Solaris
RB450G Scrambled serial Text
Thu Apr 29, 2010 5:24 pm
I've got this problem on my first and ever new Mikrotik Router :),lovely 450G,but when i am connect with my Serial to USB,i've got scrambled text both on securecrt and putty :(,
SecureCRT settings :
Putty settings :
My Serial to USB devices driver shown and working correctly as this screenshot :
The Result :
‹¿“Ÿ¿eo¿;!!55!=¿—•Ÿqåëåëä}U¿35#9
-       åë~¿e5%!
¿-/-#¿›¿59!#7¿!¿5#5544y=RêºjŠúKª'¿3%¿#=#7£££4
                                             ¥•ë25-#1¿¿5'3¿-%=15£££¿XZy=%-#1¿!¿)5'¿9!75åëVQ-#1£££åëVQ-#1¿5-95£££åërRgbg+.ê+.j+.*-)W-)¿™£™ååëe-)W-)¿g!1-#‹¿
any help really appreciated.
normis
Re: RB450G Scrambled serial Text
Fri Apr 30, 2010 9:12 am
Does the router work, and can you connect with Winbox/SSH when it boots?
mag
Fri Apr 30, 2010 1:38 pm
i have seen things like that on older USB/serial-adapters, probably caused by the serial controller chip.
only solution i know is trying another adapter.
macgaiver
Fri Apr 30, 2010 3:25 pm
I would double-check what kind of serial cable you have - there are several types around:
http://www.lammertbies.nl/comm/cable/RS-232.html
but it looks like there are problems with proper baudrate - check other baudrates
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
Solaris
Fri Apr 30, 2010 3:35 pm
yes,i was tested the winbox and using the normal-files method to upgrade mikrotik,because of this seem causing some bad blocks(4) so i want to tried netinstall before RMA to my distributor.
yup after this morning i bought another more 'branded' cable,i've got a clear text :) ,thanks to everyone,cheers.
Users browsing this forum: Maxnnet, MSN [Bot] and 56 guests
