That worked - once I had sorted out some quick VRRP to ensure that the nexthop wasn't a specific routers' IPv6 address; no point in doing BGP if it can't failover to an alternative route!try setting the next hop or gateway using routing filters to override whats coming in.
Reverting back to previous config; I get the following:please print one of the IPv6 unresolved routes.
[admin@tcw-gw1.man.spilsby.net.uk] > /ipv6 route print where dst-address is 2a01:568:3000::/64
C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
# DST-ADDRESS GATEWAY DISTANCE
[admin@tcw-gw1.man.spilsby.net.uk] > /ipv6 route print where dst-address is "2a01:568:3000::/64"
[admin@tcw-gw1.man.spilsby.net.uk] > /ping 2a01:568:fff:f003:20c:42ff:fe43:739c
2a01:568:fff:f003:20c:42ff:fe43:739c 64 byte ping: ttl=63 time=8 ms
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 8/8.0/8 ms
[admin@tcw-gw1.man.spilsby.net.uk] > /tool traceroute 2a01:568:fff:f003:20c:42ff:fe43:739c
ADDRESS STATUS
1 2a01:568:fff:f001:20c:42ff:fe20:7ee4 1ms 1ms 1ms
2 2a01:568:fff:f003:20c:42ff:fe43:739c 9ms 9ms 9ms
[admin@tcw-gw1.man.spilsby.net.uk] > /routing bgp peer export
<snip countless other IPv4/IPv6 peers>
add address-families=ipv6 as-override=no comment="" default-originate=never \
disabled=no hold-time=3m in-filter=spilsby-tcw-ipv6-multihop-ibgp-in \
instance=default interface=ether1 multihop=yes name=hex-ipv6-int-gw1 \
nexthop-choice=force-self out-filter="" passive=no remote-address=\
2a01:568:fff:f003:20c:42ff:fe43:739c remote-as=43950 remove-private-as=no \
route-reflect=no tcp-md5-key="" ttl=default use-bfd=no
Replying to my own post...Once I had sorted out some quick VRRP to ensure that the nexthop wasn't a specific routers' IPv6 address; no point in doing BGP if it can't failover to an alternative route!
35 Db dst-address=2001:db8::/32 gateway=fc00::2
gateway-status=fc00::2 unreachable distance=200 scope=40
target-scope=30 bgp-as-path="65000" bgp-local-pref=100 bgp-origin=igp
received-from=ibgp_router2
32 ADo dst-address=fc00::2/128 gateway=fe80::a61:702%sit4-vr1
gateway-status=fe80::a61:702%sit4-vr1 reachable distance=110 scope=20
target-scope=10 ospf-metric=10
You may also write an e-Mail to MT Support about this issue.I also am having big troubles with RouterOS and iBGP with IPv6 due to this issue. Please Mikrotik, consider fixing it!
I already mailed them a couple of months ago, when I replaced some cisco backbone infrastructure with CCR routers (~ 25 CCR). They answered that it will be fixed in the future.You may also write an e-Mail to MT Support about this issue.I also am having big troubles with RouterOS and iBGP with IPv6 due to this issue. Please Mikrotik, consider fixing it!
You do not have problem discussed in this topic. Recursive lookup doesn't work only when nexthop is link-local. You had global nexthops.Still occurs with 6.5rc1. I emailed support@ and was told that I simply need to tweak my scope and target-scope values. Not sure what I'm supposed to do in that regard.
