hotspotsolutions
how To "$" in terminal?
Mon Aug 22, 2005 4:13 pm
Hi Guys,
This might be a stupid question, but when I do the following I get an error:
/ip hotspot user add name="theUserName" password="pa$$word" limit-uptime=3600s profile=256 disabled=no
If I take out the dollar signs it works. If I do it via winbox it works fine again.
Is there a way to do it in terminal some how? Are there any other characters that cause it a problem?
cmit
Mon Aug 22, 2005 4:19 pm
Just escape the "$" with a backslash, so write
... password="pa\$\$word" ...
If you find another way to make $$$ by using the terminal, let me be part of your money-making machine :D
hotspotsolutions
Mon Aug 22, 2005 4:21 pm
hi,
thanks for that, I will update our scripting system. I knew it would be something simple!
Joshua
Users browsing this forum: atunguyd, hackprof, infex987, minix1402 and 6 guests
