MUM Europe 2020
uldis
New wireless protocol: Nv2 in v5.0beta5
Fri Jul 23, 2010 8:58 pm
In RouterOS v5.0beta5 there is a new wireless protocol Nv2 which is based on TDMA.
To make the connection using Nv2 on the AP side you need to select the wireless-protocol=nv2 and on the Station side you can also select wireless-protocol 'nv2' or 'any'.
Some features are not ready yet for Nv2: no support WDS,Security,Virtual AP,some details in the registration table and status. We will optimize the Nv2 in the upcoming versions.
We would like to get some feedback from you how it is working on your wireless links. When posting, please include info on the distance of the link and settings that you have and latency.
When testing N link with Nv2 you can get approx 97Mbps UDP traffic and 94Mbs TCP traffic through RB711 in one direction using one chain.
Stanislav Hrncir
Re: New wireless protocol: Nv2 in v5.0beta5
Fri Jul 23, 2010 9:32 pm
Any documentation ? what does setting "nv2 nstreme 80211" in one row ? combination of this three or what..
uldis
Fri Jul 23, 2010 9:46 pm
more documentation will be available next week.
If you select that option all 3 in one row in the Station it means it will chose any from that list.
changeip
Fri Jul 23, 2010 9:59 pm
i really hope this is compatible with airmax... please please please.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
adrianatkins
Long time Member
Long time Member
Fri Jul 23, 2010 11:47 pm
I hope not ! I prefer things that Work.
Is Nv2 going to have any kind of Time Synch, or will it be just for the Outback like Airmax ?
Don't forget to give me at least a tenner a month, every month
Mplsguy
Sat Jul 24, 2010 6:01 am
nv2 is not compatible with Airmax.
nv2 is supported for all Atheros cards, except old AR5211 based, so in order to try it out it is not required to have 11n cards - just upgrade, set wireless-protocol=any on station (this will enable station to look for whatever protocol AP that is available with appropriate SSID), set wireless-protocol=nv2 on AP and you are ready to go. If something goes wrong change wireless-protocol on AP to nstreme/802.11 - whatever you were using before.
If "Time Synch" means some synchronization between APs, then no, nv2 does not support such feature yet. You can think of it as of improved nstreme. Its benefits are intended to come from removed polling overhead.
charliebrown
Sat Jul 24, 2010 7:34 am
We've just done some testing on a 1.6km link, LOS. RB 433 on each side with R52n Cards. 22db Panel on 1 side and 22db Grid on the other. Only 1 chain
http://spreadsheets.google.com/ccc?key= ... tdFE&hl=en
We were bandwidth testing thru the routers with IP routing, We seem to have run into a issue/bug where we couldnt RX more than 33mbit which we are still looking into but so far NV2 is performing worse than Nstream.
Link signals are -72ish with 90+% CCQ
These results are not meant to show the max it can do but merely show the different between the protocols
temuri426
Sat Jul 24, 2010 8:30 am
hi all, glad to see new feaures in router os...
what is the advantages of using TDMA in router os?
npero
Sat Jul 24, 2010 9:10 am
Now tested is horrible :( .
WDS nstreme work very well with one chain switch to station and MPLS work little slower, but when go to Nv2 is disaster TX/Rx rate don't want to go more that 54/54Mbps and when traffic go link disconnected.
Also without traffic ping is 5-6ms with traffic don't know disconnected, old setting have 0ms ping without traffic.
Go back to nstreme WDS and have TX/RX 150-HT/150-HT and good speed.
