normis
RouterOS v4.10 released
Mon May 31, 2010 12:03 pm
What's new in 4.10 (2010-May-28 13:59):
*) added support for ethernet switch configuration in WinBox;
*) allow to configure 11n wireless rate tx powers in WinBox;
*) dhcp server - show non-printable option 82 agent-circuit-id and
agent-remote-id values in hexadecimal notation also in winbox;
*) api - fixed '/ip/route/print', was not showing '.id' values;
*) console - fixed printing of OID values;
*) lcd - added support for AX89063
http://www.mikrotik.com/download/router ... 10.torrent
for all RB800, RB1000, RB1100 please UPGRADE THE BOOTLOADER. This is very important, as it fixes some random memory issues. New bootloaders are on http://www.routerboard.com or as usual - simply type "/system routerboard upgrade" with the new v4.10 installed
huntah
Re: RouterOS v4.10 released
Mon May 31, 2010 2:25 pm
Have you made any changes for MAC-Telnet?
In winbox it always losses focus on the telnet window (goes to another windows, for example log or interfaces...).
Tested on RB433 with Winbox.exe 2.2.16
Also I would like to know if there is any differences in BRIDGE interface (see my post http://forum.mikrotik.com/viewtopic.php?f=2&t=42053)
Now I can confirm it works ok on 3.30 and is broken on 4.9.
Huntah
normis
Mon May 31, 2010 2:28 pm
did you report this bug and get confirmation that it will be fixed in v4.10? please tell me the ticket number and I will check
Chupaka
Mon May 31, 2010 2:44 pm
yahooo! NetFlow v5 sequence_number is fixed! why didn't mention in changelog? =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
macgaiver
Mon May 31, 2010 2:47 pm
It probably was intended as surprise specially for you :)
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
huntah
Mon May 31, 2010 2:54 pm
Normis:
I will send the support email in coulo of hours just to check if it is fixed in 4.10..
Chupaka
Mon May 31, 2010 3:06 pm
I know people who want to switch from v3 to v4 right after NF sequence number will be fixed )) how should they get to know that if it's not mentioned in changelog? =)
also, as for NetFlow v9 - incorrect Data FlowSet Length (with some garbage padding) is fixed too. I hope NetFlow v9 sequence number will be fixed soon - it's still broken =)
sergejs
Mon May 31, 2010 3:09 pm
Nice to hear that Netflow5/Netflow9 are working better now.
Chupaka, please send report to support about sequence number in v9, we will see what we can do about it.
Chupaka
Mon May 31, 2010 3:28 pm
huh, I almost answered that Sergejs know about that broblem, and then I saw that it's you :D
personal thanks to you for v5 fix )) I'll write a bit later about v9...
mandrade
Mon May 31, 2010 3:46 pm
And the BIG BUG of wireless link instability involving NSTREAME+Bridge+V4.x ??? anyone tested??? finally sloved??? V4.x finally usable???
BR
martini
Mon May 31, 2010 4:37 pm
And many thanks for finally working netflow v5 from mee !! ))) :D
rmichael
Forum Veteran
Forum Veteran
Mon May 31, 2010 8:10 pm
BR
My tests show incremental improvement (nstreme;WDS;XR9;PtMP) 4.5->4.9 (no extensive pocket loss in logs;still requires to choose datarates)->4.10 (SNR signal weaker -by 3dB- for some reason but link seems stable and works- so far- with data rates set to default)
UPDATE:
I decided to revert back to 4.9 since I don't see immediate benefit in my tests and 3dB signal loss bothers me.
Lupin
Mon May 31, 2010 8:50 pm
any link with image/details examples?
marsark
Tue Jun 01, 2010 1:39 am
I looks like the IPv6 Router Advertisement on bridge bug has been fixed. Now running ROS 4.10 on RB433AH and it seems that RA packets are being sent as expected. So I let it more time.
wispwest
Tue Jun 01, 2010 1:50 am
Does this mean we can "manually" select the high-TX power rates on the SR71-15 cards? I heard that could damage it if you go higher than the defaulted rates....
marsark
Tue Jun 01, 2010 7:19 pm
IPv6 Router Advertisement is still broken in ROS 4.10. It worked only for a few hours. Than failed again.
