randallr
Nstreme PTP links dropping since update to 4.xx
Thu May 06, 2010 6:38 pm
I've been trying to figure this one out for several weeks. Several PtP links that have always been stable will disconnect with "received deauth: class2 frame received (6)" They instantly reconnect.
Most of them have great link. Main one has a 97-100 ccq both rx/tx, 55-59 dbm both rx/tx. Very rarely flutuates.
Settings that it happens on:
v4.5
5ghz and 5ghz Turbo
default data rate
Adaptive Noise Immunity, both none and ap/client modes
AP bridge -> wds-station
Nstreme enabled
Disable CSMA both On and Off
Framer Policy- exact size
RB411ah and RB433ah
R5H and SR5 cards
It seems that this started after going from 3.xx to 4.5. Sometimes they will stay up for couple of days, but usually will do this at least once a day. I have client snr logging every 30 minutes, and don't see any signal decreases. I've logged in one minute later and it's perfect.
Any ideas will be welcomed!!!
Axiom
Re: Nstreme PTP links dropping since update to 4.xx
Thu May 06, 2010 9:14 pm
Search the forums for "hw retries".
In advanced change the default "4" to 10 or 15.
-Nelson-
randallr
Fri May 07, 2010 4:40 pm
Forgot to include that in my post. I raised the links in question to 10 several weeks ago. I'll raise it to 14 and see what that does.
Thanks,
Randall
Lakis
Forum Veteran
Forum Veteran
Fri May 07, 2010 10:18 pm
"hw retries" may help bot not 100%
I had same problem hire but today after upgrade from 4.6 to 4.9 seem problem disappeared
normis
Mon May 10, 2010 2:18 pm
in v4.9 we fixed an issue with wireless links that will help in many situations.
randallr
Tue May 25, 2010 4:53 pm
I moved several of the BH's to 4.9. The links would still drop at least once a day, often twice.
I downgraded one to 3.30, and it's dropped once in 6 days. Downgraded another 3 days ago, and it hasn't dropped yet.
Strange thing is that I have one that's not quite as good of signal, usually 85% - 90% ccq, and it is holding good with 4.5....
sonny
Wed May 26, 2010 10:50 am
Try to reset the wireless card on both sides and configure it new.
This helped in many situations.
Karl Sonnleitner
Senior Wireless-Expert
Restlesspowerbox - managed powersupply for Routerboards
Users browsing this forum: YaCy [Bot] and 38 guests