0 Db dst-address=2001:470:1f10:9a7::/64 gateway=2001:470:c334::b
gateway-status=2001:470:c334::b unreachable distance=200 scope=40 target-scope=30
bgp-local-pref=100 bgp-origin=igp received-from=fhl-r3
1 ADC dst-address=2001:470:c334::9/128 gateway=loopback gateway-status=loopback reachable
distance=0 scope=10
2 ADo dst-address=2001:470:c334::a/128 gateway=fe80::20c:42ff:feff:5c7d%ether5
gateway-status=fe80::20c:42ff:feff:5c7d%ether5 reachable distance=110 scope=20
target-scope=10 ospf-metric=20
3 ADo dst-address=2001:470:c334::b/128 gateway=fe80::d6ca:6dff:fe35:d345%ether1
gateway-status=fe80::d6ca:6dff:fe35:d345%ether1 reachable distance=110 scope=20
4 ADo dst-address=2001:470:c334::13/128 gateway=fe80::20c:42ff:feff:5c7d%ether5
target-scope=10 ospf-metric=30
5 ADC dst-address=2001:470:c334:1::/64 gateway=ether1 gateway-status=ether1 reachable distance=0
scope=10
6 ADC dst-address=2001:470:c334:4::/64 gateway=ether5 gateway-status=ether5 reachable distance=0
scope=10
7 ADo dst-address=2001:470:c334:6::/64 gateway=fe80::20c:42ff:feff:5c7d%ether5
8 ADo dst-address=2001:470:c334:7::/64 gateway=fe80::20c:42ff:feff:5c7d%ether5
9 ADo dst-address=2001:470:c334:b::/64 gateway=fe80::d6ca:6dff:fe73:25ce%ether2
gateway-status=fe80::d6ca:6dff:fe73:25ce%ether2 reachable distance=110 scope=20
10 ADC dst-address=2001:470:c334:c::/64 gateway=ether2 gateway-status=ether2 reachable distance=0
scope=10
Any idea if this bug has been resolved ?Same here. We'd like to have full IPv6 support in 2014. We might have to abandon our mikrotik gear and buy something else.
And here we are... Deploying IPv6 using static routes... Who would have thought?!This is becoming an increasingly serious problem.
+1I'm running out of IPv4 addresses.Hope this will get fixed soon.
Good to hear Maris.This feature most likely will be implemented in version 7.
Will be fixed also in v7.Will the (related) OSPFv3 /128/LA-Bit bug also be fixed?
Obvious question..Will be fixed also in v7.Will the (related) OSPFv3 /128/LA-Bit bug also be fixed?
thanks for the laughtAnd here we are... Deploying IPv6 using static routes... Who would have thought?!
Yes. sadly, static routes, sometimes multiple ones with check-gateway with differing metrics to hopefully capture the most likely failure scenarios. But alas, when there is a hiccup somewhere, most of our routeros devices in the affected part of the topology just drop off the network (on IPv6) until the situation is resolved (alternatively someone could go manually update the static routes).Can someone explain the LA-bit bug briefly? Is it related to ospfv3 not importing LSAs with the LA-bit set?? i.e. /128 loopbacks from other vendors?
If so, what are you doing in the meantime? /127s or redistributing connected?
Great question... ping timeout!Obvious question..Will be fixed also in v7.Will the (related) OSPFv3 /128/LA-Bit bug also be fixed?When can we expect v7 ?
haha classic MikrotikWhen its ready
Is there any news about a fix for V6.x or about the new V7? My network is screaming in pain!
I keep expecting to see this every time there's a new MUM....RouterOS v7 #thelongwait
Maybe we'll get lucky and it will be Dallas in a month and a halfI keep expecting to see this every time there's a new MUM....RouterOS v7 #thelongwait
There's so much that's been promised in ROSv7.
What we are asking is not an exotic feature, it's basic IPv6 functionality...It is no trivial task developing a new routing engine, adding major new features and testing all the corner cases, all the while maintaining the existing code base and back porting drivers so you can release new hardware.
Monkey's statement was directed at the comments on here hoping that ROSv7 should come out soon, and how long it's been said by Mikrotik that "such-and-such a feature will be in next version of ROS" What he was referring to is the fact that they're apparently re-writing the routing engine for ROSv7....What we are asking is not an exotic feature, it's basic IPv6 functionality...It is no trivial task developing a new routing engine, adding major new features and testing all the corner cases, all the while maintaining the existing code base and back porting drivers so you can release new hardware.
