dssmiktik
Forum Veteran
Forum Veteran
Re: NAT64 and DNS64
Tue Oct 19, 2010 12:27 am
For software requests, here is the current wiki page:
http://wiki.mikrotik.com/wiki/MikroTik_ ... e_Requests
Doug
daffster
Re: NAT64 and DNS64
Tue Oct 19, 2010 1:00 pm
Good Point.
I see its on that page too. I've added my name to the list.
Paxy
Re: NAT64 and DNS64
Thu Oct 28, 2010 12:05 pm
I am fully supporting idea of NAT64.
Until dual stack is active, administrator will keep forcing IPv4 due its simplicity and short form of ip address that is easy to remember.
Only way to accelerate improvement process by transferring completely to IPv6 is to transfer small networks and become prepared for WAN IPv6 transfer.
We would not be ready do deploy IPv6 until we give up IPv4. This is legacy rule !
bevhost
Re: NAT64 and DNS64
Thu Oct 28, 2010 10:46 pm
HI, Just returned from the IPv6 Forum Conference in Melbourne, Australia and the current advice is.
Dual Stack where you can.
Tunnel where you can't
Use NAT if you have a gun to your head.
regards,
dave
use my lookup tools
Beccara
Long time Member
Long time Member
Re: NAT64 and DNS64
Thu Oct 28, 2010 11:23 pm
What conference was that? Most SIG's are saying Translation like NAT64 is the best path since Dual-Stack only works when you have v4 space left to hand out, then its onto Dual-Stack with NAT444 on the v4 side which as you've pointed out - Would need a gun to your head
bevhost
Re: NAT64 and DNS64
Fri Oct 29, 2010 3:27 am
I would think that NAT444 + Dual Stack would work much better than NAT64/DNS64.
If you would need a gun to your head to do NAT444 then you'll need an even bigger gun to do NAT64.
If you think NAT64 will solve any of your problems think again.
Heaps of stuff doesn't work with NAT64.
About the only thing broken with NAT444 is UPnP, and that can be resolved with Manual Port Forwarding.
regards,
dave
use my lookup tools
Beccara
Long time Member
Long time Member
Re: NAT64 and DNS64
Fri Oct 29, 2010 3:37 am
Do you really think manual port forwarding at the ISP level is ever going to work?? I doubt we'll see NAT64 in ROS but the big players are deploying it, It will likely end up another transition step after large scale ISP's find that NAT444 is just not worth the hassle.
Have you actually used NAT64 before? Its quite nice, There is a liveCD floating around, Very fun turning off v4 on your computer and having everything keep working :)
bevhost
Re: NAT64 and DNS64
Fri Oct 29, 2010 4:08 am
Did you try it with Windows XP? Mac OS X?
When you say everything keeps working? What did you test? I'm sure outbound connections would work but what about P2P applications?
Skype?
What about http://66.102.11.104/
Or inbound connections can you remote desktop to an XP computer through NAT64?
How do inbound connections work from the IPv4 Internet?
regards,
dave
use my lookup tools
bevhost
Re: NAT64 and DNS64
Fri Oct 29, 2010 4:15 am
I can see some benefit of NAT64 for some of the Mobile phone providers in countries like India and China that are turning on new mobile devices at a staggering rate. Some newer mobile devices do support IPv6 quite well and they need access to legacy web servers on IPv4 and that is a good reason to use NAT64, so yes I agree the big players will role it out, but I doubt they will use RouterOS.
regards,
dave
use my lookup tools
Beccara
Long time Member
Long time Member
Re: NAT64 and DNS64
Fri Oct 29, 2010 5:19 am
Skype?
Web browsing worked fine, never ran into an issue. Skype worked for voice but I didnt try video (Never had a need) Existing NAT-busting methods used in alot of software works fine but will run into issues in a NAT444 setup. SIP and FTP had issues due to IP info carried inside the application level data. Some form of ALG ala NAT-PT will help with this
NAT444 is already in place by a lot of MT users, I believe our resident forum troll here doesnt supply his clients with a public v4 so ROS demand for it will be low. The skill needed to put in place and debug something as complex as NAT64 will rule out most ROS users. I really dont think it will be worth MT's time to put something like this in place, NAT64 is a small bridge for those of us who will deploy v6 before the crunch, NAT444 will be clung onto by users who dont know how or who wont deploy v6
bevhost
Re: NAT64 and DNS64
Fri Oct 29, 2010 5:39 am
Sorry to keep on about this, but what OS did you try this on?
regards,
dave
use my lookup tools
Beccara
Long time Member
Long time Member
Re: NAT64 and DNS64
Fri Oct 29, 2010 5:49 am
XP SP3
macgaiver
Re: NAT64 and DNS64
Fri Oct 29, 2010 8:54 am
If i may jump into conversation.
From what i notices MikroTik really loves when feature description is set in stone - so there are actual "Internet Standard".