Jun  1 08:19:40 r4bu110 radvd,debug: radvd: sending Router Advertisement on br0
Jun  1 08:22:06 r4bu110 radvd,debug: radvd: sending Router Advertisement on br0
Jun  1 08:26:44 r4bu110 radvd,debug: radvd: sending Router Advertisement on br0
Jun  1 08:30:00 r4bu110 system,info: device changed by admin
Jun  1 08:30:02 r4bu110 radvd,debug: radvd: sending Router Advertisement on br0
Jun  1 08:30:02 r4bu110 radvd,debug: radvd: adding link-layer address option, mac-address=10:10:10:3D:2B:F9
Jun  1 08:30:02 r4bu110 radvd,debug: radvd: adding prefix=2001:470:1f0b:127d::/64
Jun  1 08:30:02 r4bu110 radvd,debug: radvd: sendmsg failed on br0 (fe80::20b:6bff:fedd:3463): Invalid argument
Jun  1 08:33:45 r4bu110 radvd,debug: radvd: sending Router Advertisement on br0
Jun  1 08:37:51 r4bu110 radvd,debug: radvd: sending Router Advertisement on br0
At 8.30 wifi card has been enabled by scheduler. Log claims that RA has been sent, but it isn't true.
MikroTik guys, please again, fix it.
Update: RA stops to work when my ath0 device is enabled and part of the br0.
martini
Tue Jun 01, 2010 7:27 pm
when will be released v5 beta with netflow v5 fix ???
sergejs
Wed Jun 02, 2010 7:59 am
martini, the fix will be included to 5.0beta3, we are working on this version, there is no any specific date available.
janisk
Wed Jun 02, 2010 8:43 am
marsark are there any other interfaces and how many in that bridge?
marsark
Wed Jun 02, 2010 11:13 am
Hi janisk,
Configuration look like this br0 = ath0 + eth1 + eth2, where br0 is local LAN and eth0 is WAN interface. There is a NAT between LAN and WAN. ath0 is Wistron CM9 WiFi card which is disabled by scheduler script at 23.30 and enabled at 8.30.
I described this issue in more detail in this thread:
http://forum.mikrotik.com/viewtopic.php?f=2&t=38166
Any ideas? Thanks in advance.
mandrade
Wed Jun 02, 2010 1:23 pm
BR
UPDATE:
hhuummm good news... no more extensive data loss.... i will do same tests with PtP;Bridge;nstreme to see the results and see IF 4.x is finally usable and finally i can abandon the really stable version 3.30....
BR
Stanislav Hrncir
Wed Jun 02, 2010 4:57 pm
Getting temperature of RB-800 via snmp isnt working for me, system health print right values,but via snmp i can get only voltage value or fan, temperature value is still -2437
NetworkPro
Wed Jun 02, 2010 8:27 pm
AHAHAHAHHAHAHAHAHAHAHHA AHAHAHAHHAHAHAHA I AM LAUGHING REALLY REALLY OUT LOUD MATE !!! JHAHAHAHAH
I've got a tear in my eye :'')
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
Chupaka
Wed Jun 02, 2010 10:35 pm
yep, his humor sometimes kills me totally )) in good sense :D
bintang
Tue Jun 08, 2010 7:13 am
Whether ROS.4.10 already support Huawei EM660 (EVDO miniPCI-E) ??
sergejs
Tue Jun 08, 2010 9:13 am
I do not see the report or request from you, that this device should be supported at MikroTik RouterOS 4.10.
If you have this card in stock and want to see support for it in the next RouterOS version, contact us with attached support output file, which is generated when card is plugged in.
bintang
Tue Jun 08, 2010 4:27 pm
ok.
bintang
Tue Jun 08, 2010 4:34 pm
how about the ZTE Modem AC2726 ?, whether mikrotik already support it?
sergejs
Wed Jun 09, 2010 9:12 am
If the 3G card is not listed here,
http://wiki.mikrotik.com/wiki/Supported ... e#3G_cards
There is little chance that particular card is working.
However we may add support for the card, when you will be able to provide us with support output file/access to the router.
omidkosari
Trainer
Trainer
Thu Jun 10, 2010 10:12 am
RouterOS NTP server does not reply requests after some hours router running .
normis
Thu Jun 10, 2010 10:13 am
report to support with example and description how to reproduce please
ecliptixnet
Fri Jun 11, 2010 12:31 pm
I am a fairly new user of Mikrotik and have been using the extremely stable 3.3 version. I have been aware of the v4 series for a while and even knew of the 4.5 and 4.6 releases. In fact, all of my RB400s are now coming with 4.5 installed. Excuse my ignorance, but first...why are the 4.5 and 4.6 versions removed from MK's site, and second...what is all the hype about the 4.1 when there are 4.5s and 4.6s floating out there?
