yadmin
RB450G RouterOS 4.5 Torch BUG ?
Thu Feb 11, 2010 5:15 pm
RB450G. CPU sits at 20% or so, then I torch a busy Ethernet interface and CPU spikes to 100% and no output data. I had same problems on a RB133 RB433 RB411A RB450 .
3.28 3.30 4.4 4.5 having this same issue on
Thoughts? Happy to provide additional data.
Myron
Re: RB450G RouterOS 4.5 Torch BUG ?
Wed Feb 17, 2010 10:10 am
same issue here sometimes when i run torch cpu reach 100% and shows nothing.
jarosoup
Long time Member
Long time Member
Tue Feb 23, 2010 8:58 pm
I've seen this as well on version 3.x using 450, 450G, and 1000. The only way we can make traffic show up is to check the protocol box and select the protocol type (tcp, udp, etc). This didn't used to be a requirement (?).
jarosoup
Long time Member
Long time Member
Sat Feb 27, 2010 6:49 am
I think I've figured out how to get around this problem. To see all traffic on an interface, check the protocol and port checkboxes and select "any-ip" for the protocol and "any" for the port. This does not max out the CPU either. Tested on a RB1000 with 3.30.
yadmin
Sat Mar 06, 2010 8:48 am
RouterOS v4.6 Issues remain unresolved
Users browsing this forum: BoGs, Google [Bot] and 57 guests
