MUM Europe 2020
normis
RouterOS 5 beta 5
Fri Jul 23, 2010 3:45 pm
What's new in 5.0beta5 (2010-Jul-23 14:50):
*) email - supports multiple CCs
*) fix 5&10MHz channel support for 11n cards;
*) ssh - fix ssh client crash;
*) ssh - password authentication is disabled for users with public keys;
*) ping - fixed ping packet-loss calculation;
http://www.mikrotik.com/download/router ... a5.torrent
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS 5 beta 5
Fri Jul 23, 2010 5:44 pm
In the torrent, the mipsbe packages are corrupt. The RB1000 packages worked. In the direct download, the mipsbe packages worked.
adryfia
Sat Jul 24, 2010 6:55 am
In my RB450 the cpu load very fast to 100%, and i can't access my usermanager from web, what wrong??. Now i make ROS beta4 againt. Do you have any solutuion for this???
npero
Sat Jul 24, 2010 8:20 am
Upgraded couple minutes ago and question.
When do wireless scan only have button start, where is stop button gone ?
Usually I do quick scan press stop and look results now I don't have any more stop :( scan is running until close scan window.
JustinTx
Re: RouterOS 5 beta 5 view content
Sat Jul 24, 2010 1:01 pm
RouterOS 5.0beta5
* All files (requires a Torrent client)
* Combined package (http)
* All packages (Includes optional packages: view content)
View Content shows 4.10 files:
* advanced-tools-4.10.npk
* arlan-4.10.npk
* calea-4.10.npk
* dhcp-4.10.npk
* gps-4.10.npk
* hotspot-4.10.npk
* ipv6-4.10.npk
* isdn-4.10.npk
* kvm-4.10.npk
* lcd-4.10.npk
* mpls-4.10.npk
* multicast-4.10.npk
* ntp-4.10.npk
* ppp-4.10.npk
* radiolan-4.10.npk
* routerboard-4.10.npk
* routing-4.10.npk
* security-4.10.npk
* synchronous-4.10.npk
* system-4.10.npk
* ups-4.10.npk
* user-manager-4.10.npk
* wireless-4.10.npk
petro25
Sat Jul 24, 2010 11:04 pm
Hello. I would like to see a new version of the following configuration rollback feature on the timer. since it is usually placed on the radio long distances this feature will be quite handy. For example put a value then it is said that to use it for 5 minutes. After 5 minutes he returned to the starting position. and sometimes expose the parameters and the connection is lost had to go to a distant point. sorry for my bad English
rpress
Mon Jul 26, 2010 5:14 am
I still have the problem (since beta 4) that opening up an IPv6 route closes WinBox. It happens on my RB750 but not on the RB433, both with a clean config.
martini
Mon Jul 26, 2010 12:00 pm
Ros v5beta5 - torch dont work correct (first 20-40 rows show full ointerface speed on each IP), and where you hide STOP button ??
Xymox
Mon Jul 26, 2010 12:10 pm
Meta router still does not work in 5.0B5. No console..
blake
Mon Jul 26, 2010 12:45 pm
Like this?
http://wiki.mikrotik.com/wiki/Manual:Console#Safe_Mode
IT consultant. Network manager. Packet junkie.
1-928-328-1509
petro25
Mon Jul 26, 2010 10:31 pm
on the RB800 does not start Dude v4.0beta2
petro25
Mon Jul 26, 2010 10:34 pm
add to winbox "Apply button for 5 minutes"
dominicbatty
Tue Jul 27, 2010 4:21 pm
the /ping command in Beta5 only works in the scheduler the very first time it is used ...
i.e. Script that does ....
:log info ("ping result1=" . "$[/ping 8.8.8.8 count=3]");
:log info ("ping result2=" . "$[/ping 8.8.8.8 count=3]");
:log info ("ping result3=" . "$[/ping 8.8.8.8 count=3]");
Reboot the router .... log reports ....
ping result=3
ping result=
ping result=
This is an improvement on Beta 4 .... which did ...
ping result=
ping result=
ping result=
but still not quite there .... please help.
adryfia
Tue Jul 27, 2010 11:47 pm
Any body have solution for any bugs at beta5, waiting solve with any version :?
Chupaka
Wed Jul 28, 2010 3:02 am
I can confirm a 'feature' with ping result in beta5 =) to be fixed in beta6? :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
velvet
Mon Aug 02, 2010 2:46 pm
sshd crashed again, after few hours, on alix board with ROS 5 beta5
velvet
mangust
Wed Aug 04, 2010 4:08 pm
Incorrect status of the interfaces: all interfaces are "running" even if nothing connected.
kirshteins
Wed Aug 04, 2010 4:24 pm
That is normal for x86 as disable-running-check=yes is set by default.
adryfia
Wed Aug 04, 2010 8:10 pm
Long time waiting beta 6 version................ :( :( :(
mangust
Thu Aug 05, 2010 10:19 am
Oppss, You right...
What is the command to make "disable-running-check=no"?
Chupaka
Thu Aug 05, 2010 2:55 pm
/interface ethernet set ether1 disable-running-check=no
ckgth
Fri Aug 06, 2010 7:38 pm
Hello there!
on RB/333 with beta5 bridge filter not working.
best regards,
paranoid
Sun Aug 08, 2010 7:46 pm
Hallo there
I'm using openssh client to backup the config of my routers
since the changes of the ssh server in ros5 i cant perform export cmd like this
ssh -l admin my.mikrotik.com "export"
same with
ssh -l admin+ct my.mikrotik.com "export"
any ideas?
with routeros 4.11 its working
i dont like the binary backup because the binary backups are not platform independent
when you import a binary config of a rb450 into rb750 you have got no serial cable to set the interfaces right
i don't understand this change... you expect a security whole?
i think this is not the default behavior of an ssh server
thanks
Users browsing this forum: No registered users and 69 guests
