Nando_lavras
Problems with DNS in Version 4.x
Tue Mar 09, 2010 4:41 pm
Hi all.... i have upgraded to version 4.x (i already tested 4.2, 4.4, 4.5) and in all versions i have a problem in DNS, after a time working normal the dns stops, and in the dns config the primary and secondary ips revert to 0.0.0.0 and the "allow remote requests" is unchecked, i set the ips manually and check "allow remote requests" again, but does not work, mikrotik reverts all to 0.0.0.0 and uncheck the option..... the dns only return to work after a reboot....... after the reboot all options are ok, the primary and secondary ips are set correctly and the option "allow remo..." is checked, and all working normal for a time, after a variety time the simptoms occour again..... exist some solution to this problem???
Thanks in advance, bye.
PS: In this moment i using version 4.2 (its the more stable dns version at this moment)
PS2: Sorry for the bad english.
LatinSuD
Re: Problems with DNS in Version 4.x
Tue Mar 09, 2010 7:14 pm
Try "/ip dns print" from a terminal.
Nando_lavras
Tue Mar 09, 2010 7:18 pm
In this moment the dns is working normal, this is the print from " ip dns print" command:
primary-dns: xxx.xxx.xxx.40
secondary-dns: xxx.xxx.xxx.41
allow-remote-requests: yes
max-udp-packet-size: 512
cache-size: 24000KiB
cache-max-ttl: 1w
cache-used: 12079KiB
PS: I put XXX on Ips....
Thanks in advance...
romanse
Wed Mar 10, 2010 6:05 pm
Today I had the same problem with DNS
[admin@VPN_Serdi_Server] > ip dns print
primary-dns: 91.15.22.114
secondary-dns: 10.0.0.40
cache-size: 24096KiB
cache-max-ttl: 1w
cache-used: 4105KiB
RouterOS v4.5
I had made support.rif when the problem was
support please see support.rif - dam man I cant add supout.rif
where can I send this supout.rif
Chupaka
Wed Mar 17, 2010 1:21 am
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Nando_lavras
Wed Mar 17, 2010 7:09 pm
I send a supout.rif to mikrotik in this e-mail.... i waiting a return...... thanks for all.....
rpress
Wed Mar 17, 2010 8:14 pm
I too had problems with the MikroTik DNS server. I was just using it to cache records, as a resolving DNS server. After a couple days it would stop responding, so I stopped using it.
overbr
Wed May 12, 2010 11:13 pm
Same problem here... any solution ?
dikobraz23
Tue May 18, 2010 12:54 pm
I have the same problem. Every three days I no longer walk and DNS report describes it as Nando_lavras.
Nando_lavras
Tue May 18, 2010 5:36 pm
I could not get solution to this problem, not updating to latest version it worked ... the solution for me was to leave the Mikrotik DNS completely, I setup 2 servers with Ubuntu + bind9, set up the profiles of my PPPoE servers to new Ubuntu servers.... problem solved, never had problems with it.
Hotz1
Wed May 19, 2010 1:27 am
dikobraz23: Does this behavior continue as recent as ROS 4.9?
Normis et. al.: Has the MT crew identified the problem?
Nando_lavras: might you have a dhcp-client configured to use peer DNS?
Principal, Engineering
Cape Ann Communications, Inc.
Gloucester, MA, USA
Nando_lavras
Wed May 19, 2010 2:59 am
This problem continue in 4.9..... i not use dhcp-client, is a pppoe-concetrator..... only used do authenticate pppoe users, the link is received with a static ip configuration (ethernet) and distributed with pppoe.....
synet2k
Wed May 19, 2010 3:33 am
I am currently using a RB600a routerboard and a x86 RouterOS with ver 4.9 without any problem on DNS.
Hotz1
Wed May 19, 2010 4:02 am
I too am using all types of RouterBoards, spanning multiple 3.x and 4.x releases, and have not had this problem with DNS. It occurred to me that DHCP could be changing the DNS settings, that's all.
Gloucester, MA, USA
dikobraz23
Wed May 19, 2010 7:27 am
The problem I had in version 3.x. The problem is only on a quad Xeon server where it is connected to more than 1,000 users. Simply fails to Table of so many demands and time to go mental and tables where the same set DNS are 0.0.0.0.
