trouble
TE Tunnel and Load sharing or load distribution
Thu Jul 08, 2010 1:36 am
I have two TE( MPLS Traffig Engineering) tunnels from a head end to tail end via different paths ( like from router A to router B via router C and other is from router A to router B via router D) , how I can load share or load balance between two TE tunnel. I am using TE tunnels to transport multiple vpls circuits. Any help would be highly appreciated. Thanks
Regards
Mplsguy
Re: TE Tunnel and Load sharing or load distribution
Thu Jul 08, 2010 10:56 pm
I guess you should create as many VPLS tunnels as necessary and then use bonding for load sharing/balancing - instead of bridging ethernet with VPLS tunnel, bridge ethernet with bonding interface. Then add VPLS tunnels that traverse different paths as slaves to bonding interface.
odge
Fri Feb 18, 2011 5:27 pm
Sorry to barge in on this thread, but I want to get MPLSGUY's attention/
Hi Mplsguy... have you seen this thread: http://forum.mikrotik.com/viewtopic.php?f=13&t=48971
Is there an answer to that... can MPLS be used to split a TCP connection down different MPLS tunnels and reassemble it on the remote router?
Users browsing this forum: cdiedrich and 16 guests
