normis
Supout.rif reader available
Wed Mar 17, 2010 10:22 am
We have made a simple supout.rif file viewer. To use it, log into your mikrotik.com account, and click on "supout.rif viewer":
This online utility is only accessible online from within your account, and will show the contents of the supout.rif file. Things available are configuration export, logs, resource info, registration tables, connections, license info and others.
This utility will provide great help for those who help others, consultants, distributors, ISPs.
Be careful! Don't give your supout.rif files to people who can't see your configuration and inner workings of your network. Although passwords are hidden, some sensitive information can still be seen!
The Supout.rif viewer can open up to five files at the same time, so you can switch between tabs and compare them. The files will be kept in their opened tabs even if you switch your computers, so you can keep a file there as long as you want. When you want to free the tab, just close it, and the file will be gone forever.
If you find any issues with the viewer, please post here, or email support.
nz_monkey
Re: Supout.rif reader available
Wed Mar 17, 2010 11:30 am
Nice feature, this will be useful
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
csickles
Wed Mar 17, 2010 6:19 pm
THX...
Allways wanted to know what sas in those files...
Things that make you go "Hmmmmmmmm"...
Craig
changeip
Wed Mar 17, 2010 6:30 pm
Mikrotik - You ROCK! Thank you thank you!
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
roc-noc.com
Forum Veteran
Forum Veteran
Wed Mar 17, 2010 7:23 pm
Very cool!
Thank you Normis
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
omidkosari
Trainer
Trainer
Thu Mar 18, 2010 8:40 am
Thank you . :)
eflanery
Fri Mar 26, 2010 1:35 am
Sweet, thank you!
matiasvidoni
Fri Mar 26, 2010 6:33 am
normis
What about a backup file viewer?
I have a lot of backup files from my rbs, but if I just want to see one configuration
I have to restore that backup on a rb to see it.
That would be nice.
Thanks for this viewer!
Matias Vidoni
Network Administrator
Llambi Campbell, Argentina
http://www.matiasvidoni.com.ar
normis
Fri Mar 26, 2010 8:00 am
backup file reader doesn't exist, even we at mikrotik don't have it. you can only restore from backup, not view it.
for viewing make supout.rif files and export files.
matiasvidoni
Fri Mar 26, 2010 1:19 pm
Ok then, I will change my backups scripts to add the export file and send me both by mail.
I think the backup is better for restoring than export, but export will serve as well.
Thanks for advice.
Matias
Matias Vidoni
angboontiong
Sun Mar 28, 2010 7:48 pm
Normis...
A question to ask, when i create the back up file from the routerA, and i upload it into the routerB. when i apply (restore) the routerA backup file to routerB, for the wireless card part, i need to manually to configure again.
What's going on this?
fewi
Sun Mar 28, 2010 8:17 pm
Backups are only for restoring the exact device they were taken from, they are not to be transferred to other hardware. If you need to transfer to other hardware, use "/export", which you will still have to manually edit (MAC addresses, for example).
http://wiki.mikrotik.com/wiki/Manual:Co ... Management
The restoration procedure assumes the cofiguration is restored on the same router, where the backup file was originally created, so it will create partially broken configuration if the hardware has been changed.
In my opinion that's the biggest problem with RouterOS functionality, barring bugs. The configuration management is absolutely horrible.
NetworkPro
Thu Apr 01, 2010 9:53 am
@angboontiong I think its the MAC address, if you grab the Wi Fi card from A and put in B before restore, it should restore its config as well (same MAC) or if you change the mac with the RouterOS command beforehand (just dont bring two same MACs into same network)
@Normis can't you develop and exploit a vulnerability to decrypt .backups for viewing @ the mikrotik.com account? It will be done @ your server so it will be unknown to everyone. Such vuln exists for a certain purpose (angel) at elast in the past versions.... Sorry for going a bit guerilla here but I need to be able to see and compare the backups.
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
andreacoppini
Trainer
Trainer
Thu Apr 01, 2010 3:05 pm
Great feature! Bumped into it when I was on the account server...
I support several clients and I usually ask them to send me an Export script, but this is so much easier.
Thanks guys...
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
roc-noc.com
Forum Veteran
Forum Veteran
Thu Apr 15, 2010 8:23 pm
I guess there are concerns about the banks in Latvia. Now I see where Normis keeps his money. :)
Tom
888-762-5662
Chupaka
Wed Apr 21, 2010 12:04 am
is something going wrong? =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
normis
Thu Apr 22, 2010 8:23 am
if that for a specific file? send it to support, we will see what's so special about it.