Tested on two x86 distance 400m one chain card is both side R52n.
nz_monkey
Sat Jul 24, 2010 9:42 am
That is a brilliant feature, maybe the devs could think of a better name so it is self explanatory. Maybe evem putting a comma between them e.g. Nv2, Nstreme, 802.11
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
Stanislav Hrncir
Sat Jul 24, 2010 1:07 pm
My results on testbed, RB800 - 1333MHz, x86 1333MHz, both R52N + 5GHZ a/n,
TWO CHAINS + EXTENSION CHANNEL
802.11                       @270mbit throughtput 194mbit     @avg 12ms latency
nv2                           @270mbit throughtput 211mbit  @avg 8ms latency
nv2 + nstreme             @270mbit throughtput 217mbit    @avg 6ms latency
nv2 + nstreme + 80211 @270mbit throughtput 190,4Mbit  @avg 10ms latency
ONE CHAIN + EXTENSION CHANNEL
802.11                       @135mbit throughtput 110mbit     @avg 20ms latency
nv2                           @135mbit throughtput 108mbit     @avg 16ms latency
nv2 + nstreme             @135mbit throughtput 108.3mbit    @avg 15ms latency
nv2 + nstreme + 80211 @135mbit throughtput 108,4Mbit  @avg 16ms latency
charliebrown
Sat Jul 24, 2010 1:44 pm
Can you please post wireless config and link information? Distance, Signal etc?
From your post it seems that NV2 only made a difference in a Dual Chain setup and even then a tiny difference
ste
Sat Jul 24, 2010 2:19 pm
This is great news. My long time wish of stations autoselecting nstreme on/off
has come true :D
mishaM
Sat Jul 24, 2010 2:58 pm
i test link on 6 km distance , 433ah bords and r52n cards with one chain and 23 grid antenas . so i recive up to 69mb tcp and 94mb udp traffic , latency is leap from 3ms ,4ms ~ to 20~35 , link stability is wery bad ! .. what time is going out -- link stability spoil and spoil and some time latency reach up to ~3000ms.
adrianatkins
Long time Member
Long time Member
Sat Jul 24, 2010 11:00 pm
Let's be scientific and not fan boy
Quite right.
It's Sour Grapes with me:-
I bought a load of Airmax when it was released, and at that time it did not work, and neither could the kit be used for CPE on non-Airmax either.
There was no way to get the money back, or to make it work for about 6 months, which made me slightly unhappy.
charliebrown
Sun Jul 25, 2010 2:42 am
Seriously? Whats next? Wanting Motorola Canopy compatibility?
npero
Sun Jul 25, 2010 9:55 am
Anyone have tested on x86 on 802.11n link ?
I can't get it work properly have low speed and disconnect, on some link WDS+nstreme work ok.
Also after changing some parameter on wireless interface router restart.
avantwireless
Sun Jul 25, 2010 7:33 pm
Sorry to hijack the thread, but the comment on compatability is right. Mikrotik working with Ubiquiti is so much stronger than proprietary protocols. The battle isn't between Mikrotik and UBNT but between wireless and AT&T or comcast or whatever else competes with wireless. Standards create markets. Proprietary limits markets. Every proprietary non-wireless protocol was swept away by ethernet regardless of the advantages and the networking world advanced. Standard means more production of the base chipsets and lower prices means more penetration. Please work with UBNT and the other vendors we'll keep using Mikrotik for the great routing and features that are beyond what UBNT is offering and we'll grow faster and by more!
RK
Long time Member
Long time Member
Sun Jul 25, 2010 10:35 pm
uldis, will we be able to assign time slots to individual clients using this TDMA system?
As in, will I be able to assign more important clients a large % of the air time so they get good performance even when the link is under high load?
Equis
Forum Veteran
Forum Veteran
Mon Jul 26, 2010 3:54 am
Hello
is TDMA support a high number of cpe clients?
Nstreame is good for 60 +/- how bout this new protocol?
ste
Mon Jul 26, 2010 10:51 am
First tests look promising.
Testsetup 2xRB411ah/R52n/V+H Antenna on desk.
AP/Bridge -> Station, 5GHz only N, datarates=default
UDP Test receive gives 192MBit. Ping while test runs is at 8-14ms.
Stopping bandwith test ping goes *up* and stays up and shows
varying results. Pings differ from AP->Client/Client->AP.
Starting Bandwith test again ping go down to 8-14ms-
Looks like bandwith test influences nv2 parameters which do not
adapt back.
Doing same test with nstreme gives 120MBit and dropping connections.
So nv2 is more stable in this config. Got not a single disconnect while
testing. But there are some tweaks needed to give stable pings.
