MUM Europe 2020
ScottReed
UM 4.5 - User Search
Fri Mar 26, 2010 10:15 pm
Am I missing something? :?
Why can I not search by first / last name in User-Manager?
I've seen older posts on here about the functionality working - but I cannot figure it out.
Edit: And, that leads me to one other question: Why can you not choose which columns to display in the Users view?
Thanks,
ScottReed
Re: UM 4.5 - User Search
Wed Mar 31, 2010 11:55 pm
Please, anyone?
There must be away to modify the columns within User Manager when viewing/adding users.
Or, at a minimum, how can I dump a list of all the users with passwords in a clean CSV? Exporting from the terminal and then trying to delimit within Excel does not work well.
Thanks,
Scott
eneimi
Fri Apr 02, 2010 4:33 pm
As you can see in the attachment below all it takes is first selecting 'advanced search' from the tab list on the left and either changing the field with 'username' to 'first name' or 'last name'. Otherwise, you can add extra fields by clicking the plus sign.
Again, if you select 'settings' on the left, it allows you specify which columns are visible and which ones are not. You can modify this for routers, sessions, customers etc as well.
If you want to dump a list of users and their passwords, from terminal:
/tool userman user export file=umuser
Then check in your router file list for umuser.rsc, download to your computer and open with notepad or other editor of your choice.
ScottReed
Fri Apr 02, 2010 6:14 pm
What you've shown me is exactly what I want. I appreciate your time. But, I do not know where you are grabbing that screen shot from. My User Manager 4.5 looks completely different. :?
I access User Manager from http://router ip/userman/
Is there another frontend that I am unaware of?
Thanks,
Scott
eneimi
Fri Apr 02, 2010 9:46 pm
When you install routeros 4.x, it maintains the last stable version of UM which is 3.30.
To get UM 4.5 test you need to download from: http://forum.mikrotik.com/viewtopic.php ... 18&start=0
ScottReed
Fri Apr 02, 2010 9:54 pm
Bookmarked the link. Now this is starting to make sense!
Thank you very much for your help. I really appreciate it.
Scott
Users browsing this forum: No registered users and 1 guest
