MUM Europe 2020
taglio
MIMO antennas. To be or not to be.... this is the question!
Thu Mar 25, 2010 5:36 pm
Hi there,
please help me :? i don't understand how i have to choose MIMO antennas.
In the actuality i use mikrotik, ubiquiti and compex MIMO radios, all 2x2 MIMO.
I have in my knowledge a big lack...i don't understand what kind of MIMO antenna i have to use in my real world application.
Simply imagine a very known scenario.... A tower with 3 sector antennas of 120 degrees for the base station and number of subscriber with panel [or grid if you can find in the marquet {WHEREEEE ????}] antennas.
The question of 1 million of dollar is:
The antennas would have two [or three....] "modules" [or inside antenna.. i don't know the exact name] that will work in the same polarity, or i have two use different polarity [vertical, horizontal and 45 degree....].
In my opinion i will have to use antennas with same polarity modules.... but.... per examples Mars [http://www.mars-antennas.com/] sales dpto say to me that i have to use different polarization... .and other example in the data-sheet of of AirMax5 Sectors antennas [http://ubnt.com/downloads/AirMax5GSectors.pdf] you can see that those antennas use different polarization...
What is your real world experience MK guys???
Best Regards,
RG.
.mhavoc world
JorgeAmaral
Trainer
Trainer
Re: MIMO antennas. To be or not to be.... this is the questi
Thu Mar 25, 2010 6:15 pm
Try to understand this: http://en.wikipedia.org/wiki/IEEE_802.11n-2009
And the search google for: spatial diversity technology
802.11n 2x2 is based on spatial streams, so you need to have antennas with different polarization.
Right now their is a lack in dual polarization antennas. We need to wait for the market to start supplying these.
Kindly regards,
Jorge Amaral
taglio
Thu Mar 25, 2010 6:36 pm
Thank you for rapid reply.
Ok i can understand this for professional equipment connection [base station + CPE subscriber].
But let me speak about connection between a MIMO AP [simply image routerboard 411A + an R52N radio] and netbooks or notebooks or pda..... and so on.
No i have two MIMO chain on the radio..... The radio on those hosts have dual polarity antennas???????? I don't think so.... i don't have to use simply to omnidireccional normal antennas?
Thank you,
RG
.mhavoc world
InoX
Thu Mar 25, 2010 7:19 pm
mimo works also with same polarity. For example we use a dual feeder for RocketM, H polarised only and works very good. A simple router has only 2-3 antennas of the same polarisation.
JorgeAmaral
Trainer
Trainer
Thu Mar 25, 2010 8:39 pm
If it works, yes, is it the better approach? no
The principle off spatial stream is different paths.
From intel website:
MIMO makes antennas work smarter by enabling them to combine data streams arriving from different paths and at different times to effectively increase receiver signal-capturing power. Smart antennas use spatial diversity technology, which puts surplus antennas to good use. If there are more antennas than spatial streams, as in a 2x3 (two transmitting, three receiving) antenna configuration, then the third antenna can add receiver diversity and increase range.
With same polarity, there is a big change of receiving signals with the same path, and you will not benefit of spatial stream.
Kindly regards,
Jorge Amaral
Muqatil
Trainer
Trainer
Thu Mar 25, 2010 11:50 pm
[OT] Jorge, can you contact me on skype? :) [/OT]
Renato Bernardi
skype: medtech5
taglio
Fri Mar 26, 2010 11:42 am
Ok, so it seems that is better use different pol. but we can use same polarity antennas [and we lost some benefits].
Internal laptop MIMO antennas use different pol. antennas?? Or simply use 1 chain?
Regards,
RG
.mhavoc world
JorgeAmaral
Trainer
Trainer
Fri Mar 26, 2010 9:38 pm
Of course ;)!!!
taglio
Mon Mar 29, 2010 11:46 am
PONG...
.mhavoc world
Users browsing this forum: No registered users and 20 guests