NetworkPro
Thu Apr 22, 2010 9:27 am
All my supouts that I tried show the garbage entries.
Im guessing its the hidden information that MT made the supout viewer not show to us. :)
normis
Thu Apr 22, 2010 9:31 am
can't be, show us an example. email support please
NetworkPro
Thu Apr 22, 2010 9:41 am
I wonder if I can decode these into some useful info :)
Chupaka
Thu Apr 22, 2010 1:15 pm
yes, it suddenly appeared even for my old loaded supouts. and I can see it for both x86 and rb450g supouts. by the way, I couldn't find bonding settings in supout viewer...
taduikis
Thu Oct 07, 2010 1:44 pm
Me too always thought that backup file viewer in an application similar or even identical to winbox would be nice. I also have lots of backup files stored and sometimes it would be very useful to check them out, compare, etc. Ability to modify settings and then save them to that backup file before uploading it to the router would make life easier occasionally.
Mikrotik are doing great job already, and every additional application to help out us admins are very welcome.
I really miss more tools and flexibility of configuration management. Moving from one router to another without pain is almost impossible whatever means are used (config export, backups).
This new supout file viewer partly provides that functionality (I mean preview settings stored in supout file that was generated in particular router), so thanks for that :)
Stunherald
Fri Jul 01, 2011 2:22 pm
I have 2 suggestions for this nice reader.
- Add "\" into multi-line command. Right now it is like this and easy copy&paste is not possible
add name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web,sn
iff,sensitive,api,!ftp,!write,!policy" skin=default
fix:
add name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web,sn\
- Export to TXT. Export all things into one TXT file. Or just add a "Select all" butto, which will select all of the settings for simply copy/pasting :)
Anyway, thanks for the reader :)
Sorry for my english :)
normis
Mon Jul 04, 2011 12:32 pm
we added some of the things you asked for, please see if they work
Chupaka
Tue Jul 19, 2011 1:32 am
yep, thanks for the CPU info =)
by the way, 'firewall-bytes' and 'firewall-packets' are empty (for me?)...
operat0r
Thu Nov 16, 2017 4:55 pm
Is the .rif viewer still available? If yes where can I find it ? I can't seem to be able to find a way.
Panagiotis Botos
Networking Engineer
normis
Thu Nov 16, 2017 4:57 pm
Log into your mikrotik.com account and find the reader on the bottom of the left side menu
onlineuser
Thu Mar 15, 2018 4:42 pm
Nice, but an offline viewer would be better. :shock:
Is there something in planning?
The architecture of filesystem seems to be public or where did this guy got the source for his viewer ( did not try it with my supout files)?
http://k3dt.eu/supout-reader/ (not serious to upload the supout file on any website)
Chupaka
Tue Mar 20, 2018 9:40 am
AFAIR, supout.rif file consists of length-value blocks with value data being compressed by gzip
SpongeB0B
Sat Aug 10, 2019 12:08 pm
Is MikroTik is planning an offline program to read .rif files ?
Device: Hex: RB750Gr3
mfr476
Sat Aug 10, 2019 1:43 pm
Increíble!!! Thanks a lot!!!
r00t
Sat Aug 10, 2019 5:43 pm
Here are some offline scripts to decode supout.rif files:
Perl: https://github.com/farseeker/go-mikroti ... r/unsup.pl
Go: https://github.com/farseeker/go-mikroti ... er/main.go
Much better than uploading it to some shady server for analysis... supout may contain various private info.
EDIT: Changed link to perl and go script instead of github page that offers weird EXEs for download (do not download and run them, always use source code).
Hiji56
Wed Dec 04, 2019 10:36 pm
Here are some offline scripts to decode supout.rif files: https://github.com/farseeker/go-mikrotik-rif
Make this clear please)!
r00t
Thu Dec 05, 2019 3:49 pm
Not my github, but there is source code there. It's possible this is just a false positive but I would not trust any random EXE anyway.
Just don't download the EXEs, download perl and go sources. You can look and inspect the source code as long as you want.
I only used the perl script version on linux and that works.
Sob
Thu Dec 05, 2019 5:05 pm
I've been using the Perl script on Windows for years with ActiveState Perl and it works to. It's just that I don't need Perl for anything else anymore, so mine became a little outdated and I can't vouch for current version.
Another option could be https://github.com/0ki/mikrotik-tools/b ... _supout.py, but it doesn't work for me. Although that could be just my problem, because when it comes to Python, almost nothing works, that thing just doesn't like me, maybe I'm cursed.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Users browsing this forum: kazim and 131 guests
