bigguns
Strnage PC received bytes are massively high
Thu Apr 22, 2010 10:16 pm
HI
For some reason my RB800 is sending a massive amount of packets to my computer (only one attached not doing anything other than idling (fresh windows install, no virus, malware etc).
Within a short period of time 2days for some reason my RB800 has sent over 436GBs of data (as can be seen on Eth3 (lan) interface using winbox.
Can anyone think why this would be happening? Also why are so many error packets occurring?
[img]New.jpg[/img]
bigguns
Re: Strnage PC received bytes are massively high
Mon May 10, 2010 8:23 pm
can anyone help with this issue. I really have no idea why so much traffic is occurring.
ditonet
Forum Veteran
Forum Veteran
Tue May 11, 2010 12:57 am
If ether3 is your LAN interface then your PC sent over 400GB to RB800.
So check your PC/Windows.
Regards, Grzegorz.
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
bigguns
Wed May 12, 2010 6:36 pm
HI there,
Thanks for your reply - yes eth3 is my LAN connection but this occurs only when connected to the rb800.
If I connect it to my other router, than this doesn't happen. So it must be something on the RB800
fewi
Wed May 12, 2010 6:38 pm
Install wireshark, capture the traffic and go from there.
bigguns
Thu May 13, 2010 11:32 am
I've actually upgraded the OS to 4.9 and this has fixed the issue no more packet spamming as before - So it must have been something on the RB800?
Users browsing this forum: No registered users and 36 guests