Using nv2 Tx-Signal Strength is not shown.
charliebrown
Mon Jul 26, 2010 12:06 pm
Can you do TCP tests? UDP is almost always insanely higher than real world TCP data
angboontiong
Mon Jul 26, 2010 3:38 pm
can post the right configuration here instead of just announce that's a new protocol for this ?
uldis
Mon Jul 26, 2010 4:45 pm
Hello
Protocol limit is 511 client.
Yes you can connect a lot of clients to the AP, but note that the throughput and the latency could get worse.
uldis
Mon Jul 26, 2010 4:53 pm
Wireless-protocol setting info.
When the card is in the AP mode:
nv2-nstreme-802.11 - AP will use Nv2 as it uses the first what is in the row
any - it will use 802.11 or nstreme depending if you have specified the old setting enable-nstreme=yes
When the card is in the Station mode:
nv2-nstreme-802.11 - first will look for the Nv2 AP, then nstreme AP and then regular 802.11 AP
any - it will choose the AP without any special sequence; the sequence can be altered by the use of connect-list
doush
Long time Member
Long time Member
Mon Jul 26, 2010 5:25 pm
You are right. Even 802.16d had a horrible death.
Mix and match has to be the priority of the vendors.
frontiersteve
Mon Jul 26, 2010 8:03 pm
I agree, I like mikrotik as well. Cooperation would be splendid.
On different note, I changed over my 802.11n wds ptp link to nv2, and lost remote connectivity. I switch it back and everything goes back to normal. I think this might be due to it not supporting wds in this mode. Does anyone know a quick way around this? I would like to implement tdma and not lose remote connectivity due to wds being down on my link.
normis
Mon Jul 26, 2010 8:08 pm
you need compatibility only if you will use different brands of products with some specific technology that's not a standard (if you use 802.11b everywhere, no problem with compatibility). why do you use different brands? because other-brand cpe's are cheaper? mikrotik is working on that
uldis
Mon Jul 26, 2010 8:45 pm
unfortunately Nv2 doesn't have support for WDS yet. For now you could make MPLS/VPLS tunnel across the link and then you could easy switch between the wireless protocols.
xxiii
Mon Jul 26, 2010 9:17 pm
Most people so far seem to be looking at this from a throughput point of view; I'm more interested in the reliability point of view:
Here is a too brief ping test I performed just now:
NV2:
Ping statistics for 10.23.22.1:
Packets: Sent = 100, Received = 99, Lost = 1 (1% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 300ms, Average = 48ms
802.11:
Packets: Sent = 100, Received = 96, Lost = 4 (4% loss),
Minimum = 13ms, Maximum = 1531ms, Average = 174ms
nstream (via protocol drop-down)
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Minimum = 10ms, Maximum = 272ms, Average = 43ms
This link is being unusually well behaved right now. In the late evenings it is frequently bad enough to be unusable. I will leave it in nv2 mode for a few days and see how it does.
Personally, I prefer stable links with occasional high latency to ones that drop packets or the entire link all the time; thus hiding packet loss (typically by retransmitting behind the scenes until the packet gets through, and thereby converting packet loss to the appearance of a lower throughput link), than links that pretend they are fast, while having 60% packet loss. I'm hoping this is what nv2, being TDMA, will give me. 802.11 pretends to work this way, but usually just drops the link instead (after a limited number of failed retrys). (Basically, I'm describing Canopy vs nearly everyone else).
ste
Mon Jul 26, 2010 10:19 pm
No. Because they are cheaper and smarter. You've to update your RIC-line of Products.
Dreams of a Wisp:
- get the cpe from MT, don't touch it give it direct to the Customer. cpe gets all it needs from AP
- Customer can install cpe by looking at LEDs while mounting it
He can see that there is power and/or connection without calling/connected pc
- no crimping, simple slider to tighten Ethernetcable
- no try and error to find wireless parameters, working defaults
- 2 different cpes, small for short range, bigger for long range
- cpe needs to look smart and not cheap
- RF-Engineered (Metal housing, good antennas)
Your products *are* cheaper when we have less work to install/manage them.
ihernandez
Mon Jul 26, 2010 10:55 pm
I just wish to know if I can use XR5 cards
Regards,
Ignacio
uldis
Mon Jul 26, 2010 11:10 pm
Yes, is also working on those cards and regular R52 cards.
adrianatkins
Long time Member
Long time Member
Tue Jul 27, 2010 1:53 am
511 is the protocol max ?
what is the other bit for ?