Also, is it honestly worth upgrading to the 4.1 from 3.3 when v5 is just around the corner? I guess it all depends on how much of 4.1's new features you would actually use and how long of a wait it will be until v5 is solidified.
thank you for your replies.
Jeff
NetworkPro
Fri Jun 11, 2010 2:28 pm
First of all, please go and drink a glass of cold water and open the window to let some fresh and cold air in. Version 3.3 - do you mean version 3.30 ? Because there is a huge difference from 3 to 30, OK ? And version 4.10 and 4.1 - which one do you realy mean? 10 is more than 1. In fact 1+9=10 :) OK? And 5 is less than 10, OK?
And to answer the question - if your system is working - leave it as it is - this is the IT best practice way. Of course you could check all the changelogs* up to the latest versions and you could see an addition and a fix to a feature that you are using, or you could see a new feature that you would like to use. Then you could upgrade. Carefully. If the unit you want to upgrade is far away from you and something happens to it mid-upgrade - it will be dead and you will have to go to recover it. So if that is the case - don't do it.
Usually I just upgrade (I mean update really) everything. It's my own best practice and I plan and I can take it if every one of the possible failures occur.
*Changelogs for RouterOS do not include all changes, but the major and important ones
normis
Fri Jun 11, 2010 2:31 pm
4.0
4.1
4.2
4.3
4.4
4.5
4.6
4.7
4.8
4.9
4.10
4.11
ecliptixnet
Fri Jun 11, 2010 7:51 pm
Thank you both! I guess I should be reading these in binary progression as opposed to decimal. :? I was taking it as 4.10 (.1) in decimal is actually less in value than 4.5 in decimal. It makes sense that it would mean version 4 - release 10; which in fact would be much higher than version 4 - release 5.
Thank you for laying it all out. Much appreciated.
I am using 3.30 most successfully; however, there are some very peculiar things happening with about 30% of them. It is an extensive data loss issue with subscirbers who have awesome signal levels, great Ack timeouts, and great CCQs. They are just randomly disconnected due to "extensive data loss." I have tried changing a lot of options on both the AP and CPE including using the NStreme with the all MK links...all with no success. This may/may not even be a MK issue as I am using XR2s, 5s, and 9s in my APs with NS2/5 & MK+XR9 CPEs. The troubleshooting continues... :?
On a side note...anyone have a coparison of MK R52Hn's capabilities to UB's new AirMax systems? Interested in finding advantages/disadvantages of both!
Thank you all again for your clarification.
Jeff
ojsa
Fri Jun 11, 2010 9:42 pm
I took the MTCWE course a couple of weeks ago and during som testing on "management protection key" we found a bug, since the client did not disconnect with required key. The instructor said that he would report, but my question are "is this fixed in 4.10 release"
Network professional - Certified MTCNA, MTCWE MTCTCE, MTCRE, MTCUME and MTCINE. - Wiki Profile
NetworkPro
Fri Jun 11, 2010 11:32 pm
ecliptixnet I think the differences are obvious.
And the disconnects - it could be hacker/or-just-someone-with-free-time activity, easily.
miq
Mon Jun 14, 2010 10:56 pm
Did are any chance to solve bug in nstreme in 4.10? I see a lot of post in this case, but any solutions from mikrotik team. I send post about it: http://forum.mikrotik.com/viewtopic.php?f=2&t=42495. Now i'm doing test without nstreme - link looks stable.
Ozelo
Tue Jun 15, 2010 2:28 pm
Can I turn off those resources of IP175D to make it equal to IP175C through this menu?
MTCRE - 1104RE006
MTCINE - 1104INE001
sergejs
Tue Jun 15, 2010 2:40 pm
It adds configuration switch for the Winbox, as previously you can apply configuration from console only.
Ports are not added to the switch by default, isn't it?
andresdrr
Wed Jun 16, 2010 3:31 am
What's new in 4.10...
¿Is this download legal? :D
My equipment has the 3.30 version ¿ Can I upgrade from 3.30 to 4.10 without paying?
