benmikrotik
system,error,critical login failure for user *** using ssh
Mon Apr 26, 2010 5:20 am
Hi, I am a newbie, and just installed mikrotik a few days ago. I have an urgent need to secure my network. The following error I see when I log in today using winbox:
apr/26/2010 17:18:32 system,error,critical login failure for user root from 218.
246.23.69 via ssh
apr/26/2010 17:18:37 system,error,critical login failure for user root from 218.
246.23.69 via ssh
apr/26/2010 17:18:42 system,error,critical login failure for user root from 218.
246.23.69 via ssh
apr/26/2010 17:18:47 system,error,critical login failure for user root from 218.
246.23.69 via ssh
apr/26/2010 17:18:52 system,error,critical login failure for user root from 218.
246.23.69 via ssh
apr/26/2010 17:18:57 system,error,critical login failure for user root from 218.
246.23.69 via ssh
apr/26/2010 17:19:02 system,error,critical login failure for user oracle from 21
8.246.23.69 via ssh
apr/26/2010 17:19:07 system,error,critical login failure for user test from 218.
246.23.69 via ssh
Ho do I make my network secure? Why is it that my DNS always change back to my ISP's? I want to use opendns but it always revert back to my ISP's DNS.
dssmiktik
Forum Veteran
Forum Veteran
Re: system,error,critical login failure for user *** using s
Mon Apr 26, 2010 8:58 am
246.23.69 via ssh
246.23.69 via ssh
246.23.69 via ssh
246.23.69 via ssh
246.23.69 via ssh
246.23.69 via ssh
8.246.23.69 via ssh
246.23.69 via ssh
Looks like someone is trying to connect to your router via ssh. Have a look at: http://wiki.mikrotik.com/wiki/Securing_ ... rOs_Router, the concepts will be the same for v3.x and v4.x
Disable "use peer dns" in your dhcp-client interface:
/ip dhcp-client set WAN use-peer-dns=no
Then set dns servers to OpenDNS dns servers:
RouterOS <= 4.5:
/ip dns set primary-dns="208.67.222.222"
/ip dns set secondary-dns="208.67.220.220"
RouterOS >= 4.6:
/ip dns set servers="208.67.222.222,208.67.220.220"
Users browsing this forum: carrykangur and 14 guests