Broadcast ?
charliebrown
Tue Jul 27, 2010 2:56 am
all this sounds ok if you build a wirelss network from the scratch
but we allready started with that business more than 10 years ago
and i cant change alle clients ...
an as we do also many competetors have grown networks - and also use UBNT cpes
as they do their job for a fair amount of money - sorry but money is a big argument
and also the offer of a complete cpe inlcuding antenna and alectronics in one part
without any frickeling around ....
i know that there are mikrotik based cps on the market but they are more expensive
so why not giving the compatibility tdma a chance ??
it dont think that it is that complicated...
In my experience UBNT CPE have a higher TCO when you're doing advanced functions. You may get around the install issue by having the client install it themself but in my experience 30-40% of the time you'll need a tech to go back onsite and realign it. If you want simple CPE then you need to run a simple network either pure UBNT or pure 802.11. Inter operation is complex, You'd need UBNT and MT to work together on a standard or combining their TDMA spec and then you as the operator would have to undertake a huge compatibility testing rig to check everything works and even then when you have a fault you still have to question a compatibility issue.
And if your dealing with a legacy network then tough, Work around it. Theres no reason why a pure MT network can be installed around/over the top of a legacy wireless network where new services for existing clients would require a CPE upgrade/change. Its not MT's job to build your network for you. Harsh I know but its painful reading everyone wanting MT to be compatible with their Toaster or that their CPE doesnt have this or that, UBNT are cheaper for CPE because the feature-set is extremely limited when you compare it to MT. Once again MT isn't here to build your network for you, Its upto you to shop around for the CPE option that suits you the best and every option has it's pro's and con's so you have to look at them and figure outs whats best for you
ste
Tue Jul 27, 2010 12:47 pm
i would rather not use ubnt... but point me to a dual polarity CPE for < $100 that doesnt take 30 mins to assemble, configure, and look all messy when its done. when there is a nice mt cpe then I will switch back to all mt. thats why it would be nice for them to interoperate for the time being (on links > 17km).
Yes. The RIC-series needs a strong update. The integrators do not deliver a pleasant device.
normis
Tue Jul 27, 2010 1:35 pm
ok, please read the forum rules. this forum is for discussing MikroTik products. It would be much more helpful if you all would stick to the topic, and tell us what's to improve (except compatibility, because that will never happen)
Muqatil
Trainer
Trainer
Tue Jul 27, 2010 3:26 pm
Will be created a nv2-dual like nstreme-dual?
Renato Bernardi
skype: medtech5
odie
Tue Jul 27, 2010 5:06 pm
no problem staying to the rules !!
but if you would like to sell more of your products you should also here to your customers !!!!
we have many hundreds of your devices in use !
and we need an affordable client
we have this wish since years now - and where is your answer ??
rb 411 ? - which enclosour - which antenna - powersupply .....
we have no time to build our cpes - we want to by them - but with some quality and a resonable price ...
why dont you build a device like the nanostation -
the ric was ok - but quality is not good - the first ones fall off allready - they dont stand the UV and the weather
and the white cover starts to brake ....
PTP devices ar not the problem - here we use only mt products in antennas with included housing from huber&suhner
not cheap but verry good !
missinlnk
Tue Jul 27, 2010 5:11 pm
Broadcast ?
The AP itself?
nz_monkey
Tue Jul 27, 2010 5:25 pm
Wow a lot of people moaning about nothing in here.
Low cost Mikrotik CPE, easy.
