AdinaNet
Clock on PCEngines WRAP x86, 10 seconds per second?
Fri Jun 11, 2010 4:49 pm
I just put 4.10 on a PCEngines WRAP board, older model, that is showing the system clock incrementing by 10 seconds every second. It did the same on 4.6. NTP is setup, but I am dropping a 5GHZ link quite often and watching this clock advance at a tremendous pace. The system believes it has been up for 5 days, I rebooted last night.
Any ideas? This is one of my backhaul links, and it is creating quite the problem.
Thank you.
Chupaka
Re: Clock on PCEngines WRAP x86, 10 seconds per second?
Sun Jun 13, 2010 8:03 pm
BIOS Firmware upgrade?..
bokad
Mon Jun 14, 2010 3:52 am
This sounds like what happened with 3.x when you loaded the wireless test package.
uldis
Mon Jun 14, 2010 10:55 am
disable the nstreme if it is possible.
and try to use RouterOS v5.0beta3 when it is released and then play with the multi-cpu option. We hope to release v5.0beta3 soon.
