karina
exporting firewall config
Wed Feb 10, 2010 3:07 pm
Hi All,
I notice you guys post scripts on the forum that users can copy and paste into a teminal window to add firewall rules etc. How can I make these scripts? I have multiple APs on my network and I want to export firewall rules from one and add to others. Or is there a better way to mirror firewall rules across a bunch of APs
Thanks in Advance
PS : This forum is brilliant and has saved my life. I have lost my main Techie and having to learn stuff way over my head. :D
normis
Re: exporting firewall config
Wed Feb 10, 2010 3:09 pm
type:
ip firewall export file=name
then find a file called "name.rsc" in your files folder. if you want it on screen, not in a file, omit the file part.
karina
Wed Feb 10, 2010 6:31 pm
Thanks Normis.
Excellent as ever
Users browsing this forum: No registered users and 76 guests
