MUM Europe 2020
rgpmikrotik
METAROUTER IN RB750 + OpenWRT + Asterisk
Thu May 20, 2010 3:52 pm
I wan´t to install openWRT in a RB750, it has 32mb of RAM and 64 mb of flash, is that possible?, I think 16mb for Mikrotik RouterOS and 16 MB for openWRT.
I would use the precompiled package of openWRT provided by Mikrotik for using with Metarouter, so, as I understood I don´t need patches. If I use this openWRT, is possible to install Asterisk via opkg? If that is possible, my flash of 64mb is enough for installing all that?
Thanks in advace
janisk
Re: METAROUTER IN RB750 + OpenWRT + Asterisk
Fri May 21, 2010 7:25 am
yes, that should be possible. Also notice, that you should remove everything that is not in use and use just few things on host OS, as 16MB of RAM is not good.
dormador
Thu Sep 02, 2010 5:13 am
THE BIG QESTION HOW !!!
i need this featur
i read then read after that also read .. at last i dont know where can i start !!!!
some tutorial for these gentleman
janisk
Thu Sep 02, 2010 4:12 pm
you have to check out OpenWRT forums on how to best handle OpenWRT install. As that is just one flavor of OpenWRT build.
Users browsing this forum: No registered users and 2 guests
