HaQs
feature request : Windows ROS installer on USB card reader
Thu Jun 17, 2010 9:11 pm
Any chance to netinstall version to install ROS on CF card (USB CF READER)
Local in Windows ?
normis
Re: feature request : Windows ROS installer on USB card read
Fri Jun 18, 2010 10:19 am
Of course, that's what Netinstall is for.
HaQs
Fri Jun 18, 2010 10:47 pm
OK :)
In Configure script: I can browse: .backup file ? (only RSC extension or all )
When I select backup file then ROS will be instaled and this backup will be automatic restored ?
fewi
Fri Jun 18, 2010 11:10 pm
You can't use a .backup file, those are specific to that router (not just the model, but that very router).
The configuration restore can be used for restoring the router's configuration, exactly as it was at the backup creation moment, from a backup file. The restoration procedure assumes the cofiguration is restored on the same router, where the backup file was originally created, so it will create partially broken configuration if the hardware has been changed.
http://wiki.mikrotik.com/wiki/Manual:Co ... escription
Do an export instead (same wiki link) and use the resulting script as a .rsc file.
HaQs
Mon Jun 21, 2010 12:45 am
OK, but when I need prepare: working CF card with ROS and old backup file to change card (ex. ROS update failed.)
RSC file is not enough.
HOW with netinstall?
Any chance to option: "backup file" in prepared CF card with netinstall.
Users browsing this forum: Google [Bot], psannz, wispmikrotik, xanio and 129 guests