Thank you very much!!! :D
normis
Wed Jun 16, 2010 8:56 am
Of course it's legal, this is the only legal MikroTik forum :D
NetworkPro
Wed Jun 16, 2010 11:06 am
If your current license is legit - yes. Follow the procedure and upgrade.
Normis, our forum is legal too. Its not an official MT forum but its kinda better - its an authority on "ISP" for Bulgaria.
Ozelo
Wed Jun 16, 2010 6:12 pm
I mean, to be able to use 65535B packet size. See http://forum.mikrotik.com/viewtopic.php?f=3&t=40743 The answer from support was that disabling the IP175D features would not bring any benefits other than be able to use 65535B packet size and I suggested to put it configurable somewhere via console/winbox. But I guess this release implementation does not sort this out.
MTCRE - 1104RE006
MTCINE - 1104INE001
frontiersteve
Wed Jun 16, 2010 9:51 pm
I would like to comment on this latest release. I have been fairly impressed with what 4.10 has done for my pair of 802.11n nstream ptp links. I also have recently deployed a 5GHz sector and am running v4.10 with 5 clients and counting with good quality, throughput etc.. On the other hand I have a tower with 3 2.4 sectors on three non overlapping 120 deg 20MHz channels and could not get stable connections/speeds/CCQs on even the very short range customers. Downgrading to 3.30 was the quick fix to this problem. I'm not sure what was causing this, but as this was a production environment I didn't have time to futz with it.
NetworkPro
Wed Jun 16, 2010 10:04 pm
Futz. I am not pleased to hear about bad news and problems. Futz futz :)
You should try (please do) again 4.10 with reset wireelss settings, and re-configured aonly the basic things like channel and SSID and whats needed for the clients to connect. From there, if results still are poor - try setting a manual distance/ack-timeout.
Don't give up on finding the truth. Do the tests at night if you have to.
sergejs
Thu Jun 17, 2010 11:56 am
Ozelo, no this feature is not implemented.
kirshteins
Thu Jun 17, 2010 12:13 pm
Unfortunately these features can only be disabled by hardware modification.
vanich
Fri Jun 18, 2010 12:43 pm
Hi
I just installed v4.10 to 411AH and 433 link - and finally I've got n-stream working at list accessible.
It was huge headache for me.
We will see what will happens at the evening when maximum users on-line, but hopefully it will works ))
makstex
Fri Jun 18, 2010 1:03 pm
v4.10 Indicates an incorrect voltage.
vanich
Fri Jun 18, 2010 8:59 pm
Just update:
n-stream douesnt work under load - to many losses. Ping OK, but not usefool in this case.
(I trying to use link between to routerboards with MPLS bridge, about 4 km, signal -60, ccq 95%)
In my experience – I didn’t ever have any success with Wi-Fi on mikrotik - link between two nanostations works more stable and more productive.
NetworkPro
Fri Jun 18, 2010 10:45 pm
Maybe you should replace something. It's an ongoing game to find the deffective part of the system. Replace a cable. Replace a pigtail. Replace a card. Replace a RouterBOARD, Replace a PC, change the frequency, change a setting, change the roof, replace the people, change the businnes, replace your head amd put on an upgraded one that has always been using nstreme as stable as 100%.
mishaM
Fri Jun 18, 2010 11:20 pm
when i set link mode to n , frequency is jumped on different sides and i can't use more that 2 n links on 1 ap , (i see jump's on frequency spectral analizer )
NetworkPro
Fri Jun 18, 2010 11:24 pm
Sooo you have a stragne problem huh :) How about some screenshots of that spectral tool and an export of /interface wireless :)
vanich
Fri Jun 18, 2010 11:28 pm
I’ve got very nice respond from NetworkPro, but it Friday night and this sound to me like joke.
I can add some details: We have 3 routerboard 433AH (with superchannel licence) and 2 routerboard 411AH.
We try 4 different places with different topography.
Currently we using one 433AH with 2 sector antennas (120*) just like access point and it just working.
We have another 6 places where we try to do same, but simple nanostation2 give us stable 8mb for access point.
At this moment main our main target is create link for remote networks. We have license for some frequencies and we unable to use 5gz (only 2.4). I create WDS and MPLS links but unfortunate I can’t get it stable yet.
My boss an about to give up from using mikrotik for this purpose, but I try to make it work.
