albeniz
kill user online
Sat Mar 06, 2010 1:44 pm
hi all
With user manager ,How can the member disconnect is on the line? (user online in the user manager)
eneimi
Re: kill user online
Sun Mar 07, 2010 6:02 pm
Remove the user's session(s) from the list of active sessions (A sessions) in the UM web interface. This is likely to work better if you have CoA enabled in UM as well as in your hotspot router.
Of course you can always use winbox and directly terminate the active session.
If you use PPPoE however, CoA will not work.
volkirik
Fri Jul 23, 2021 6:48 pm
CoA works on my router. just set port to 1700 on usermanager and radius tab of router.
select users, choose disable, then choose enable when desired the user(s) will reconnect
Users browsing this forum: Bing [Bot] and 53 guests