Nando_lavras
Wed May 19, 2010 11:16 am
Must be a problem of x86, I do not use Routerboards for servers, I use servers (Core 2 Duo with 2GB of RAM), but no more problem for me, the problem has been solved using the linux DNS servers.
sergejs
Wed May 19, 2010 3:07 pm
Yes, there is small possibility, that problem could be on x86 routers. Anyone who is experiencing the problem with DNS in the same way, as Nando_lavras described in the first post, it would be great you can do small test.
Set the configuration to your router,
/system hardware set multi-cpu=no
/system reboot
Please post your report here or contact support (support@mikrotik.com), thank you very much for your help.
Nando_lavras
Wed May 19, 2010 4:43 pm
I use the option set-multi-cpu = no .... and happens the same problem .... with yes or no ...
dikobraz23
Wed May 19, 2010 10:35 pm
/system reboot
Yes this is the solution. But not for me. Ja mam to MK over 1000 clients over ip hotspot. To disable multi-cpu so cpu mam tapped to 100 percent.
sergejs
Thu May 20, 2010 7:50 am
dikobraz23 thank you then do not switch additional cores.
Nando_lavras,
1) Have you rebooted the router after setting the configuration?
2) How long you should wait to get the problem with DNS? How frequently it occurs?
dikobraz23
Thu May 20, 2010 8:56 am
If I do not switched core, the CPU is at 100 percent.
Server: Supermicro i3000, Quad XEON.
Problem occurs sporadically. Roughly once every three days.
Nando_lavras
Thu May 20, 2010 11:18 am
Nando_lavras,
1. Yes i rebooted the router..... after this in the resources tab show me only 1 core..... but the problem occours in same way....
2. There is not a right time.... has arrived to work one month without any problems ... but have had weeks of almost daily to problem ... has not a right time, just working and a sudden stopped working, I just knew that would stop because customers began to call saying that he stopped to browse.
sergejs
Thu May 20, 2010 12:03 pm
Nando_lavras, it would be great you can generate support output file when DNS is not working with one core and send it to us (support@mikrotik.com)
Nando_lavras
Thu May 20, 2010 1:08 pm
Sergejs as I explained above I am no longer using the mikrotik dns, I swapped for 2 ubuntu + bind9 servers because of these problems and dropped out of mikrotik dns, if one day I re-use it sure will make the requested test. ... I'm so not because of testing has caused many problems for my clients .... after I started using the new dns with Linux already has a few good months that I have no problems .... thank you for your attention.
PS: Someone who is experiencing the same problem could do the test for Sergejs??
LatinSuD
Tue Jun 01, 2010 7:37 pm
Switched dns to debian+djdbns
sergejs
Wed Jun 02, 2010 8:07 am
There are no reports about the particular problem anymore, we asked 1 or 2 people to tune the configuration and we do not get any feedback.
askanazus
Sun Aug 08, 2010 4:18 pm
askanazus
Sun Aug 08, 2010 4:28 pm
Version 4.11
[XXXX@PPTP Router] > ip dns print
action timed out - try again, if error continues contact MikroTik support and send a sup
out file (13)
normis
Mon Aug 09, 2010 9:38 am
Version 4.11
out file (13)
what kind of device you have? if routerboard, which model?
