heviejob
Using Radius manager 3.7 with 3 remote sites
Sun Apr 18, 2010 6:19 pm
I currently have one mikrotik router and a radius manager and all is ok. I want to add two remote sites and have clients at each so i will have 3 sites all with wireless backhauls to each from the internet gateway where I want to have a RB750 (at the gateway) and have pppoe and hotspot running on all backhaul links and have the radius manager on one remote site since i cannot have it at the gateway with the RB750.
My question is can the router authenticate against the radius manager at the remote site not having to be connected directly to the internet gateway?
Chupaka
Re: Using Radius manager 3.7 with 3 remote sites
Thu Apr 22, 2010 5:57 pm
if router has access to the radius (even via Internet) - it can authenticate
gabak
Thu Apr 22, 2010 8:49 pm
plz tell me how do i procede?
i have hardware to use if you need me to built a server or whatever it need to be done.
Chupaka
Thu Apr 22, 2010 11:49 pm
gabak
Fri Apr 23, 2010 6:09 am
i need a step by step , how can it be done!
Chupaka
Fri Apr 23, 2010 10:27 pm
what?.. what can be done?..
heviejob
Sat Apr 24, 2010 12:38 am
Thanks. That solves my problem.
