgraded. When I add a metarouter, the router crashes. I get no messages in the console, or anything, it just freezes completely. It works fine with the bundled memory... I have checked several RAM circuits, and I get the issue consistently.
Any ideas?
The road to hell is paved with good intentions.
uldis
Re: RB1000, metarouter, crash with > 512MB ram
Mon Feb 01, 2010 1:43 pm
What RouterOS version you are using?
How big memory you specified for the metarouter and how much RAM you have in the RB1000 plugged in?
Eising
Mon Feb 01, 2010 1:55 pm
I've tried a lot of different versions. I've tried from 3.30 to 4.5.
The router has a 2GB kingston block in (giving it 1.5 GB effectively), and it doesn't matter how much memory I specify for the guest.
uldis
Mon Feb 01, 2010 2:30 pm
So to reproduce - reset the configuration on RB1000, go into the metarouter menu and click on the + for adding a new metarouter, and after pressing ok, the board freezes - no response, even not from the console?
Eising
Mon Feb 01, 2010 2:33 pm
Exactly. This is exactly what happens.
uldis
Wed Feb 03, 2010 5:13 pm
thank you for the report, we will check how to fix this problem.
Users browsing this forum: No registered users and 1 guest
