Metalspawn
Help with MPLS please
Tue Jul 06, 2010 2:59 pm
Hello . I want to create a LAN network between me and 2 friends.
I have the following setup :
3 Routerboards :
Station1 -------> <--------------- My RB (Ap) --------------> <------------------- Station2
Station1 has its own antenna for the AP and so does Station2
Here is my setup scripts
AP
# --configure wireless access point--
/interface wireless
set wlan1 disabled=no ssid=MPLS frequency=5180 band=5ghz mode=bridge
# --configure IP--
add address=172.16.0.1/30 interface=wlan1
# --enable LDP--
/mpls ldp
set enabled=yes lsr-id=172.16.0.1 transport-address=172.16.0.1
/mpls ldp interface
add interface=wlan1
# --configure VPLS tunnel--
/interface vpls
add name=vpls1 remote-peer=172.16.0.2 vpls-id=1:1 disabled=no
# --add bridge and bridge ports --
/interface bridge add name=bridge1
add bridge=bridge1 interface=vpls1
station
/interface wireless
set wlan1 disabled=no ssid=MPLS band=5ghz mode=station
# --configure IP--
add address=172.16.0.2/30 interface=wlan1
# --enable LDP--
/mpls ldp
set enabled=yes lsr-id=172.16.0.2 transport-address=172.16.0.2
/mpls ldp interface
add interface=wlan1
/interface vpls
add name=vpls1 remote-peer=172.16.0.1 vpls-id=1:1 disabled=no
-------------------------------------------------------OK Link 2 ------------------------------------------------------------
AP
/interface wireless
set wlan2 disabled=no ssid=MPLS band=2.4ghz-b/g mode=bridge
# --configure IP--
add address=172.16.0.5/30 interface=wlan2
# --enable LDP--
/mpls ldp
set enabled=yes lsr-id=172.16.0.5 transport-address=172.16.0.5
/mpls ldp interface
add interface=wlan2
/interface vpls
add name=vpls2 remote-peer=172.16.0.6 vpls-id=2:2 disabled=no
add bridge=bridge1 interface=vpls2
2nd Station
/interface wireless
set wlan1 disabled=no ssid=MPLS band=2.4ghz-b/g mode=station
# --configure IP--
add address=172.16.0.6/30 interface=wlan1
# --enable LDP--
/mpls ldp
set enabled=yes lsr-id=172.16.0.6 transport-address=172.16.0.6
/mpls ldp interface
add interface=wlan1
/interface vpls
add name=vpls1 remote-peer=172.16.0.5 vpls-id=2:2 disabled=no
When i setup the first link everything works fine, but as soon as i add the second set of commands i can only access my 2nd friends network.
From what i can see is that the routing protocols pick up a loop in the network (Don't know how ???) but i get that one is designated and the other disabled. I can't remember where I read that, but if some one can perhaps help me with this matter I will appreciate it!.
Thanks in advance
hans0
Re: Help with MPLS please
Tue Jul 06, 2010 6:10 pm
Why on ap there is two hosts network mask ?
Metalspawn
Tue Jul 06, 2010 6:46 pm
Because i have 2 wireless lan cards connecting the two . Should i try and put them on the same network ?
hans0
Tue Jul 06, 2010 8:24 pm
Of course NO!
But SSID for all wlan devices is this same.
Are you sure that your clients are connected to different AP?
Sorry but your configuration dump is quite hard to read cause is incomplete.
Try to make all configuration as easy as it is possible:
St1----------------------Ap_wlan1|AP_wlan2--------------------St2
SSID Link1 SSID Link2
net: 172.16.0.0/30 | 172.16.0.4/30
ip:
172.16.0.2/30 172.16.0.1/30 | 172.16.0.5/30 172.16.0.6/30
routing:
on St1: add to 172.16.0.4/30 via 172.16.0.1/30
on St2: add to 172.16.0.0/30 via 172.16.0.5/30
after this if you can ping every host form each other start with MPLS
Add LDP interfaces : wlans on all routers.
Not sure but I increase MTU of every interface on which ldp labels are supposed to be going through.
In your case set mtu for all wlans to 1522.
Next set other things about MPLS.
Check LDP neighbors.
Set vpls tunnels
Bridge to ethernet on endpoints and finish.
Metalspawn
Tue Jul 06, 2010 9:03 pm
Ok thanks for the quick reply, going to redo the network in about 2 hours and check if i can fix it via your method.
Metalspawn
Thu Jul 08, 2010 3:25 pm
Ok I have redone everything. Same problem as before: One vpls's role is :"Disabled port" in the bridge->Port . Can any1 shed some light on what goes wrong where ?