[admin@tested] > /routing/route/print
Flags: D - dynamic, X - disabled, I - inactive, A - active,
C - connect, S - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, Y - synthetic, T - terminal,
> - best, ' - candidate, U - updated, F - filtered
DST-ADDRESS GATEWAY DISTANCE SCOPE TARGET-SCOPE IMMEDIATE-GW
AS >' 0.0.0.0/0 10.5.130.1 1 30 10 10.5.130.1%ether1
DAC >' 10.5.130.0/24 ether1 0 10 ether1
AS >' ;;; router-test
2001:2001::/64 fe80::29:dfff:f... 1 15 10 fe80::29:dfff:fe2b:14d0%ether2
2001:2002::/64 2001:2001::1 1 30 15 fe80::29:dfff:fe2b:14d0%ether2
ooops.. looks like CLI will change a lot?v7 Teaser alert, recursive ipv6 works
Code: Select all[admin@tested] > /routing/route/print
and the very first v7 bug reportCode: Select allC - connect, S - static, r - rip, b - bgp, o - ospf
Code: Select all[admin@tested] > /routing/route/print Flags: D - dynamic, X - disabled, I - inactive, A - active, C - connect, S - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, Y - synthetic, T - terminal, > - best, ' - candidate, U - updated, F - filtered DST-ADDRESS GATEWAY DISTANCE SCOPE TARGET-SCOPE IMMEDIATE-GW AS >' 0.0.0.0/0 10.5.130.1 1 30 10 10.5.130.1%ether1 DAC >' 10.5.130.0/24 ether1 0 10 ether1 AS >' ;;; router-test 2001:2001::/64 fe80::29:dfff:f... 1 15 10 fe80::29:dfff:fe2b:14d0%ether2 AS >' ;;; router-test 2001:2002::/64 2001:2001::1 1 30 15 fe80::29:dfff:fe2b:14d0%ether2
I noticed that too - if the command syntax requires slashes now, that's a huge change that will require everyone to modify their scripts and so forth. Hopefully they're going to go through a deprecation period where older syntax is still supported but gives deprecation warnings if you use it in an interactive shell, or something like that. I don't personally use scripts much, but many do. I wonder how that's going to unfold.Wonderful news. Hope we can play with it very soon.
Now there is another question that bugs my mind: if the CLI syntax is new, I will have to refactor all the automated software (and it is complex!): Is it possible to access to an early documentation or have an early version to install on a lab box so we can start working on the management software and have it ready for when v7 will be released???
Well that's good because my brain can't digest yet another CLI syntax without imploding. On a daily basis, I'm already juggling Cisco [IOS, NX-OS, ASA and Wireless Controller], Juniper, HP, Dell, ZyXEL, AdTran, IBM, Lenovo, etc...as well as MikroTik.Mikrotik have used this different CLI syntax in previous early test releases for new systems.
I don't think what is shown above will be in the final release.
Thanks for the confirmation Maris.Old menu without slashes will be available, so scripts will not break.
What you perhaps don't know, and can't live with... If Loopback0 (in your example) is in a VRF for IPv4, IPv6 won't work completely. The connected route never becomes active, and OSPF never injects the route - ANOTHER MT bug...OSPFv3 and Loopback-bridge-interfaces with /128 IPv6 addresses assigned in RouterOS will only be shown reachable if one sets an admin-mac to the bridge (named eg Loopback0).
well, that's not 100% intuitive, but I guess that's something I can live with.
ahem, the nexthop delivered by RRs was not implying the nexthop in fact is the RR, in fact the nexthop is usually the IP set by "next-hop self" (or similar) by BGP-routers talking to the RRs, but as long as those next-hop IPs are delivered via ospf (which is pretty common imho) routes are not getting active, therefore static routes to those IPs set by BGP-routers as "next hop" are the only workaround I'm aware of, but I'd be happy to hear any other solution.Hi. RR's need not to be in data path (most often aren't) so please consider your own setup before fiddeling with above statement.