askanazus
Mon Aug 09, 2010 4:03 pm
[XXXX@PPTP Router] > system resource print
uptime: 22h10m29s
version: "4.11"
free-memory: 931388kB
total-memory: 970876kB
cpu: "Intel(R)"
cpu-count: 2
cpu-frequency: 2999MHz
cpu-load: 21
free-hdd-space: 83976kB
total-hdd-space: 123951kB
write-sect-since-reboot: 39976
write-sect-total: 495989962
architecture-name: "x86"
board-name: "x86"
platform: "MikroTik"
[XXXX@PPTP Router] > system resource pci print
# DEVICE VENDOR NAME IRQ
0 05:01.0 VIA Technologies, Inc. VIA High Definition Audio ... 3
1 04:0b.0 VIA Technologies, Inc. VT6105M [Rhine-III] (rev: ... 11
2 04:0a.0 VIA Technologies, Inc. VT6105M [Rhine-III] (rev: ... 5
3 04:09.0 VIA Technologies, Inc. VT6105M [Rhine-III] (rev: ... 10
4 04:08.0 VIA Technologies, Inc. VT6105M [Rhine-III] (rev: ... 3
5 01:00.0 VIA Technologies, Inc. UniChrome Pro IGP [VIA P4M... 11
6 00:13.0 VIA Technologies, Inc. VT8237A Host Bridge (rev: 0) 0
7 00:12.0 VIA Technologies, Inc. VT6102 [Rhine-II] (rev: 124) 11
8 00:11.7 VIA Technologies, Inc. VT8251 Ultra VLINK Control... 0
9 00:11.0 VIA Technologies, Inc. VT8237A PCI to ISA Bridge ... 0
10 00:10.4 VIA Technologies, Inc. USB 2.0 (rev: 134) 10
11 00:10.3 VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Con... 5
12 00:10.2 VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Con... 10
13 00:10.1 VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Con... 3
14 00:10.0 VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Con... 11
15 00:0f.1 VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/V... 0
16 00:0f.0 VIA Technologies, Inc. VT8237A SATA 2-Port Contro... 3
17 00:0a.0 Accton Technology Corporation SMC2-1211TX (rev: 16) 5
18 00:09.0 Hint Corp HB6 Universal PCI-PCI brid... 0
19 00:03.0 VIA Technologies, Inc. P4M890 PCI to PCI Bridge C... 10
20 00:02.0 VIA Technologies, Inc. P4M890 PCI to PCI Bridge C... 10
21 00:01.0 VIA Technologies, Inc. VT8237 PCI Bridge (rev: 0) 0
22 00:00.7 VIA Technologies, Inc. P4M890 Host Bridge (rev: 0) 0
23 00:00.6 VIA Technologies, Inc. P4M890 Security Device (re... 0
24 00:00.5 VIA Technologies, Inc. P4M890 I/O APIC Interrupt ... 0
25 00:00.4 VIA Technologies, Inc. P4M890 Host Bridge (rev: 0) 0
26 00:00.3 VIA Technologies, Inc. P4M890 Host Bridge (rev: 0) 0
27 00:00.2 VIA Technologies, Inc. P4M890 Host Bridge (rev: 0) 0
28 00:00.1 VIA Technologies, Inc. P4M890 Host Bridge (rev: 0) 0
29 00:00.0 VIA Technologies, Inc. P4M890 Host Bridge (rev: 0) 0
[XXXX@PPTP Router] > system resource irq print
IRQ OWNER
1 [IO-APIC-edge i8042]
4 [IO-APIC-edge serial]
6 [IO-APIC-edge floppy]
8 [IO-APIC-edge rtc]
9 [IO-APIC-fasteoi acpi]
12 [IO-APIC-edge i8042]
14 [IO-APIC-edge ide0]
15 [IO-APIC-edge ide1]
18 [IO-APIC-fasteoi eth3]
19 [IO-APIC-fasteoi eth0]
19 Local Users(22)
20 [IO-APIC-fasteoi uhci_hcd:usb2]
20 To Global(16.30)
21 [IO-APIC-fasteoi sata_via]
21 [ehci_hcd:usb1]
21 [uhci_hcd:usb4]
22 [IO-APIC-fasteoi uhci_hcd:usb3]
23 [IO-APIC-fasteoi uhci_hcd:usb5]
23 free1
I had the same problem with routeros v4.6 after upgdrade to v4.11 still have it
it works fine after reboot 1 or 2 days and in system logs i can see this message
aug/08 19:49:12 system,error,critical System rebooted because of kernel failure
tanjil
Thu Sep 09, 2010 1:49 am
hi there
one of my mikrotik hasproblem that is ....suddenly it has been stucked and nobody can browse or download anything that time ..nd also i cannot even ping outside ... when i have seen the dns section there is no value .. after rebooting the mikrotik the problem has been solved for temporary ...
how do i solve this ...
please help me to solve this problem..
Inssomniak
Thu Sep 09, 2010 4:14 am
Ive had this problem too, but only once every few months.
/ip dns print gives an error timeout.
