he1ium
route ospf error -> Discarding packet: locally originated
Sat Feb 06, 2010 6:23 am
Quick overview - wheel and spoke network with IPSec over IPIP tunnel and OSPF running on the IPIP interfaces (based on this article http://wiki.mikrotik.com/wiki/IPSec_VPN ... _and_Cisco but using OSPF instead of RIP and both routers are Mikrotiks). I am only getting these errors on the IPIP tunnel addresses on the central router that the rest dial in to. All routers recently upgraded to ROS_4.5 and that is when I started to notice the errors in my log files. example error below -
20:14:25 route,ospf,error Discarding packet: locally originated
20:14:25 route,ospf,error src address=10.0.1.117 <--- this is a /30 address where .116=network, .117=central router, .118=remote router, .119=broadcast
20:14:25 route,ospf,error src address=10.0.1.121
20:14:25 route,ospf,error src address=10.0.1.129
I attempted to discard any 10.0.0.0/16 packets through ospf-out to no avail. Any suggestions? Hopefully I am just missing something blindly obvious.
awsmith
Re: route ospf error -> Discarding packet: locally originated
Tue Mar 02, 2010 3:43 am
This sounds like you may have multiple IP networks on the same broadcast domain. For some reason, the router is seeing its own announcements on interfaces that it is not expecting. Check for multiple IP networks on the same broadcast domain, or possible loops in your tunnel infrastructure.
The ospf-out filter filters out prefix announcements from redistribution, not actual packets.
he1ium
Sat Mar 13, 2010 12:22 am
You may have just helped me FINALLY prove a point to my boss on why you don't run your WAN and LAN on the same dumb switch. There are many unintended consequences from doing so. I blocking 89(OSPF) on the WAN interface and the errors seem to have stopped. Thank you OSI model (even though there are disputes as to which layer OSPF operates on).
he1ium
Sat Mar 13, 2010 12:29 am
Scratch that, they are back. But my point remains. Layer 2 separation begins Monday.
he1ium
Wed Mar 17, 2010 8:35 am
Layer 2 separation = no good. Still getting errors. As always, Mikrotik support says it's fixed in the newest firmware... and it's not. Then they told me to set all my interfaces as passive... this = loosing OSPF routes all over the place. My frustrations continue.
theWISP
Wed Mar 17, 2010 6:55 pm
Hello - we have a thread started a few days before yours, and we are having the same problem. Dropping OSPF routes, usually the same couple, but it is very often. One of the routes it drops is even an ethernet link, Odd thing is which router drops the route:
Border Router -ethernet> RB433AH (4.6) -Bonded link to> RB600 (4.6) -ethernet> rb433ah(4.6)
This RB433AH (4.6) drops the route to the wireless interface of This rb433ah(4.6)
Very odd, and extreamly frustratin as this seems to happen more during peak times, and is on some of our core routers. Any help would be extreamly helpful, Mikrotik.
he1ium
Wed Mar 17, 2010 8:32 pm
This is what I got from Mikrotik and it didn't work (see below). By setting interfaces to passive (on one side, other side, both sides), the tunnel addresses appears to be up but the remote LAN networks were not distributed -
Yes it is possible.
Lets say we have setup 10.1.1.1/24 on ether1 and you want to run ospf on
10.1.1.0/24 network only.
Setup as follows
/routing ospf network add network=10.1.1.0/24
/routing ospf interface
add interface=ether1
add interface=all passive=yes
Nothing complicated. <- Smart Ass
Regards,
Maris
If OSPF is not seeing neighbors after setting interfaces to passive, it means
that you set passive interface which shouldn't be passive. Send us supout file
from the router.
Regards,
Maris
Chupaka
Thu Mar 18, 2010 12:29 am
this makes ether1 NOT passive. so, you should make all your ospf interfaces NOT passive, and the rest will be passive (by executing "add interface=all passive=yes")
he1ium
Thu Mar 18, 2010 7:18 am
I did not add interface ether1 as the reply states. Only "add interface=all passive=yes" and this still kills routes. These interfaces are IPIP tunnels and not wired directly to this router.
mrz
Thu Mar 18, 2010 9:45 am
Well then no wonder OSPF is not working if you add only "add interface=all passive=yes".
