eugenyfo
Lost all Dude data after reboot.
Wed Feb 10, 2010 7:00 am
Hello!
I have RouterOS V4.3 (License Level 1) as guest under Virtualbox 3.1.2 (host Ubuntu 9.10).
RouterOS have a Dude package. All working fine. I can create a map, scan devices etc.
But after reboot my VM with RouterOS, all data in Dude is dissapear.
But if I changing something in RouterOS settings - all keeping fine, even after reboot.
Is it because I use License Level 1, or something wrong in my VM or what?
sergejs
Re: Lost all Dude data after reboot.
Fri Feb 12, 2010 4:46 pm
Probably Virtualbox does not make correct reboot of the router.
Do you run reboot Virtualbox immediately after applying Dude configuration?
Try the following,
/system reboot on MikroTik RouterOS
Reboot the Virtualbox.
Let us know, how it works.
eugenyfo
Fri Feb 12, 2010 4:57 pm
Yes,
I rebooted router via winbox (system/reboot).
Results the same :(
sergejs
Mon Feb 15, 2010 3:20 pm
Setup The Dude server on stand-alone router.
Muhammad
Wed Mar 24, 2010 9:03 am
i also lost data some time in Dude after reboot on RB800 and RB433AH
Ibersystems
Fri Aug 20, 2010 11:00 am
I have the same problem with this.
After a disconnection of my Dude client, all the changes I made and I were looking for 5 days, are not there now. All is like I installed months ago, not like I configured this week. WTF?!
My Dude Server isn't rebooted since 5 days at this moment, but the configuration is lost. I have a RB450 only for the dude server..!
Whats the problem and how can I get my configuration again?
Thanks,
adonato
Thu Nov 21, 2019 3:58 pm
Hello to all... I have the same issue problem, does any one solved it?
danial898
Fri Dec 27, 2019 11:30 pm
Hi, I Have Same Problem. Please Solve It.
psoft68
Thu Mar 05, 2020 11:56 am
I have the same problem.
For me working solution is disable DUDE service (from Dude settings) , before shutdown or restart Mikrotik Dude router.
Note that when you stop service you must check the status text. Normally the status is "running"
When you stop service the status became "applying settings: disabling: waiting for config changes to flush (xxxxxxx bytes in queue)"
You must wait till the status becomes "applying settings: disabling: stopped"
Users browsing this forum: No registered users and 64 guests
