MUM Europe 2020
freddyg
Recomended hardware? 300m line of sight, perfect quality
Mon Jun 07, 2010 5:22 pm
Dear sirs,
Can you please recommend me a solution for the following;
Point to Point link from rooftop to rooftop (300meters line of sight)
Important is:
Jitter
Latency
Throughput (we need 100M+, the higher the better)
Our budget is ~800€/link (happy if we can do it cheaper, but quality is more important then price)
BR
Fredrik
poli5681
Re: Recomended hardware? 300m line of sight, perfect quality
Tue Jun 08, 2010 2:15 pm
If you need more than 100Mbit with POE your only option is RB800 with n-Wireless and a good dual-pol antenna.
This is the only board to support 1Gbit Interfaces with ieee802.11af POE.
Your costs might be a bit higher than 800€, but believe me, its worth.
If 100Mbit are enough for you, RB433AH is an option.
rmichael
Forum Veteran
Forum Veteran
Tue Jun 08, 2010 9:32 pm
RB411AH + R52Hn + dual pol antenna (like AirMax 17dBi) x2 on each side. Both RB411AH connected to RB450G on each side running OSPF.
That's about $750 per link with full redundancy and up to 300Mbps TCP throughput (150Mbps one way). If your network packets are smaller than 1000bytes -on average- than you'll need something more powerful than RB450G.
Users browsing this forum: Mikro82, MSN [Bot], vilpalu and 25 guests