1x Mikrotik RB711
1x Poynting WLAN-A0056
1x All in one PSU/POE Injector
All designed to fit together, no screws, no hot glue, it all snaps together in less than 10 minutes. And based on estimated pricing this will cost USD $100, which in my opinion is damn cheap for a CPE that has such an extensive feature set.
What Mikrotik are doing with Nv2 is proof that they listen to their customers, they are implementing TDMA, it works on a/b/g cards as well as n, it has adjustable time slots and to top it off they have added a mechanism for the CPE to automagically select the wireless protocol. All are features that have been mentioned on these forums.
angboontiong
Tue Jul 27, 2010 6:29 pm
so far..
we test a 11n link with MPLs setup...
with only MPLS, the link can carry 6Mbps full duplex TCP traffic when using the bandwidth test tools to test it...
with NV2 + MPLS, the link can carry 15Mbps full duplex TCP traffic when using the bandwidth test tools to test it...
in our here, the frequency is damn congested no matter what frequency range you running on.. i also dunno how come... ^_^
BTW, i going to setup another 4 link and test it out with the 11a card... anywhere... great job Mikrotik..
cheers...
catato
Wed Jul 28, 2010 4:44 am
Hi, this is a snapshot of my configuration, is a 44km PTP with rb433 r52hn antenna Kozumi (28db V / H).
was improved in 8mb
disabled csma
protocol= nv2
tdma period size = 10 (is 10 because 2 was unstable and 7 smaller bandwidth)
Extension Channel = HT BELOW CONTROL
distance = 44
adpative noise inmunity = ap&client
sorry for my English, it is my first post.
normis
Wed Jul 28, 2010 9:29 am
petro, you are on beta4. this topic is about specific improvements on beta5 and a new protocol called nv2. please stay on topic.
doush
Long time Member
Long time Member
Wed Jul 28, 2010 4:39 pm
Does nv2 disable CSMA ?
angboontiong
Wed Jul 28, 2010 5:52 pm
Normis...
we tested it with the R5h card...
the result is bad... and also, the V5.0Beta5 is not suitable for the wds mode..
when we downgrade it back to the V4.10, the wds back to the normal...
normis
Wed Jul 28, 2010 7:43 pm
Vincent, uldis clearly said - WDS IS NOT SUPPORTED, please, there is no use testing nv2 with wds because it is not supposed to work!
angboontiong
Thu Jul 29, 2010 1:13 am
ops.. forgotten to said that, we tested the R5h card with mpls setting and it getting bad result instead of wds setting...
Beside this, the V5.0Beta5 is not suitable for the wds setting also.
normis
Thu Jul 29, 2010 10:05 am
Vincent, this topic is only about NV2 feature!
RK
Long time Member
Long time Member
Thu Jul 29, 2010 10:06 am
As in, will I be able to assign more important clients a larger % of the air time so they get good performance even when the link is under high load?
RK
Long time Member
Long time Member
Thu Jul 29, 2010 10:14 am
There is no question that Mikrotik's software is far superior to the "other guys." The problem is that you have fallen far behind on the hardware and I think you are seeing that in your sales numbers.
You need an all-in-one, or at least modular, MiMo CPE device with LEDs for basic diagnostics.
"My Internet is off"
"Are any lights on?"
"No"
"Is the electric cable plugged in?"
"Oops, my cat moved it."
After my technicians started simply screwing Bullets to panel antennas, they began referring to the years when we assembled RooTennas with routerboards as the dark ages.
The RB711 is a good start, but it's neither MiMo nor has an antenna.
normis
Thu Jul 29, 2010 10:44 am
No, you are wrong :)
nz_monkey
Thu Jul 29, 2010 11:59 am
haha, not just WISP's use Mikrotik products.
