rodolfo
Long time Member
Long time Member
MilliScript: freeware to manage export configuration files
Wed Mar 17, 2010 12:06 am
Hi all. Everyone can download this simple exe which:
- save RouterOs export configuration file in a readable form (one parameter per line)
- compare differences from two ros export configuration files (highlights different settings)
- clean a ros configuration file from unused commands, unused sections and unused parameter (you can configure what is unused)
- create configurations file from template
- show a simple help
WIKI PAGE: http://wiki.mikrotik.com/wiki/Milliscript
I hope it can help someone.
It is a simple exe and do not require installation.
Obviously it is provided as-is and without any warranty.
If you want, provide a feedback to make it better.
EDIT: 26/12/2012 - minimal interface bug fixing
MilliScript147.zip
EDIT:  18/08/2011 - correct a bug (parameters 'name' ignored if at beginning of line)
MilliScript146.zip [739.39 KiB]
Downloaded 2565 times
EDIT:  new functions, better handling of parsing, create wiki page
MilliScript145.zip [739.38 KiB]
Downloaded 366 times
EDIT:  new version with new handling of file-save
milliScript137.zip [548.06 KiB]
Downloaded 2164 times
EDIT:  new version with small fixes
EDIT:  new version with a small fix (the clean button moved to the top)
First version
normis
Re: MilliScript: freeware to manage export configuration files
Wed Mar 17, 2010 10:08 am
Wow cool, thanks! Looks very interesting
rodolfo
Long time Member
Long time Member
Wed Mar 17, 2010 8:30 pm
Thanks Normis!
I'm working on a wiki page I will publish soon.
rodolfo
Long time Member
Long time Member
Sat Mar 20, 2010 7:10 pm
added version 1.35
jolival
Trainer
Trainer
Sun Mar 21, 2010 5:43 pm
nice work.
João Olival
brigitte79
Tue Mar 23, 2010 10:18 pm
Great job Rodolfo
Thanks Brigitte :D
Muqatil
Trainer
Trainer
Fri Mar 26, 2010 5:47 pm
This script made my day...
I was after a hidden misconfiguration on a live machine, while the test machine was working properly...
I compared the 2 exports and i found the misconfiguration.
Grazie mille Rodolfo, programma semplice ma molto efficace :)
ViREnG
Sun Mar 28, 2010 9:33 pm
Please Sticky or Add to Mikrotik Tools .
Nice Work . :)
Chupaka
Mon Mar 29, 2010 6:45 pm
I'd rather create Wiki page =) http://wiki.mikrotik.com/
rmichael
Forum Veteran
Forum Veteran
Wed Apr 14, 2010 2:11 am
This is great. The app is very usefull as it is however, if you're looking for suggestions I would like another tab that looks like compare but where I can pick and checkmark lines to create rsc script.
Thank you for sharing.
PS: I found a bug: ssid is being converted to all lower case which is not correct since ssid is case sensitive.
rodolfo
Long time Member
Long time Member
Sat Apr 17, 2010 5:00 pm
Attached a new version 1.36 in the main post.
Fixes of 1.36:
- ssid now is not more lowercased (thanks rmichael)
- names with spaces now are correctly inside quotes
- cleanup of files now correctly handle commands with disabled=yes
Thanks.
Rodolfo
rodolfo
Long time Member
Long time Member
Sat Apr 24, 2010 11:16 am
Attached the new version 1.37 in the main post.
Fixes of 1.37:
- file save now have the file loaded name
Thanks.
Rodolfo
car1cow
Sat Apr 24, 2010 6:45 pm
Thanks, nice works
kazanova
Sat Apr 24, 2010 11:16 pm
lol really nice
good work
thx
leonset
Tue Jun 29, 2010 2:06 pm
Hello!
I'm trying to use this program to check my configuration but when I load the file I only get garbage on screen. I'm I doing something wrong?
Thanks!
rodolfo
Long time Member
Long time Member
Thu Jul 01, 2010 12:02 pm
if you open the same file using Notepad, what you see ?
You must open file obtained using Export, not Backup.
normis
Tue Jul 12, 2011 10:15 am
any updates to this nice program?
rjscomms
Wed Jul 13, 2011 1:54 am
Excellent work rodolfo.
I have been thinking about how to do this for a while now.
Very Nice, thankyou.
hellweiss
Thu Jul 14, 2011 2:26 pm
Great, thank you.