"Nexthop self" in an bgp environment is an abomination. I agree that it has some good corner cases but a good setup IGP for distributing nexthops (ie: ospf with loopbacks) and a non nexthop modifying ebgp and ibgp. Depending on number of routers you have fullmesh ibgp is fast responsive but explodes in management if you are constantly growing. This is where clustered RR's is a must to keep peering sessions manageable. It's in this space I just claimed that a RR is most of the time not in the packets Datapath and it need/should not to be it should only RR your network.ahem, the nexthop delivered by RRs was not implying the nexthop in fact is the RR, in fact the nexthop is usually the IP set by "next-hop self" (or similar) by BGP-routers talking to the RRs, but as long as those next-hop IPs are delivered via ospf (which is pretty common imho) routes are not getting active, therefore static routes to those IPs set by BGP-routers as "next hop" are the only workaround I'm aware of, but I'd be happy to hear any other solution.Hi. RR's need not to be in data path (most often aren't) so please consider your own setup before fiddeling with above statement.
Regards
hk
It should not be needed - agreed, but real world teaches us:"Nexthop self" in an bgp environment is an abomination.
Let me recap, and please correct me if I'm wrong.Hi
The only workaround we have seen so far for iBGP IPv6 routes to get active is to add a static ipv6 route for the loopback IP for the next-hop delivered through the route-reflectors.
(again tested with RouterOS 6.40.2)
hk
I'm in the same boat. Can't use MT in my core / borders. MT is definitely not aware of the actual seriousness of this issue, especially on larger networks.I gave up on mikrotik when we moved to a dual stack network because of this bug. You can find new Juniper SRX routers pretty cheaply if you look hard. Don’t pay more than 25% of the list cost, though.
Depends on your use case. I like FRR and talk to a number of the developers at FRR on a regular basis. However, it's still software that's go to go on bare metal or a VM and there are a number of operational challenges with that if you're doing something outside of BGP Full table or RR.@IPANetEngineer If it would be important for them, they would have fixed this issue years ago.
Just proceed with FRRoutingIt's better anyways.
add name=bridge-ipv6-mpls protocol-mode=none
add name=lo
set [ find default-name=ether2 ] mtu=2026
/routing bgp instance
set default redistribute-connected=yes redistribute-static=yes router-id=10.0.0.1
/routing ospf instance
set [ find default=yes ] distribute-default=if-installed-as-type-1 router-id=10.0.0.1
/interface vpls bgp-vpls
add bridge=bridge-ipv6-mpls bridge-horizon=1 export-route-targets=1:1 import-route-targets=1:1 name=bgp-vpls1 route-distinguisher=1:1
add address=10.0.0.1 interface=lo
add address=172.16.254.5/30 interface=ether2
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
/ipv6 address
add address=2001:db8::1/128 advertise=no interface=lo
add address=2001:db8:1000::1/48 advertise=no interface=ether1
add address=2001:db8::1 advertise=no interface=bridge-ipv6-mpls
/mpls interface
set [ find default=yes ] mpls-mtu=1992
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.1 transport-address=10.0.0.1
/mpls ldp interface
add hello-interval=1s hold-time=10s interface=ether2
/mpls local-bindings
add label=impl-null
/routing bgp peer
add address-families=ip,ipv6,l2vpn in-filter=bgp-in multihop=yes name=RR1 nexthop-choice=force-self remote-address=10.0.0.6 remote-as=65530 ttl=default update-source=lo
/routing ospf interface
add authentication=md5 authentication-key=PHi02OnUPN1gzENt dead-interval=10s hello-interval=1s interface=ether2 network-type=point-to-point
/routing ospf network
add area=backbone network=10.0.0.1/32
add area=backbone network=172.16.254.4/30
/system identity
set name=R1
add name=lo
set [ find default-name=ether1 ] mtu=2026
set [ find default=yes ] router-id=10.0.0.2
add address=10.0.0.2 interface=lo
add address=172.16.254.9/30 interface=ether1
add address=172.16.254.6/30 interface=ether2
set servers=1.1.1.1,1.0.0.1
/mpls interface
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.2 transport-address=10.0.0.2
/mpls ldp interface