Im pretty sure any loss in CPE sales was more than made up for in sales of RB450, RB750, RB1000, RB1100 products ;)
ste
Thu Jul 29, 2010 12:12 pm
I love to say: You're far off topic :lol:
I would like to see this discussion in another thread at it's worth
to be done.
uldis
Thu Jul 29, 2010 12:34 pm
Currently not, but in future we might add this feature.
ste
Thu Jul 29, 2010 12:41 pm
Does the access-list AP Tx Limit/Client Tx Limit work with nv2?
uldis
Thu Jul 29, 2010 2:42 pm
No, they don't work yet.
angboontiong
Thu Jul 29, 2010 3:52 pm
Normis..
what's the routerboard should apply for this new feature test to get best performance..
and it should couple with what type of the card..
with such infor, then only we can provide the useful data for your reference...
we have a lot of site can test it and can allow you to remote it for fine tuning...
uldis
Thu Jul 29, 2010 3:59 pm
angboontiong, you can use any RouterBoard - all depends what kind of traffic you want to push through and at what speed. You can use any Atheros N card if you want to use N protocol or you can use regular A/B/G Atheros card.
chapex
Thu Jul 29, 2010 6:51 pm
nice improve! ... is good news. Surely the protocol greatly improved with the advance of time.
regards
Ubnet datacenter: bandwith transport
jcem
Sat Jul 31, 2010 12:16 am
I have a testlink in my office with v5.0beta5
RB411 with r2n
RB433 with r52n
with a 2Ghz link an nv2 my whole network goes down
with tons of collisions.
this is an edge link - nothing connected to the RB411
and ethernet only for access to the RB433
when I swiched to 802.11 the problem goes away
what is this traffic? It can't be seen by torch....
normis
Sat Jul 31, 2010 8:16 pm
nv2 doesn't play nice. it wants the whole playground to itself.
jcem
Sun Aug 01, 2010 11:37 am
So how to avoid it?
How do I incorporate a nv2-link in my network
without it bringing it all down?
RGDS
adrianatkins
Long time Member
Long time Member
Tue Aug 03, 2010 12:16 am
Nice.
Any more details ?
You sound like a Canopy salesman working for MikroTik, and i like how that sounds.
normis
Tue Aug 03, 2010 3:21 pm
yes, this is because we use TDMA, in a similar manner as canopy.
adrianatkins
Long time Member
Long time Member
Wed Aug 04, 2010 2:31 am
Ah. So you have never worked with Canopy then.
I'm slightly dissapointed, but that should help those who think it will interfere with their 802.11a installations.
Unless it's on the same or adjacent channel, then it won't interfere at all.
Your statement about the 'Whole Playground' was a bit misleading.
TDMA-based will only want the nice bit with the Swings - the Slide and the Roundabout will still be available.
From what you've posted, i can only deduce that it is an 802.11n variant with TDMA overlaid, just like AirMax.
An earlier post suggested that it would be Great to have UBNT and MT co-operate on this.
I said No. Now i think i should have said Yes. Why invent 2 wheels when we use MT as AP kit and UBNT as CPE ?
Then again. maybe i'm as thick as a plank and a bit drunk, and smell.
xxiii
Wed Aug 04, 2010 11:39 pm
Ok, been running it for a couple of weeks, and so far I love it, when it works.
It has higher throughput with more stability, However, under heavy traffic the client radio seems to lock up.
Wirelessly, everything appears to be fine, but my bgp peer dies, and no traffic seems to pass. I can see the AP in /ip neighbor, so apparently packets can still be recieved, but attempts to mac-telnet to the AP will fail. If I disable and re-enable the radio, it reassociates but traffic still doesn't pass. If I then reboot the client, everything works normally for a while, until it happens again. It seems more likely to happen if the traffic is heavy, and takes anywhere from 5 minutes to an hour (or several hours or days, if traffic is light).
802.11n 2x1 with the two antennas on the client side.
