MUM Europe 2020
Caci99
PPPoE dialing frequency
Sat Apr 24, 2010 2:48 pm
Is there any option to manage how often should the PPPoE interface
check for the connection?
I have experienced a situation where the input cable was removed from
the adsl modem, while it took nearly 2min for the PPPoE interface in mikrotik
to go down.
Thank you, Toni
-Toni-
Don't crash the ambulance, whatever you do
martini
Re: PPPoE dialing frequency
Sat Apr 24, 2010 2:54 pm
even if you unplugged cable, pppoe client try to connect, if you plug it again pppoe conect to the server
Caci99
Sat Apr 24, 2010 9:22 pm
I simulated a condition when the internet from ISP will go down.
So, I unplugged the adsl cable from the adsl modem, and it took
a long time before the pppoe interface went down too.
In cases when you use two adsl lines this is not good because
the backup line will take a while.
I was wandering if there is any option to establish on the pppoe client interface
to check about its connectivity with the server.
-Toni-
martini
Sat Apr 24, 2010 10:40 pm
PPPoE dont drop connection beacose it whait command from server, and after some timeouts it disconnects, you better use 'Netwatch' script , if you need to disconnect the session
Users browsing this forum: MSN [Bot] and 85 guests