add hello-interval=1s hold-time=10s interface=ether1
add authentication=md5 authentication-key=3r5MTWTfAD4dDMeH dead-interval=10s hello-interval=1s interface=ether1 network-type=point-to-point
add area=backbone network=10.0.0.2/32
add area=backbone network=172.16.254.8/30
/system identity
set name=R2
add name=lo
set [ find default-name=ether3 ] mtu=2026
set [ find default=yes ] router-id=10.0.0.3
add address=10.0.0.3 interface=lo
add address=172.16.254.13/30 interface=ether2
add address=172.16.254.10/30 interface=ether1
add address=172.16.254.21/30 interface=ether3
/mpls interface
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.3 transport-address=10.0.0.3
/mpls ldp interface
add hello-interval=1s hold-time=10s interface=ether3
add authentication=md5 authentication-key=ZxOnGXB2ZLsCr0dJ dead-interval=10s hello-interval=1s interface=ether2 network-type=point-to-point
add authentication=md5 authentication-key=5bnwqgfAomwbU9B3 dead-interval=10s hello-interval=1s interface=ether3 network-type=point-to-point
add area=backbone network=10.0.0.3/32
add area=backbone network=172.16.254.12/30
add area=backbone network=172.16.254.20/30
/system identity
set name=R3
add name=lo
set [ find default=yes ] router-id=10.0.0.4
add address=10.0.0.4 interface=lo
add address=172.16.254.17/30 interface=ether2
add address=172.16.254.14/30 interface=ether1
/mpls interface
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.4 transport-address=10.0.0.4
/mpls ldp interface
add authentication=md5 authentication-key=ZxOnGXB2ZLsCr0dJ dead-interval=10s hello-interval=1s interface=ether1 network-type=point-to-point
add authentication=md5 authentication-key=A54RUkZukh3lDRBb dead-interval=10s hello-interval=1s interface=ether2 network-type=point-to-point
add area=backbone network=10.0.0.4/32
add area=backbone network=172.16.254.16/30
/system identity
set name=R4
add name=lo
add name=DHCP ranges=192.168.248.50-192.168.248.199
add address-pool=DHCP disabled=no interface=ether1 lease-time=12h name=ether1
set default redistribute-connected=yes redistribute-static=yes router-id=10.0.0.5
set [ find default=yes ] router-id=10.0.0.5
add bridge=bridge-ipv6-mpls bridge-horizon=1 export-route-targets=1:1 import-route-targets=1:1 name=bgp-vpls1 route-distinguisher=1:1 site-id=5
add address=10.0.0.5 interface=lo
add address=172.16.254.18/30 interface=ether2
add address=192.168.248.1/24 interface=ether1
add address=192.168.248.0/24 gateway=192.168.248.1
/ipv6 address
add address=2001:db8::5/128 advertise=no interface=lo
add address=2001:db8:5000::1/48 advertise=no interface=ether1
add address=2001:db8::5 advertise=no interface=bridge-ipv6-mpls
/mpls interface
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.5 transport-address=10.0.0.5
/mpls ldp interface
/routing bgp peer
add area=backbone network=10.0.0.5/32
/system identity
set name=R5
add name=lo
set default redistribute-connected=yes redistribute-static=yes router-id=10.0.0.6
set [ find default=yes ] router-id=10.0.0.6
add bridge=bridge-ipv6-mpls bridge-horizon=1 export-route-targets=1:1 import-route-targets=1:1 name=bgp-vpls1 route-distinguisher=1:1 site-id=6
add address=10.0.0.6 interface=lo
add address=172.16.254.22/30 interface=ether1
/ipv6 address
add address=2001:db8::6/128 advertise=no interface=lo
add address=2001:db8::6 advertise=no interface=bridge-ipv6-mpls
/mpls interface
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.6 transport-address=10.0.0.6
/mpls ldp interface
/routing bgp peer
add address-families=ip,ipv6,l2vpn in-filter=bgp-in multihop=yes name=R1 remote-address=10.0.0.1 remote-as=65530 route-reflect=yes ttl=default
add address-families=ip,ipv6,l2vpn in-filter=bgp-in multihop=yes name=R5 remote-address=10.0.0.5 remote-as=65530 route-reflect=yes ttl=default
add authentication=md5 authentication-key=5bnwqgfAomwbU9B3 dead-interval=10s hello-interval=1s interface=ether1 network-type=point-to-point
add area=backbone network=10.0.0.6/32
/system identity
set name=RR1
I'm guessing that might be the cause of your issue. Use different IPs with a /64 subnet for the VPLS bridge interfaces than you are using for the loopback. I expect the ping above would then work.We then assigned IPv6 /128 loopback IPs and assigned the same IP with a /64 subnet to the VPLS bridge interfaces.