Reboot fixes it for the next bunch of months.
BobcatGuy
Thu Sep 09, 2010 7:19 pm
I have this problem too for the last year or so, differnet versions, where nothing works, dns lookups fail. I always blaimed my ISP who were very nice to give me credits for lack of service, but then the problem kept comming back, not very often, but it does. I has this on my main router, a 493AH. happened about 7 times in 10 months. reboots for me sometimes fixed the problem, other times after 5 reboots, it still was a problem, so I used a backup config file, then it worked. Never had time to dig into this issue, just happen to stumble upon this thread today.
I'm running 4.10 since it was released and have not had an issue that I can recall now. The issue was there on earlier versions, just dont know which ones.
tanjil
Fri Sep 10, 2010 1:10 am
yeah that is true.. after upgrading my MT 4.10 to 4.11 the problem has been started again.. dont know when ill get relief from that... how can i downgrade the version
any clue?
Tanz
tanjil
Fri Sep 10, 2010 1:12 am
/system reboot
---> i did it but its not worked...
Any solution ?
quantex75
Fri Sep 10, 2010 5:01 am
I have this problem with DNS in versions 4.10-4.11 and 5.0beta6
[ihor@MT-NetServer] > system resource print
uptime: 30m18s
version: "5.0beta6"
free-memory: 212404KiB
total-memory: 255476KiB
cpu: "Intel(R)"
cpu-count: 2
cpu-frequency: 3066MHz
cpu-load: 7%
free-hdd-space: 883048KiB
total-hdd-space: 952944KiB
write-sect-since-reboot: 56518
write-sect-total: 56518
board-name: "x86"
[ihor@MT-NetServer] > system resource pci print detail
0 device="01:0b.0" name="82540EM Gigabit Ethernet Controller (rev: 2)"
vendor="Intel Corporation" category="Ethernet controller" vendor-id="0x8086"
device-id="0x100e" irq=10 memory=0xDFEE0000-0xDFEFFFFF,0xDFEC0000-0xDFEDFFFF
io=0xD800-0xD83F
1 device="01:0a.0" name="82540EM Gigabit Ethernet Controller (rev: 2)"
device-id="0x100e" irq=5 memory=0xDFE80000-0xDFE9FFFF,0xDFE60000-0xDFE7FFFF
io=0xD400-0xD43F
2 device="01:09.0" name="82540EM Gigabit Ethernet Controller (rev: 2)"
device-id="0x100e" irq=10 memory=0xDFE20000-0xDFE3FFFF,0xDFE00000-0xDFE1FFFF
io=0xD000-0xD03F
3 device="01:03.0" name="82540EM Gigabit Ethernet Controller (rev: 2)"
device-id="0x100e" irq=5 memory=0xDFDC0000-0xDFDDFFFF,0xDFDB0000-0xDFDBFFFF
io=0xC800-0xC83F
4 device="02:00.0"
name="RTL8111/8168B PCI Express Gigabit Ethernet controller (rev: 1)"
vendor="Realtek Semiconductor Co., Ltd." category="Ethernet controller"
vendor-id="0x10ec" device-id="0x8168" irq=10 memory=0xDFFFF000-0xDFFFFFFF
io=0xE800-0xE8FF
5 device="00:1f.3"
name="82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev: 5)"
vendor="Intel Corporation" category="SMBus" vendor-id="0x8086"
device-id="0x266a" irq=0 io=0x400-0x41F
6 device="00:1f.2" name="82801FB/FW (ICH6/ICH6W) SATA Controller (rev: 5)"
vendor="Intel Corporation" category="IDE interface" vendor-id="0x8086"
device-id="0x2651" irq=5 io=0xA400-0xA40F
7 device="00:1f.1"
name="82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller (rev: 5)"
device-id="0x266f" irq=0 io=0xFFA0-0xFFAF
8 device="00:1f.0" name="82801FB/FR (ICH6/ICH6R) LPC Interface Bridge (rev: 5)"
vendor="Intel Corporation" category="ISA bridge" vendor-id="0x8086"
