minfrin
After reboot, /ip dns changes revert to old settings
Sat Jun 19, 2010 4:32 pm
Hi all,
I have a strange problem with /ip dns.
I need to update the name of the DNS server server in routerboard, and so use /ip dns to change the settings. I can view the new settings, and the routerboard's DNS now works, so far so good.
I then reboot the routerboard, and the old dns settings have come back again, the change I made didn't "stick".
Is this a known problem, and has anyone worked around it / managed to solve it?
Regards,
Graham
changeip
Re: After reboot, /ip dns changes revert to old settings
Sat Jun 19, 2010 8:56 pm
are you using dhcp client with use dns checked?