It makes all dynamic interfaces passive, passive interfaces do not send hello packets.
he1ium
Fri Mar 19, 2010 7:11 am
OK. Do you have any advice then? I tested Chupaka's method with the same result.
rumiclord
Fri Jan 27, 2012 12:42 am
I have ran into this problem myself twice. I don't remember how I corrected it the first time, but this time i turned on the debugging and it showed all my virtual interfaces sending hello packets down tunnels... long story short Chupaka was correct. Just added interface=all - passive. All ospf interfaces have there own settings. This did magically start happening after i upgraded from 4.17 to 5.11, not sure if the firmware just brought this out in the open, which is my thought about this.
bysard
Wed Apr 10, 2013 8:36 am
Maybe you have proxy-arp enabled on your interfaces. <-- not the case. I still get these errors.
I'm getting more and more of these errors every day now.
EDIT:
In my case the solution was, to reboot all routers and the ospf error went away. Seems to have something to do with negotiated state (backup/designated).
bysard
Sun Sep 01, 2013 10:26 am
Error is back. I really can't reboot all routers every couple of hours. No fix on the horizon. No good advice from support to eliminate this problem except..."It will be fixed in RoS6." It is now 6.2 and still no fix.
StubArea51
Trainer
Trainer
Sun Sep 01, 2013 6:07 pm
Have you attempted to change the ospf network type or set static ospf neighbors? Setting a static neighbor will remove multicast from the mix and changing from broadcast to ptp will remove DR/BDR elections.
I would be curious to see what RIP or BGP do over the same physical topology - might help you sort out whether you have an ospf specific issue or a physical and/or logical topology issue.
robertik
Mon Mar 31, 2014 5:25 pm
I'm struggling with that in our network for about a year.
We have changed most of devices to nmba mode - but route propagation was taking too long.
We can observe that issue on CCR's working versions 6.7,6.10, 1100AHx2 ver 6.7 and almost on all other devices with OSPF.
We where thinking the issue is with radio link, but it is happening with all radio links that we have (ubnt, MikroTik, Ceragon, SAF). We can find it also when two devices are connected on cable.
My current status - I put few firewall rules to block packets with source IP the same as device.
Error disappear.
> /ip address print where interface=ether1
# ADDRESS NETWORK INTERFACE
1 10.240.14.254/24 10.240.14.0 ether1
> /ip firewall filter print
0 chain=input action=drop protocol=ospf src-address=10.240.14.254
I was trying to track them on device that is connected to that one, but without luck - packets are not coming from outside.
When I enabled packets logging, my results:
15:00:48 firewall,info input: in:ether1 out:(none), proto 89, 10.240.14.254->224.0.0.5, len 1764
15:01:01 firewall,info input: in:ether1 out:(none), proto 89, 10.240.14.254->224.0.0.5, len 1752
15:02:31 firewall,info input: in:ether1 out:(none), proto 89, 10.240.14.254->224.0.0.5, len 1764
15:02:56 firewall,info input: in:ether1 out:(none), proto 89, 10.240.14.254->224.0.0.5, len 1752
Hope that will give some kind of directions.
RB1100AHx2 RoS v6.7
bakica
Tue Nov 03, 2015 4:41 pm
I'm still having the same issue. Router OS 6.12. Does anyone found a way to fix this?
klasaradnicka
Fri Oct 05, 2018 5:44 pm
I have the same problem,
I have two OSPF processes , one primary link with OSPF is working fine, but the problem is when I turn off my primary link, second link is not active.
One router has ID 1.1.1.1
Primary link has a cost 10 priorty 1
Secondary cost 20 with priority 1
Second has ID 1.1.1.2
and it says Status is ExStart , there is NO firewall between to block any traffic.