device-id="0x2640" irq=0
9 device="00:1e.0" name="82801 PCI Bridge (rev: 213)" vendor="Intel Corporation>
category="PCI bridge" vendor-id="0x8086" device-id="0x244e" irq=0
10 device="00:1d.3"
name="82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev: 5)"
vendor="Intel Corporation" category="USB Controller" vendor-id="0x8086"
device-id="0x265b" irq=10 io=0xA000-0xA01F
11 device="00:1d.2"
name="82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev: 5)"
device-id="0x265a" irq=11 io=0x9800-0x981F
12 device="00:1d.1"
name="82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev: 5)"
device-id="0x2659" irq=5 io=0x9400-0x941F
13 device="00:1d.0"
name="82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev: 5)"
device-id="0x2658" irq=4 io=0x9000-0x901F
14 device="00:1c.0"
name="82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 1 (rev: 5)"
vendor="Intel Corporation" category="PCI bridge" vendor-id="0x8086"
device-id="0x2660" irq=10
15 device="00:1b.0" name="82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition
Audio Controller (rev: 5)"
vendor="Intel Corporation" category="Audio device" vendor-id="0x8086"
device-id="0x2668" irq=10 memory=0xDFCFC000-0xDFCFFFFF
16 device="00:00.0"
name="82915G/P/GV/GL/PL/910GL Memory Controller Hub (rev: 14)"
vendor="Intel Corporation" category="Host bridge" vendor-id="0x8086"
device-id="0x2580" irq=0
[ihor@MT-NetServer] > system resource irq print detail
0 irq=1 users=i8042 cpu=auto active-cpu=1
1 irq=3 users=serial cpu=auto active-cpu=1
2 irq=6 users=floppy cpu=auto active-cpu=1
3 irq=9 users=acpi cpu=auto active-cpu=1
4 irq=12 users=i8042 cpu=auto active-cpu=1
5 irq=14 users=ide0 cpu=auto active-cpu=1
6 irq=15 users=ide1 cpu=auto active-cpu=1
7 irq=16 users=usb4 cpu=auto active-cpu=1
8 irq=17 users=Ether_Wi-Fi-Networks cpu=auto active-cpu=1
9 irq=18 users=usb3 cpu=auto active-cpu=1
10 irq=19 users=Ether_LocalNet_Ufo,usb2,ata_piix cpu=auto active-cpu=1
11 irq=21 users=Ether_Canada-LAN cpu=auto active-cpu=1
12 irq=22 users=Ether_Kanada.Net cpu=auto active-cpu=0
13 irq=23 users=usb1 cpu=auto active-cpu=1
14 irq=25 users=Ether_Internet cpu=auto active-cpu=1
[ihor@MT-NetServer] > ip dns print
servers: 194.44.203.5,208.67.222.222
cache-size: 8192KiB
cache-max-ttl: 1w
cache-used: 109KiB
tanjil
Fri Sep 10, 2010 12:48 pm
uptime: 11h58m15s
version: "4.11"
free-memory: 963932kB
total-memory: 1019532kB
cpu: "Intel(R)"
cpu-count: 1
cpu-frequency: 2992MHz
cpu-load: 16
free-hdd-space: 54730kB
total-hdd-space: 121999kB
write-sect-since-reboot: 174680
write-sect-total: 174680
board-name: "x86"
anjil@OmegaPPPOE] > ip dns pr
servers: 203.112.194.243,10.10.0.1
max-udp-packet-size: 1500
cache-size: 10240KiB
cache-max-ttl: 1w
cache-used: 678KiB
[tanjil@OmegaPPPOE] >
[tanjil@OmegaPPPOE] /system> hardware pr
multi-cpu: no
[tanjil@OmegaPPPOE] /system> health pr
state: disabled
state-after-reboot: enabled
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 4.11 (c) 1999-2010 http://www.mikrotik.com/
[tanjil@OmegaPPPOE] > system resource pr
uptime: 11h58m15s
version: "4.11"
cpu: "Intel(R)"
cpu-count: 1
cpu-load: 16
board-name: "x86"
[tanjil@OmegaPPPOE] > ip dns pr
cache-max-ttl: 1w
cache-used: 678KiB
[tanjil@OmegaPPPOE] /system> pr
