mostafaalsaady
what does this error mean ??? KVM Error + other thing
Thu Mar 18, 2010 8:38 pm
dear friends
http://i63.servimg.com/u/f63/12/33/78/59/prob10.jpg
and U look to the bottom of the interface on the pppoe page
u see 4 out of 7 why is that why there r 7
and just 4 user connected
LearnING MikrotiK
MTCNA - MTCWE - MTCRE - MTCTCE
fewi
Re: what does this error mean ??? KVM Error
Thu Mar 18, 2010 8:42 pm
It means that whatever processor you're running on doesn't support virtualization in hardware. KVM requires that.
http://en.wikipedia.org/wiki/X86_virtua ... re_support
mostafaalsaady
Thu Mar 18, 2010 10:32 pm
what should i do to solve this problem
change the CPU ??
or what
LearnING MikrotiK
gcakici
Re: what does this error mean ??? KVM Error + other thing
Thu Mar 18, 2010 10:35 pm
You should change your processor to a virtualization supported one, i.e. VT supported Intel cpus.
mostafaalsaady
Thu Mar 18, 2010 10:55 pm
THANX dear for the answer
and the other thing >>>>?
what does it means ?
LearnING MikrotiK
mostafaalsaady
thanx bro
LearnING MikrotiK
Chupaka
Fri Mar 19, 2010 1:06 am
or just enable VT support in BIOS setup =)
the text in status bar says 'there are 7 interfaces on the router, 4 of them are ppp'
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
janisk
Fri Mar 19, 2010 8:19 am
indeed, check if you ahve enabled virtualization in BIOS, check the page weather your CPU supports it if still no go, check if there is BIOS update that solves the problem.
Also, check if you do not have any XEN leftovers (see output on screen while booting, if there are a lot more stuff than usual messages, reinstall your router with cd-install or netinstall to reload clean RouterOS without XEN.
if you had xen on that router, then you definitely need to reinstall.
mostafaalsaady
Fri Mar 19, 2010 9:11 am
dear i have intel core 2 due CPU with giga byte mother board I upgrade to
http://download.mikrotik.com/all_packages-x86-4.6.zip
and still there is the same error
LearnING MikrotiK
janisk
Fri Mar 19, 2010 10:48 am
pleas see the wiki link posted in previously, find there your Core2 CPU to know for sure it is supported as Intel caused havoc with removing/adding features, including virtualization support. As result, you could buy seemingly more powerful CPU but end up without features you need. for example, Core 2 E6750 have virtualization support while Core 2 E7300 does not
csickles
Fri Mar 19, 2010 4:02 pm
Yeh...
Ran in to THAT prob. last night with VM Ware as well..
Picked up a Dual core DL380 server CHEAP!!
64 bit Dual core CPUs, 2GB, 2SCSI drives Etc for $180
64Bit OS install just fine, VM Ware install and creates VM's fine..
BUT.. Cant install 64Bit VMs as the VT function is NOT present int the CPU / BIOS...
Guess it is a web server for this box...
Can't complaign tho... They left 3 $500 fibre channell cards in the server when they sent it... :lol: :lol:
Things that make you go "Hmmmmmmmm"...
Craig
janisk
Fri Mar 19, 2010 4:25 pm
try your luck even more and check for new BIOS for the motherboard (that is, if CPU supports it). Upgrade might show you new sweet feature in BIOS menu
Users browsing this forum: MSN [Bot] and 3 guests