Also we try 3 different brands of wifi cards. 2 times we losing cards at one of our access point, but our technical guy restore it, any way we use nanostation at that place.
So, now I have 5 (same) wifi cards and 4 mikrotiks and just can’t create stable link with n-stream.
If anyone ever had some troubles I will be very appreciated for any advice.
Can anyone tell wich wifi card better to use for n-stream?
NetworkPro
Fri Jun 18, 2010 11:47 pm
CM9 :P
But the problems are for point to multipoint or for point to point ? :) Usually when someone would have a problem would post a thread with his question, giving complete detail about what the situation is :) So anyone could have a chance to respond directly in that thread :)
For point to multipoint, all devices must be nstreme enabled (mikrotik) to gain benefits.
Why use WDS and MPLS ontop of WDS. While you're at it why don't you add a VLAN, an IPIP tunnel, a EoIP tunnel ontop of that, a PPPoE inside that, an IPSec inside that and an PPTP inside that one. He he :)
I just use routing. Layer 3.
vanich
Sat Jun 19, 2010 10:01 am
I try to create point to point link.
I didn’t use WDS+MPLS! I was trying WDS before, but now I create MPLS bridge.
Something like this:
http://wiki.mikrotik.com/wiki/Transpare ... using_MPLS
And actually point to point link is working.
The problems begin when hi load traffic running.
Ping is ok, 1-5 ms, but as soon as more traffic start running packets start dropping (ping around 100-200ms) and wifi card disappearing and running up again – causing disaster ))
And I try it on different mikrotiks and on 5 wifi cards.
If I disable n-stream packets didn’t drop at all but actually speed around 6mb.
(Just in case: I’m using fixed rate 54/54, fixed scan list, manual tx power and CSMA is disabled)
NetworkPro
Sat Jun 19, 2010 10:48 am
Why disable CSMA?
I usually din't need to use a fixed rate.
Of course I lower the tx power every time.
Some wifi cards work better when used with a x86 router. Some second hand PC. I think its because of the more power they can draw through the motherboard of the PC and the PSU.
But if the wifi card itself disappears - surely this is a hardware problem.
chvdr
Mon Jun 21, 2010 5:41 pm
we had several times "self disappeared card". every time hardware problem was "broken card" - problem.
Best regards,
C. G.
If nothing to say, do not say anything...
All thoughts that have huge effect actually are simple...
tanjil
Tue Jun 22, 2010 12:37 am
Some new features should be add like Disk qouta management .. Download Usage Limit Upload usage limit.....
Different Menu for traffic http p2p and other bw shaping system .. Auto Timer Blocking System :) is it is possible.. we would be glad!
xezen
Long time Member
Long time Member
Thu Jun 24, 2010 3:45 pm
found a bug in this version
or maybe a tying error
rb411
If i dont No Ask someone That Does!
chronos
Thu Jun 24, 2010 9:51 pm
You have only 4177 V? What is this against 43859 V!! :) It's not safe to touch to these devices under power... :)
mandrade
Sat Jun 26, 2010 3:53 pm
BR
YYYYEEEEEEESSSSSSSSSSS!!!!!!! After 2 weeks of tests in 4 different links without any workaround in config, the BIG BUG involving NSTREAME+Bridge+V4.x appars to be FINALLY Sloved. In other words the version 4.10 is finally usable to me and a lot of users around the world.... :D :D :D :D
BR
vanich
Wed Jul 07, 2010 5:00 pm
Hi all
I've got solved nstream issues:
I've had lost packets between two links when to many users was on-line.
I changed wifi cards, a lot work with settings, changed os to 5.3 beta - but it doesn't help me 100% (I mean I've got positive but packets was still missing)
After a week I have notice a key to my problem:
(I hope it helps other people)
I have locked data rate to 54mb and wifi card to G-only mode, so when CCQ was low station just
disappeared and of course lost packets.
After I change wifi card to mode B/G and add 11mb to data rates - packets stop vanished!
Also I add 18mb to data rates, but it very individual - I still play with it.
Unfortunately ping now too high (50-300) When AP and station talks at 54mb - ping are 1-15ms but when data rate drops to 11Mb ping increase (( .
I think I have to sort out why CCQ drops and after that I will have nstream 100% works!
ps. Is anyone noticed problems with superchannel on 5.3 beta?
pps. Sorry for my broken English
Users browsing this forum: sirbryan and 106 guests
