PaoloBS
DUDE as windows service without user log on
Wed Jun 09, 2010 4:10 pm
Hello
I need to run dude as windows services.
I need to keep service ON also when no windows users are logged in
I try dude 3.6 on win xp and when i perform the log off the service not works.
Someone could help me?
Best regards!
Paolo
mcb
Re: DUDE as windows service without user log on
Mon Jul 05, 2010 10:12 am
Did you at least TRY to add it as a Windows service? On which Windows version?
normis
Mon Jul 05, 2010 10:16 am
Use this option:
PaoloBS
Tue Jul 13, 2010 6:07 pm
Ok now works on small bussiness server
One think: dude appear on process list and not in the services list of task manager.
For Version 3.6 On windows server 2008 R2
When i configure as services
The dude client fails to connect to the server (on the same server)
If I install 4.01 beta on win 2008 R2, install fail in waiting stop server.
If i deinstall 3.6 and reinstall it, all is ok.
HarvSki
Mon Nov 08, 2010 3:36 pm
I had the same problem on Windows server 2008 with Dude version 4.0 beta2, it would not install as a service until I switched off Windows User Access Control then it installed no problem
megamuz
Wed Jul 22, 2015 8:58 am
Run the dude as administrator, and check in the "as service". Reconnect with the default login and configure again.
Users browsing this forum: No registered users and 6 guests
