ciphercore
Hotspot splashpage / captive portal without auth
Wed May 12, 2010 5:39 pm
I am looking to setup a free access hotspot. I need to have a "landing" page, that every user that connects to the hotspot will be re-directed to when accessing http. It will show info on who is providing the free access and so on.
I have setup a few other hotspots with mikrotik using the userman.
fewi
Re: Hotspot splashpage / captive portal without auth
Wed May 12, 2010 5:51 pm
That's much simpler than you think.
First, create a user profile and a local user that is linked to the profile. The below assumes a username of 'username' and a password of 'password'.
Then make the following login.html:
<html>
<head>
<meta http-equiv="refresh" content="0; url=login?username=username&password=password">
<meta http-equiv="pragma" content="no-cache">
<meta http-equiv="expires" content="-1">
</head>
<body>
</body>
</html>
That login.html is loaded for unauthorized users and usually has the login form, the above instead after 0 seconds causes an automatic redirect (HTTP code 302) to the login servlet of the Hotspot, passing on the correct user credentials and effectively logging the user in.
To cover all possible redirect conditions, create the following redirect.html and logout.html (they both get the same HTML) to in turn redirect to the above login.html:
<html>
<head>
<meta http-equiv="refresh" content="0; url=login.html">
</head>
<body>
</body>
</html>
After a successful login, alogin.html is loaded for the user. The below assumes that the page you want to show after login resides on an external server. If you want to host it on the router itself, just replace it with the HTML for the final landing screen.
<html>
<head>
<meta http-equiv="refresh" content="0; url=http://my.external.server.com/landingpage.html">
</head>
<body>
</body>
</html>
ciphercore
Wed May 12, 2010 6:15 pm
Awesome fewi. That should be pretty easy. I'm going to try it out right now.
someuser
Wed May 12, 2010 6:18 pm
Very clearly written fewi, U da man.
I've got same planned scenario as this guy
After struggling through a little html and UserMan... and now... I get it.
noob wanna be
ciphercore
Thu May 13, 2010 9:40 pm
fewi: This works great. Exactly what I was looking for.
I do have another quick question. I will be running a RB750G as the wifi access controller/captive portal. It comes with a L4 License.
Since I am not using userman/radius... this is not considered an "Active User Manager session" (20 in L4 ROS) ?, but falls under "Hotspot Active Users" (200 L4 ROS) ?
fewi
Thu May 13, 2010 9:51 pm
That is correct.
Edit: and while User Manager is essentially a RADIUS server, the license level for those sessions is specific to a local install of User Manager and not a general limitation on RADIUS authentication. Meaning that if you were to use a local User Manager you'd have a limit of 20 active sessions, but if you were to use an external RADIUS server (such as FreeRADIUS or even a second device with User Manager) you'd have a limit of 200 active sessions.
ciphercore
Thu May 13, 2010 10:04 pm
Hmmm... thanks for the extra info regarding external RADIUS. That may come in handy down the road for another project.
wispsupporttech
Wed May 19, 2010 10:53 pm
Thanks for this great information. I have been looking for a simple way to do this. I've implemented this as shown, but when I go to open up my browser (Chrome, Firefox, and IE), it brings up the following url:
http://192.168.4.1/login?username=user& ... d=password
(My user I created has the name user instead of username)
However, the page then starts refreshing over and over very quickly until I stop it. I'm guessing that it's not passing the information correctly to the servlet, but I don't know what I've done wrong. I copied and pasted the code directly and only changed the username variable. I'm just wondering if anyone else had this problem when implementing it.
Thanks.
fewi
Thu May 20, 2010 4:15 pm
Make sure you have HTTP PAP enabled on the Hotspot Server Profile (or ideally HTTPS), or change things to support CHAP. I don't use CHAP (I use HTTPS everywhere), so I have no experience with it.
wispsupporttech
Thu May 20, 2010 7:03 pm
Thanks a lot fewi!! Enabling PAP let me right on! :D
Coins
Wed May 26, 2010 9:44 pm
Hello Guys;
I have the same problem too. I need to implement my mikrotik to work with my AP which is presently working on Mac Filtering to authenticate clients through Aradial Radius server. I need to get the details from the scratch. This is the idea for the intended setup; The AP is configured to work on Mac Filtering and the clients needs to be authenticated through a login page before being routed to internet. i need your guide to setup a login page i can then modify to contain my logo. After setting up the login html , i also need a guide on how to load the Html file and setup the mikrotik to work effectively with it. Thanks
acidu
Wed Jun 02, 2010 6:47 am
That is correct.
hi, when refering to a secound device to use it as a radius server aka-user manager, that might be even another rb750 with L4 license, to get over that 20 active sesions?
thx
Adrian C.
fewi
Thu Jun 03, 2010 3:53 pm
RB750s come with an L4 license, which means 20 users.
franhirs
Wed Sep 25, 2013 6:35 pm
I have applied your method. It works on the first ime. Subsequent access does not go to the splash page and connects directly. Any clues ?