bad command name pr (line 1 column 1)
backup lcd scheduler reset-configuration
clock license script serial-terminal
console logging upgrade shutdown
default-configuration note watchdog ssh
hardware ntp check-disk sup-output
health package check-installation telnet
history resource export
identity routerboard reboot
multi-cpu: no
state: disabled
[tanjil@OmegaPPPOE] > system resource pci print detail
0 device="01:05.0" name="RTL-8139/8139C/8139C+ (rev: 16)"
vendor-id="0x10ec" device-id="0x8139" irq=3 memory=0xFF991000-0xFF9910FF
io=0xA800-0xA8FF
1 device="01:04.0" name="RTL-8139/8139C/8139C+ (rev: 16)"
vendor-id="0x10ec" device-id="0x8139" irq=10 memory=0xFF990C00-0xFF990CFF
io=0xB000-0xB0FF
2 device="01:02.0" name="3c905B 100BaseTX [Cyclone] (rev: 100)"
vendor="3Com Corporation" category="Ethernet controller"
vendor-id="0x10b7" device-id="0x9055" irq=3 memory=0xFF990800-0xFF99087F
io=0xBC00-0xBC7F
3 device="01:01.0" name="RTL-8139/8139C/8139C+ (rev: 16)"
vendor-id="0x10ec" device-id="0x8139" irq=11 memory=0xFF990400-0xFF9904FF
io=0xB400-0xB4FF
4 device="01:00.0" name="RTL-8139/8139C/8139C+ (rev: 16)"
vendor-id="0x10ec" device-id="0x8139" irq=10 memory=0xFF990000-0xFF9900FF
io=0xB800-0xB8FF
5 device="00:1f.5"
name="82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller (rev: 2)"
vendor="Intel Corporation" category="Multimedia audio controller"
vendor-id="0x8086" device-id="0x24d5" irq=3
memory=0xFFA80400-0xFFA805FF,0xFFA80800-0xFFA808FF
6 device="00:1f.3" name="82801EB/ER (ICH5/ICH5R) SMBus Controller (rev: 2)"
device-id="0x24d3" irq=3 io=0xC400-0xC41F
7 device="00:1f.2" name="82801EB (ICH5) SATA Controller (rev: 2)"
device-id="0x24d1" irq=10 io=0xD800-0xD80F
8 device="00:1f.1" name="82801EB/ER (ICH5/ICH5R) IDE Controller (rev: 2)"
device-id="0x24db" irq=255 memory=0x40100000-0x401003FF io=0xFFA0-0xFFAF
9 device="00:1f.0"
name="82801EB/ER (ICH5/ICH5R) LPC Interface Bridge (rev: 2)"
device-id="0x24d0" irq=0
10 device="00:1e.0" name="82801 PCI Bridge (rev: 194)"
11 device="00:1d.7"
name="82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller (rev: 2)"
device-id="0x24dd" irq=9 memory=0xFFA80000-0xFFA803FF
12 device="00:1d.3"
name="82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 (rev: 2)"
device-id="0x24de" irq=11 io=0xD400-0xD41F
13 device="00:1d.2"
name="82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 (rev: 2)"
device-id="0x24d7" irq=10 io=0xD000-0xD01F
14 device="00:1d.1"
name="82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 (rev: 2)"
device-id="0x24d4" irq=5 io=0xCC00-0xCC1F
15 device="00:1d.0"
name="82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 (rev: 2)"
device-id="0x24d2" irq=11 io=0xC800-0xC81F
16 device="00:02.0" name="82865G Integrated Graphics Controller (rev: 2)"
vendor="Intel Corporation" category="VGA compatible controller"
vendor-id="0x8086" device-id="0x2572" irq=11
memory=0xF0000000-0xF7FFFFFF,0xFFA00000-0xFFA7FFFF io=0xEC00-0xEC07
17 device="00:00.0"
name="82865G/PE/P DRAM Controller/Host-Hub Interface (rev: 2)"
device-id="0x2570" irq=0 memory=0xF8000000-0xFBFFFFFF
===========Solution pls....
Madrox
Sat Sep 11, 2010 3:20 am
Hey
I did have this problem whit my rb1000, think i figuret out that it stops when it get to mutch reqest.