From what i was able to find on this topic is:
a) http://tools.ietf.org/id/draft-bagnulo- ... t64-03.txt
"This Internet-Draft will expire on September 8, 2009"
b) http://tools.ietf.org/html/draft-ietf-b ... tateful-00
"This Internet-Draft will expire on January 5, 2010"
So, it is not even "Proposed Standard" not talking about "Draft Standard" and "Internet Standard"...
IF i'm missing something, please, provide me proper links :)
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
bevhost
Re: NAT64 and DNS64
Fri Oct 29, 2010 2:09 pm
Ok, so I found the CD, downloaded it, had a play. Read the specs.,
It's really only designed to allow IP6 only clients to access IPv4 legacy servers.
It's not meant for Ipv4 to Ipv6 connections and not designed to do P2P applications.
It might allow for Hole Punching in the way that firewalls allow reverse connections in RELATED state, but that's all.
So once they get the ALG's written, it will catch up to where NAT44 is now and you'll be able to move on from Dual Stack to IPv6 Only Stack.
regards,
dave
use my lookup tools
Beccara
Long time Member
Long time Member
Re: NAT64 and DNS64
Sun Oct 31, 2010 9:51 pm
Its PoC code, Meant as a simple demo. I'm not even sure the linux code is being actively worked on. Anyway this topic is pointless as MT will never put something like NAT64 into ROS and alot of people around here already do NAT444.
eduardomazolini
Re: NAT64 and DNS64
Mon Jul 04, 2016 8:29 pm
http://tools.ietf.org/html/rfc6146
Zorro
Long time Member
Long time Member
Re: NAT64 and DNS64
Wed Jul 06, 2016 1:09 am
aside NAT64 relevant things - 6877 https://tools.ietf.org/html/rfc6877 was apprently common as say wiukd 6rd, DS, DS-lite or other things from that list https://en.wikipedia.org/wiki/IPv6_tran ... mechanisms
(in which - ANY thing make sense and important).
from proprietary stuff among it perhaps MAP by CISCO was imprtant(rest, including ommited from article - not so much, perhaps. or even known at all).
fron "unemplemented yet" not finalised things i personally would care about IPv6 to IPv6 NAT(some would say "it make no sense", but sadly it is. already :(
andersonlich
Re: NAT64 and DNS64
Wed Jul 13, 2016 2:52 am
v6 should be end to end connection. But if mikrotik released this feature that should be +10.
mohmultihouse
Re: NAT64 and DNS64
Tue Jan 03, 2017 9:29 am
i second this, need NAT64 support.
Zorro
Long time Member
Long time Member
Re: NAT64 and DNS64
Mon Feb 27, 2017 8:17 am
not really. it "should" not.
and for that reasons both 4-to-6, 4-to-6 and even 6-to-6 NAT exist, just like 4-to-4 before. but implementation yet sporadic and incomplete, yet(to use "straight away/now").
mohmultihouse
Re: NAT64 and DNS64
Thu Mar 09, 2017 11:15 am
Google just made a public DNS64 server, NAT64 gateway is more relevant then ever.
https://developers.google.com/speed/pub ... docs/dns64
Splash
Re: NAT64 and DNS64
Sat Apr 29, 2017 4:02 pm
Here's to hoping IPv6 on Mikrotik will take a leap forward and become a more complete solution. With the IPv6 certification now available from Mikrotik, I'm crossing fingers they will press forward with an IPv6 implementation that is more usable.
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME
Milan
Re: NAT64 and DNS64
Tue Jul 11, 2017 12:03 am
We really need NAT64. And also IPv6 NAT (not IPv6 masqureade, just NAT).
zervan
Re: NAT64 and DNS64
Wed Jul 26, 2017 10:18 pm
Is anything new about NAT64? Maybe some new RouterOS version?
If not, maybe this could be useful (at least for testing): http://www.internetsociety.org/deploy36 ... in-go6lab/
Dusan Zervan from Slovakia
MTCNA, MTCRE
eliasbats
Re: NAT64 and DNS64
Sat Sep 16, 2017 11:03 pm
Dear MT, Please consider NAT64!
wtm
Re: NAT64 and DNS64
Thu Jul 05, 2018 5:01 am
Bump ........
Is there anything new on this? As IPV4 addresses get in shorter demand?
enzain
Re: NAT64 and DNS64
Wed Jan 30, 2019 10:44 am
Any progress with nat64 and dns64?
Now in russia is actual, our internet regulator starting blocking sitews by IPv6 ...
mutinsa
Re: NAT64 and DNS64
Sat Feb 09, 2019 4:36 pm
+1.
Sergey Mutin
Certified Mikrotik Consultant
MikroTik: MTCNA, MTCRE, MTCIPv6E, MTCTCE, MTCUME, MTCINE, MTCWE | Cisco: CCNA R&S | Juniper: JNCIA-Junos | Zabbix: ZCU | Asterisk: dCAA | IPv6 Forum Certified Network Engineer (Silver) | HE.net IPv6: Sage
Users browsing this forum: No registered users and 9 guests
