Hunteru
Restore configuration problem in Metarouter (RB1100 - 4.10)
Thu Jul 01, 2010 1:12 pm
Hi all,
I had a PC runnig MikroTik 4.10 with KVM active set with a mikrotik virtual machine.
I made a backup of the virtual mikrotik (his configuration) and I want to migrate to my new RB1100 using MetaRouter.
I set the MetaRouter with my virtual machine, I import the config and I restored.
In console after it reboots it hangs like this:
Rebooting...
Stopping services...
Restarting system.
Starting...
Starting services...
Why is happening ? I can't use my new RB1100 properly.
Please help.
The Metarouter machine is set to use 128 M of ram and 500 Mbytres of disk space, with 2 virtual interfaces set to 2 dynamic bridges.
/metarouter
add name=shaper disk-size=500000 memory-size=128 disabled=no
interface
add virtual-machine=shaper dynamic-bridge=bridge_1
add virtual-machine=shaper dynamic-bridge=bridge_2
reboot shaper
janisk
Re: Restore configuration problem in Metarouter (RB1100 - 4.
Fri Jul 02, 2010 8:46 am
try not to import port and interface settings.
or do Ctrl+A; Ctrl+R to detect transfer rate and you should get that login prompt.
Users browsing this forum: No registered users and 2 guests