But now i run servers bind9. and the problem was gone.
tanjil
Sat Sep 11, 2010 12:32 pm
Still we r not gettng solution from mikrotik teaam......
A
tanjil
Tue Sep 14, 2010 1:13 am
Hi all
as far no reply from mt team.. the temporary solution is change your LAN card .. it might be okey i think...
its works here...
A
tanjil
Mon Sep 20, 2010 8:39 pm
:( its not solution ... again its started
i would like to requestmikrotik team to solve this problem.. cause i took so many licences for that but didnt get any solution fromyou....
normis
Tue Sep 21, 2010 9:15 am
have you emailed support with any new information? you didn't even answer my post
tanjil
Wed Sep 22, 2010 1:06 am
dear normis
imreally sorry to say that i have tried a lot. and very much sorry cudnot see your post,
and i have send email.. so many times.. again im sending the file
thanks
BobcatGuy
Sun Dec 05, 2010 5:39 am
I have had this issue in the past every few months...
BUT now I have been having it 2 or 3 times a day, sometimes within 10 minutes after a full power cycle.
I cant confirm its DNS, but dns requests do not get a response, such as on a tracert cnn.com etc.
Also Cannot PING a Domain name, DNS fails, AND cannot ping a known IP of a device ( on internet ) that responds to ping.
Pings, and all inside LAN stuff works.
I have my cable modem plugged into ether 2, and bridged with ether 3 where a voip box gets a public IP. DHCP client on Ether 2 also gets Public IP. This is on a 493AH board.
This VOIP box has connectivity when this issue happens, phone will work, it is just bridged to get public IP not NATTED.
All other devices that are NATTED have no access to internent, ANY protocols.
I do have another RB 493 ( Not AH ) that has its ether 1 connected to this first 493ah Ether 9 port. I have NEVER had the issue with NAT failing on the 493. To clarify, the 493 (notAH) is at a remote location Ether 1 from this device is connected to ether 9 on the RB493AH the one with the problems.
This actually drives me up the wall since when it fails, I need to reboot the router, but that ussually is when I come home, and other people depend on this internet access.
I have had 3 Cable modems in the last few days, ISP trying to help me, the first two were Docsis 2.0 and the third one I use now is a DOCSIS 3.0. The best part of the whole issue was in the process the ISP used the docsis 3 and upgraded my plan at no charge, so instead of 15 Mbit down, and 1 mbit up. I now get 50Mbit down, and 3 Mbit up... So I guess I did benifit from it kinda.
One thing my ISP does, which may be normal for all cable providers, is they have a CONSTANT ARP data going on on the ethernet side of the cable modem. Dont know if this would matter, but worth pointing out. It is a Motorola Docsis 3.
NOTE: This was working on earlier versions, and just this week was on 4.12, then upgraded to 4.13 and still having issue.
normis
Mon Dec 06, 2010 12:38 pm
email support with supout.rif files please
BobcatGuy
Wed Dec 08, 2010 1:42 am
I have sent the email, and recived a quick response....
Apparedly there is no fix for this problem, but I was told that i should use a RouterBOARD instead. Funny, the problem is on a 493AH Routerboard. I email that information back, but have not heard back yet.
Seeing as V5 will probably be out somewhat soon, is this an issue in V 5? or has it been fixed?
Is this hardware specific issue?
This was not an issue before, but has gotten worse as new releases came out. At what version did it work properly?
Why Do I see this issue only on a 493AH, and not on a 493 routerboard? Both do natting, and run thier own DNS.
Turns out that this may not be the same issue as described above. Seems as if Checking USE PEER DNS on one interface cuases another interface with DHCP client to use that Peers dns, which is an internal IP with no route to it. ( WIerd setup on my stuff)
tanjil
Wed Jan 26, 2011 7:11 pm
i tried but somehow its not working.. if i flush my dns same error i got
l0pes
Tue Mar 01, 2011 4:42 pm
Apparently, this problem occurs only on x86. Today I had this problem again and everything returns to work after the reboot. I'm using version 4.16
Support, any solution for this bug?
Thanks in advance
R. L0pes
Users browsing this forum: Bing [Bot], goliathHawk, Google [Bot], KiLLeRRaT and 165 guests
