ciphercore
I cannot make a Supout.rif file ROS 5 b2
Wed May 05, 2010 2:48 am
I am running ROSv5 b2. I am unable to make a supout.rif file on my RB750G. I waited about 15mins and had nothing and could not cancel. Had basically 0 CPU usage. After the reboot I notice I am missing ~4MB of space, but no supout.rif. Tried again and no file, but this time disk space did not change. I even checked via FTP.
Anyone else have this ?
ciphercore
Re: I cannot make a Supout.rif file ROS 5 b2
Wed May 05, 2010 3:54 am
So I tried yet again via terminal.
/system> sup-output
I waited for 30 mins and it was going @ 100% CPU. I ended up stopping it. Should it take that long ?
duvi
Wed May 05, 2010 10:16 am
Same issue, RB532A.
I sent an e-mail to support.
normis
Wed May 05, 2010 10:21 am
try to make an export file, and see if there is a section that failed to export (there will be errors in the file)
duvi
Wed May 05, 2010 3:24 pm
I've made an export file, everything is readable, I see no errors in the file.
normis
Wed May 05, 2010 3:26 pm
Hm, you are right, my RB750G also doesn't make supout.rif file. Will investigate
ciphercore
Wed May 05, 2010 6:51 pm
@normis
I'm glad it wasn't just me. I had only made a supout.rif once before in ROS v4.6. Didn't recall it taking that long.
Also in winbox -> Files.
It seems it after the first failed .rif.. I lost ~4MB. (According to the status at the bottom of the Files submenu in Winbox).
Files shows 24.7 MB free. (at bottom of "Files") (Was showing ~28.9MB free before first attempt to make supout.rif)
System -> Stores shows 36.6 MB free
System Resources shows 36.6 MB Free
ciphercore
Wed Jun 16, 2010 11:47 pm
I do not see a reply to my last message. Are you aware of the "missing" file space after failed attempt to generate a supout.rif file ?
normis
Thu Jun 17, 2010 8:51 am
We have fixed the issue in beta3 which will be released this week
ciphercore
Thu Jun 17, 2010 3:25 pm
great news... thank you.
Users browsing this forum: No registered users and 96 guests
