pakzad
Can I use Mikrotik Instead of Cisco router?
Sun Jul 04, 2010 4:04 pm
Can I use Mikrotik RouterOS instead of Cisco router to make an access server?
I use this hardwares to provide a dialup service in my isp.
1.Cisco AS5300
2.XAVi G.SHDSL modem
3.Radius server
and now I want to use mikrotik router.os instead of my Cisco AS5300.
Can I do this by FarSync_TE1?
http://www.farsite.com/datasheets/FarSy ... _G.704.pdf
normis
Re: Can I use Mikrotik Instead of Cisco router?
Mon Jul 05, 2010 9:16 am
Yes, that farsync card should be supported in RouterOS. Not sure about the rest of the requirements, don't know much about those mentioned ciscos.
mcb
Mon Jul 05, 2010 10:23 am
My approach:
Old PC, RouterOS on it, box of beer, me on it, configuration, trying, then asking for a specific problem, if any.
normis
Mon Jul 05, 2010 10:27 am
Old PC doesn't cut it if you need millions of PPS and major BGP feeds
pakzad
Mon Jul 05, 2010 4:18 pm
I know that farsync card is supported in RouterOS.
but i want to make an ACCESS SERVER by Mikrotik RouterOS.
Do you know what is an access server in dialup networks?
mcb
Mon Jul 05, 2010 5:34 pm
Well, first you need to TEST that dial-up perversion anyway, right?
How to do it, if no with an old PC and trial/cracked RouterOS?
Then, if it works with couple of users, you try to switch the dial-up pool over to an allready configured RouterOS, which is bought legally.
I never experiment such major changes with a working system.
Normi, where do you got the hundreds and thousands of users? Look at his HW.
pakzad
Wed Jul 21, 2010 7:29 pm
This is The diagram of my current network:
And this is the diagram of new network that I want it
Ozelo
Thu Jul 22, 2010 12:07 am
I'm also interested on this question, if I can use Mikrotik instead of CISCO. But my decision parameter lies on BGP:
CISCO config
no bgp enforce-first-as
Can Mikrotik do this?