Feklar
Wed Sep 25, 2013 11:35 pm
Have the guests signed out first (if not try setting the idle timeout), or have you enabled login by cookies (if so, try disabling them)?
Maggiore81
Trainer
Trainer
Sat Feb 15, 2014 6:24 pm
Hello.
I have another idea:
instead than refreshing the page and auto-inserting the username/password combination, can we do a button that (as nodogsplash) clicking on it gives the MT the username/password combination?
So the user reads the page and clicks CONNECT (that login on the network).
Anyone has tested that?
Dott. Elia Spadoni
Network Administrator
MTCRE, MTCTCE, MTCINE, MTCWE, MTCSE, MikroTik Certified Trainer
Spadhausen Internet Provider
Ravenna, ITALY
https://www.spadhausen.com
Maggiore81
Trainer
Trainer
Thu Dec 04, 2014 9:12 am
up...
Dott. Elia Spadoni
Ravenna, ITALY
Feklar
Thu Dec 04, 2014 7:46 pm
Yes that works properly. We use that for many of the locations that we support with Hotspots since it removes the fat fingering of people connecting to the network.
Here is some of the HTML to get you started.
<input type="hidden" name="username" value="<NAME>" />
<input type="hidden" name="password" id="password" value="<Password>" />
<button type="submit" class="btn">Connect Now</button>
Maggiore81
Trainer
Trainer
Fri Jan 30, 2015 7:26 pm
It doesnt work!
I tried to use the button you provided but... maybe I set something wrong
Dott. Elia Spadoni
Ravenna, ITALY
Lordi
Sun Sep 20, 2015 6:23 pm
Hii there,
old thread but the button solutions is what i need now.
anynone have exsample code?
Tnx for helping
ALX1S
Tue Dec 29, 2015 4:40 pm
Hi, I made exactly what you told, but when I try to go to some page, start loading over and over again the page " head.log.net/login?username=username&password=password ".
Im running a rb433 with 6.32.2 and wondering to use with capsman (capsman is running with 3 ssid without any issue)
One of this SSID will be the hotspot (for guests)
Could you give me some advice, please.
Thanks.
<html>
<head>
</head>
<body>
</body>
</html>
<html>
<head>
</head>
<body>
</body>
</html>
<html>
<head>
</head>
<body>
</body>
</html>
Feklar
Wed Dec 30, 2015 10:12 pm
Do you have the external URL added to the walled garden of the hotspot?
ClaudioJunior10
Wed Jan 25, 2017 7:30 pm
Good afternoon Mikrotik
I made the hotspot confirmations in mikrotik and when I test in my notebook or computer the redirect works perfectly. The page that I set opens, but when I log in and connect through the mobile menu the page I defined as redirect does not open.
How can I solve this problem? I've read the documentation and did tests, but it still does not work.
I need this to work urgently.
Thank you
ErfanDL
Re: RE: Re: Hotspot splashpage / captive portal without auth
Wed Jan 25, 2017 7:47 pm
Thank you
Hi
test it in android or ios?
ClaudioJunior10
Thu Jan 26, 2017 4:45 am
Thank you
Hi
android my friend.
KNOW HOW TO HELP ME?
ErfanDL
Re: RE: Re: RE: Re: Hotspot splashpage / captive portal without auth
Thu Jan 26, 2017 12:26 pm
Thank you
Hi
android my friend.
Rename the hotspot dns name to hotspot.pt
ClaudioJunior10
Thu Jan 26, 2017 1:13 pm
Thank you
Hi
android my friend.
I'll do it, my friend. thanks for listening
ErfanDL
Re: RE: Re: RE: Re: RE: Re: Hotspot splashpage / captive portal without auth
Thu Jan 26, 2017 1:15 pm
Thank you
Hi
android my friend.
Your welcome. Is your problem solved?
ClaudioJunior10
Fri Jan 27, 2017 2:22 pm
Hi
android my friend.
Hello, unfortunately not
I configured my mikrotik as follows: I connected a LAN, a wired interface and a wireless one. Then I enabled a bridge by putting the wired and wireless interface. I have enabled DHCP Client and DHCP Server and NAT.
After that I enabled the hotspot by placing the bridge inside it, a default setting.
I edited login.html and alogin.html to redirect to a site initially as a test, but in the final project I want to redirect to a page I am developing on my local machine, in localhost.
The redirect of the hotspot on my computer works perfectly for both the web page and the page I am developing, but on my phone it opens the hotspot login, redirects, "loads and displays 2 seconds and returns to the wifi settings of the cell phone , Confirming that the network has been connected.
Any doubts I am available.
ClaudioJunior10
Sun Jan 29, 2017 2:16 am
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 24 guests