I'm guessing that might be the cause of your issue. Use different IPs with a /64 subnet for the VPLS bridge interfaces than you are using for the loopback.We then assigned IPv6 /128 loopback IPs and assigned the same IP with a /64 subnet to the VPLS bridge interfaces.
I did not miss this, I can see quite well that the gateways are reachable. We offer IPv6 over VPLS tunnels and it works quite well. But given the routing tables you have shown, there is no other reason I can see (short of a bug) why the ping would fail. I expect that the duplication of IPs from the loopback to the VPLS bridge interface is not impacting the direct ping, but may be preventing the recursive routing from functioning properly. For instance, your routing tables show that the nexthop for 2001:db8::1 is 2001:db8::1, the nexthop for 2001:db8::5 is 2001:db8::5, and the nexthop for 2001:db8::6 is 2001:db8::6. This would seem to me to create a loop that can not be recovered from, hence not being reachable when it comes to recursive routing, but reachable when it comes to a direct ping response.The point is to get IPv6 ingressing at a PE switched across P routers using MPLS. You also missed the fact that I can ping R5's IPv6 loopback from R1 and vice versa, so the gateways are reachable.
/routing filter add chain=bgp-in address-family=ipv6 prefix=2001:db8::/64 prefix-length=64-128 action=discard
/routing filter add chain=bgp-out address-family=ipv6 prefix=2001:db8::/64 prefix-length=64-128 action=discard
/routing bgp peer set [ find ] in-filter=bgp-in out-filter=bgp-out
Again, what I see here as a common link is that you are assigning the same IPv6 address to the loopback interface as a /128 as you are to the VPLS interface (/64). I strongly suspect that this is the cause of your issues.IPv6 appears extremely unreliable in the GNS3 virtual lab I put together. The following initially only worked in one direction (R1 -> R5) until I restarted R5, after which it worked in both.
/ipv6 address set [ find interface=bridge-ipv6-mpls ] advertise=yes
Strange - advertise=yes shouldn't make a difference, you should not need router advertisements for this to work. They must be somehow working around an underlying issue.The environment does now appear to be working consistently, the problem was due to IPv6 addresses associated with the VPLS bridge interfaces having been set as 'advertise=no'. 2nd amendment to the lab environment:
R1 + R5 + RR1:Code: Select all/ipv6 address set [ find interface=bridge-ipv6-mpls ] advertise=yes
I didn't quite say that. I said we offer IPv6 over VPLS tunnels, but there is no BGP involved in the way we provision services - we bridge the customer at one end to a VPLS tunnel, and the other end of the tunnel has their gateway IP bound. We do L2VPN, not L3VPN.You mention having numerous production networks doing just this, I have no production experience and would appreciate it if you would be so kind as to share your knowledge in this regard.
/interface bridge set [ find name=bridge-ipv6-mpls ] auto-mac=no admin-mac=00:14:F2:00:00:01
/interface bridge set [ find name=bridge-ipv6-mpls ] auto-mac=no admin-mac=00:14:F2:00:00:05
/interface bridge set [ find name=bridge-ipv6-mpls ] auto-mac=no admin-mac=00:14:F2:00:00:06
Yes, I have seen issues like this as well. In cases where a port leaves a bridge with auto-mac and rejoins, the link local shown in IPv6->Addresses doesn't always match the link-local that the router responds on, which leads to all kinds of other issues. Setting an admin MAC is the safest workaround.As you state the advertise option is not needed and was most probably only effecting a change by it flapping the IPv6 address when applying the change. Problem resurfaces if the layer 2 VPLS tunnels re-establish and automatically get removed and added to the bridge, thereby changing its MAC address. I assume a deeper bug relating to the link local address not updating properly to track the interface's MAC so I simply set a static MAC address on the 'bridge-ipv6-mpls' interfaces to avoid the quirk.