I have update both routers on 6.43.2 Router OS, but no luck router 2 ID 1.1.1.2 keeps saying discarding packet locally originated and no luck at all.
Please help ? this is an emergency
klasaradnicka
Wed Oct 17, 2018 1:18 pm
Update, I was able to resolve the issue by updating Router Boards on all routers in my network to 6.43.2 , OSPF is now working fine, still there is an error message but OSPF is working fine, it is just irritating and nothing else :)
Mybe we can close this topic.
kraljek
Tue Jun 04, 2019 9:21 pm
I have same issue. One year OSPF work great, and before few weaks I see lot of errors in log on cca 20 CCR routers (I have few Cisco routers in same backbone and I dont have any problems in log). Only MT router who have one OSPF connection on same broadcast domain dont have this errors. Every router who have backup route, have this errors.
I check full network, I dont have any duplicated networks, IPs, loopbacks and I dont know what more! Im using vlan-s, /30 networks for communications, I dont have more ideas.
Mikrotik says that no way that is problem in ROS. :-D
@klasaradnicka you can disable Track connections on IP firewall, and you will not have more logging, but some of features will not work in router (NAT, Mangle and etc.).
Whether someone has tried it with Point to Point links?
Has anyone found a decision?
mrz
Wed Jun 05, 2019 11:20 am
MT is saying it is not a problem of OSPF. Packet is sent back to the router by some device. Loop, switch is between is leaking vlan packets from other vlans, etc, etc... OSPF is just processing packets that it receives.
carlhjerpe
Tue Jun 25, 2019 6:47 pm
We get the same problem on our CHR's (I'm most certainly not excluding a loop though, but it doesn't seem like our switches are overloaded at all)
add area=backbone network=192.168.10.0/24
[diadmin@somegw] > /routing ospf interface print
Flags: X - disabled, I - inactive, D - dynamic, P - passive
 #    INTERFACE                                                              COST PRIORITY NETWORK-TYPE   AUTHENTICATION AUTHENTICATION-KEY
 0 D  ether2        10        1 broadcast      none
mangust479
Wed Aug 21, 2019 12:14 pm
I confirm existence of a problem on firmwares on 6.45.2, the configuration is checked - there are no loops. For bigger confidence, decided to collect traffic to look at what incoming packet which was allegedly generated by the router to it it is not pleasant, and so I did not see such packet in a sniffer. But saw defragmentation of incoming packets which coincide with error time in the log. How can fragmentation of a packet cause this error?Image Image
mrz
Thu Aug 22, 2019 9:53 am
Do you have connection tracking enabled?
jindranix
Thu Oct 17, 2019 2:50 pm
Hello, I discovered this issue on our routers and solution was really disable conntrack for ospf. No looped ospf packet found by sniffer. Very strange.
Code: Select all
add action=accept chain=input protocol=ospf
/ip firewall raw
add action=notrack chain=prerouting protocol=ospf
add action=notrack chain=output protocol=ospf
highonsnow
Wed Dec 11, 2019 7:00 pm
I'm experiencing the same error for no reason other than having upgraded from an earlier v6 version to 6.44.6.
Immediately after upgrading, on a PTP link, no switches involved, 'nothing complicated', just a mikrotik through a wireless PTP bridge (UBNT) to this other mikrotik. I have tried the below fix, but this does not remedy the issue and the error message persists. Also, it's only witnessed on one mikrotik, however both are on 6.44.6. One is an RB3011UiAS, the other is a Hex S. The Hex S is the one producing the errors
Code: Select all
/ip firewall raw
LouisVisagie
Thu Sep 23, 2021 3:48 pm
ospf,error Discarding packet: locally originated usually means that there is an IP conflict on your network. You could be trying to use the same IP address on more than one device and OSPF is picking up this conflict. I would try using another IP address on your router where you are trying to set up OSPF than the one being reported in your logs.
Users browsing this forum: No registered users and 29 guests