Mplsguy
Thu Jul 08, 2010 4:19 pm
please post output of the following commands on all involved devices:
/ip address print
/ip route print
/mpls local-bindings print
/mpls remote-bindings print
/interface vpls print
Metalspawn
Sat Jul 10, 2010 6:03 pm
Ap Settings :
[admin@MikroTik] > ip address print
# ADDRESS NETWORK BROADCAST INTERFACE
0 ;;; default configuration
192.168.0.6/24 192.168.0.0 192.168.0.255 ether1
1 172.16.1.1/24 172.16.1.0 172.16.1.255 wlan1
2 172.24.200.209/28 172.24.200.208 172.24.200.223 ether1
3 172.24.200.66/27 172.24.200.64 172.24.200.95 WUG
4 172.16.0.5/30 172.16.0.4 172.16.0.7 Brandon-Micholl
[admin@MikroTik] > /ip route print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 172.16.0.0/12 172.24.200.65 1
1 ADC 172.16.0.4/30 172.16.0.5 Brandon-Micholl 0
2 ADC 172.16.1.0/24 172.16.1.1 wlan1 0
3 ADC 172.24.200.64/27 172.24.200.66 WUG 0
4 ADC 172.24.200.208/28 172.24.200.209 bridge1 0
5 ADC 192.168.0.0/24 192.168.0.6 bridge1 0
[admin@MikroTik] > /mpls local-bindings print
Flags: X - disabled, A - advertised, D - dynamic,
L - local-route, G - gateway-route, e - egress
# DST-ADDRESS LABEL PEERS
0 ADLe 172.24.200.208/28 impl-null 172.16.1.2:0
1 ADLe 172.16.0.4/30 impl-null 172.16.1.2:0
2 ADLe 192.168.0.0/24 impl-null 172.16.1.2:0
3 ADLe 172.24.200.64/27 impl-null 172.16.1.2:0
4 ADLe 172.16.1.0/24 impl-null 172.16.1.2:0
5 ADG 172.16.0.0/12 17 172.16.1.2:0
[admin@MikroTik] > /mpls remote-bindings print
Flags: X - disabled, A - active, D - dynamic
# DST-ADDRESS NEXTHOP LABEL PEER
0 D 192.168.88.0/24 impl-null 172.16.1.2:0
1 D 172.16.1.0/24 impl-null 172.16.1.2:0
[admin@MikroTik] > /interface vpls print
Flags: X - disabled, R - running, D - dynamic,
B - bgp-signaled, C - cisco-bgp-signaled
0 name="vpls2" mtu=1500 l2mtu=1500 mac-address=02:F4:BD:B4:95:F6
arp=enabled disable-running-check=no remote-peer=172.16.0.6
vpls-id=2:2 cisco-style=no cisco-style-id=0 advertised-l2mtu=1500
pw-type=raw-ethernet
1 R name="vpls1" mtu=1500 l2mtu=1500 mac-address=02:53:53:BF:8B:04
arp=enabled disable-running-check=no remote-peer=172.16.1.2
vpls-id=1:1 cisco-style=no cisco-style-id=0 advertised-l2mtu=1500
Station1 (working one)
[admin@MikroTik] > /ip address print
192.168.88.1/24 192.168.88.0 192.168.88.255 ether1
1 172.16.1.2/24 172.16.1.0 172.16.1.255 wlan1
0 ADC 172.16.1.0/24 172.16.1.2 wlan1 0
1 ADC 192.168.88.0/24 192.168.88.1 bridge1 0
0 ADLe 192.168.88.0/24 impl-null 172.16.1.1:0
1 ADLe 172.16.1.0/24 impl-null 172.16.1.1:0
0 D 172.24.200.208/28 impl-null
1 D 172.16.0.4/30 impl-null
2 D 192.168.0.0/24 impl-null
3 D 172.24.200.64/27 impl-null
4 D 172.16.1.0/24 impl-null
5 D 172.16.0.0/12 17
0 R name="vpls1" mtu=1500 l2mtu=1500 mac-address=02:51:DD:7C:3B:11
arp=enabled disable-running-check=no remote-peer=172.16.1.1
Station 2 (Disabled Port)
172.0.0.5/24 172.0.0.0 172.0.0.255 ether1
1 172.16.0.6/30 172.16.0.4 172.16.0.7 wlan1
2 192.168.0.8/24 192.168.0.0 192.168.0.255 ether1
0 ADC 172.0.0.0/24 172.0.0.5 bridge1 0
1 ADC 172.16.0.4/30 172.16.0.6 wlan1 0
2 ADC 192.168.0.0/24 192.168.0.8 bridge1 0
0 name="vpls1" mtu=1500 l2mtu=1500 mac-address=02:12:27:A7:3E:18
arp=enabled disable-running-check=no remote-peer=172.16.0.5
Mplsguy
Tue Jul 13, 2010 7:59 am
From your config I understand that you are trying to establish 2 vpls tunnels, one between station1 and AP and second between station2 and AP. Is that correct? In this case please post VPLS config on AP also.
Additionally - there are no any LDP bindings on station 2. This tells that most likely you do not have LDP enabled there or it is not establishing adjacency with AP. Please post all LDP and VPLS related config of AP and station 2.
Users browsing this forum: lywkj, Majestic-12 [Bot] and 19 guests