Karma +1
hilton
Long time Member
Long time Member
Thu Jul 14, 2011 2:37 pm
The question remains though, are there any recent updates?
rodolfo
Long time Member
Long time Member
Sun Jul 24, 2011 12:22 pm
Create wiki page: http://wiki.mikrotik.com/wiki/Milliscript
Uploaded last version:
- better parsing of rsc files
- tested with 5.5
- the file cleaner now support profiles (i.e. I wnat a profile FULL where I delete a lot of things, and a profile MAC where I delte only mac addresses
- in the cleaner added flags to delete all default values (delete all parameters named "default", i.e. the default bgp instance, ecc)
- new section "Modeling": you can compile a rsc file from a template, changing variables with values (i.e. I have a rsc file where radio-name and system identity are variables: here I can simply change this names with a value. It allow also to create tempaltes)
- you can open in notepad cleaned and compiled template rsc file
- little improve to the help
normis
Mon Jul 25, 2011 8:27 am
Thanks! The program is really great
matteorb
Mon Jul 25, 2011 4:22 pm
Nice Job Rodolfo! Thanks! :D
learnnow
Fri Jul 29, 2011 5:04 am
THANKS MAN!
netrat
Wed Aug 17, 2011 10:06 pm
Your program leaves out the name entry in /ip pool. Actually it leaves the name entry off /interface pppoe-server as well and probably others. I'm using RouterOS 5.6, could this be a problem?
rodolfo
Long time Member
Long time Member
Wed Aug 17, 2011 11:07 pm
thanks of info. tomorrow I will inspect the code.
rodolfo
Long time Member
Long time Member
Thu Aug 18, 2011 9:39 am
Correct the bg: in some cases, if parameter "name" is at the beginning of line, it can be ignored.
thanks
netrat
Thu Aug 18, 2011 3:32 pm
thanks
If the name is left off of an ip pool entry and it is referenced by /ip dhcp-server it is not going to work.
rodolfo
Long time Member
Long time Member
Fri Aug 19, 2011 9:38 pm
yes, is the bug fixed in 1.46.
tx
netrat
Sat Aug 20, 2011 4:49 am
tx
Thanks for the awesome program!
mmmigoro
Sat Sep 17, 2011 1:26 pm
Thanks! Nice and handy utility!
omega-00
Mon Sep 19, 2011 8:52 am
Hi rodolfo,
Firstly, great work on the script! I've been playing around with it this afternoon and am quite impressed.
Secondly, as you're currently hosting just on the forum, if you're interested I'm happy to set you up a site or subdomain on my site where you can share/update it directly if you'd like.
Feel free to bang me an email if you're interested: admin@mikrotik-routeros.com
and from the community, thanks!
cbrown
Trainer
Trainer
Tue Oct 25, 2011 6:35 pm
This is amazing. Thank you
rtandon
Sat Jan 28, 2012 2:11 am
Thanks rudolfo
I had to do this manually (reformatting RSC and then using diff or such tool)
It will hopefully save much time.
chrisgoldsmith
Thu Feb 02, 2012 1:38 am
Rudolfo,
May we add this as a downloadable file to our site? We are trying to acquire useful free scripts for free general use along with our own. We tested this, it really is quite helpful. Thank you for posting it.
AnRkey
Thu Sep 27, 2012 1:21 pm
Rodolfo, thanks!
aknisley
Mon Oct 29, 2012 10:39 pm
Thanks for the program. I have been trying to use to clone a working RB411 with XR3-3.5 wireless card. I get my source and clone file to look the same, but when I import I get an error (line xxx column xx).
Here is what I do.
/export file=backup the router board of the working one
/export file=backup the new router board
compare the two rsc files
change new router board the match the working one.
rename the new one to 2new.rsc
drop the 2new.rsc into the folders section
/import 2new.rsc
says it imported but gives error line xxx column xx expected end of
ronix
Tue Dec 18, 2012 10:48 am
Nice Job Rodolfo The program is really great
rodolfo
Long time Member
Long time Member
Wed Dec 26, 2012 11:06 am
Added new version 1.47.
some small interface bug fix.
Merry Christmax and Happy New Year!!!
rezamoghadam
Trainer
Trainer
Sat Dec 29, 2012 1:46 pm
Thank You , Very Great Tool !
telepro
Mon Mar 11, 2013 5:46 am
Thanks very much for a great utility. We use it continually during development of new router configurations. And it makes comparing previous and updated ROS configurations so much easier to read and manage.
One question (or suggestion): is there an option to keep the format for script source intact (as produced by the export command) without changing it to a single long line? That seem to be the single configuration command that becomes less readable when converted by this great utility.
thanks again
rodolfo
Long time Member
Long time Member
Sun Apr 07, 2013 10:26 am
Hi Telpro.
Could you make me an example?
johnremboh
Tue Jul 14, 2020 6:56 pm
will try this, this one that i need..
thanks
Users browsing this forum: AshuGite, mact, rplant and 28 guests