client side, r52hn:
Flags: X - disabled, R - running eles
0 R ;;; chain 0 rx -75 chain 1 rx -71 both together -69
name="wlan1" mtu=1500 mac-address=00:0C:42:xx:xx:xx arp=enabled
interface-type=Atheros 11N mode=station ssid="xxx" frequency=2432 band=2ghz-onlyn
scan-list=default wireless-protocol=any wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=xxx
compression=no
0 interface=wlan1 radio-name="000C42xxxxxx" mac-address=00:0C:42:xx:xx:xx ap=yes
rx-rate="26.0Mbps-HT" tx-rate="13.0Mbps-HT" packets=728971,1075510 bytes=92547344,1316880575
frames=542358,1043764 frame-bytes=93289116,1300263050 uptime=13h1m23s last-activity=0ms
signal-strength=-75dBm tdma-timing-offset=67 tdma-tx-size=1008 tdma-rx-size=496 tdma-retx=40
tdma-winfull=0
ap side, r52n:
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:xx:xx:xx arp=enabled
interface-type=Atheros 11N mode=ap-bridge ssid="xxx" frequency=2432
band=2ghz-onlyn scan-list=default wireless-protocol=nv2
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
compression=no
0 interface=wlan1 radio-name="000C42xxxxxx" mac-address=00:0C:42:xx:xx:xx ap=no
rx-rate="13.0Mbps-HT" tx-rate="26.0Mbps-HT" packets=1075142,728512
bytes=1316846323,92239759 frames=1043407,541944
frame-bytes=1316992303,70794244 uptime=13h20s last-activity=0ms
signal-strength=-84dBm tdma-timing-offset=67 tdma-tx-size=496
tdma-rx-size=1008 tdma-retx=36 tdma-winfull=0
uldis
Thu Aug 05, 2010 12:07 pm
in the next release of the beta version there will be a fix for the Nv2 link lockup problem.
angboontiong
Thu Aug 05, 2010 1:13 pm
Uldis..
another issue is, in the V5.0Beta5, if we key in following channel scan list into the wireless equipment..
it not able to link up, to resolve it, we have to cut short the number of frequency to be scan in the scan list
"5150,5160,5170,5180,5190,5200,5210,5220,5230,5240,5250,
5260,5270,5280,5290,5300,5310,5320,5330,5340,5350,5360,5370,
5380,5390,5400,5410,5420,5430,5440,5450,5460,5470,5480,5490,
5500,5510,5520,5530,5540,5550,5560,5570,5580,5590,5600,5610,
5620,5630,5640,5650,5660,5670,5680,5690,5700,5710,5720,5730,
5740,5750,5760,5770,5780,5790,5800,5810,5820,5830,5840,5850"
The above scan list is work well in the V4.11 with the MPLS or WDS setting.
normis
Fri Aug 06, 2010 11:54 am
Vincent, does this question relate to NV2? If not, post it as a new topic!
angboontiong
Fri Aug 06, 2010 12:21 pm
Normis...
Yes, it we put the wireless protocol to unspecified then having no issue on this.
uldis
Fri Aug 06, 2010 12:23 pm
Normis...
So you add that ling scan-list enable the wireless-protocol=nv2 on the client and it can't connect to the AP? What does the log say when you enable wireless,debug logs?
On what frequency is the AP?
angboontiong
Fri Aug 06, 2010 3:29 pm
Normis...
Hi Uldis..
i tried to use the 5150Mhz to 5850Mhz with MPLS+NV2 setting, it totally not able to connect..
but when i cut the scan list channel and remain 1/4 of it, then no matter what range of the frequency, it can connect.
in the wds or the MPLS only, i having no issue with this.
Anywhere, 1 thing i have to highlight here, the NV2 is very good feature and it's work great, if the channel scan list issue can solve, then it will wonderful.
uldis
Fri Aug 06, 2010 3:35 pm
angboontiong, please enable the wireless,debug logging on the client and make the support output file after it can't connect. Also make the support output file from the AP. Send both files to support@mikrotik.com
We tested that long scan-list in the one nv2 client and it was able to connect to the AP.
angboontiong
Sat Aug 07, 2010 5:45 am
Hi Uldis..
ok, i will do it and send it to support, btw, what's the maximum number of the channel for the scan list?
Mplsguy
Sat Aug 07, 2010 8:24 am
There are no explicit limits for scan-list length, but still it is better to keep it shorter - the shorter it is, the faster full scan will complete. Indeed there is a problem with nv2 and long scan-lists that will be fixed in next version. Take into account that scan for nv2 networks takes approximately two times more time and this was not accounted for, therefore the problem with connecting with nv2. For now you can use shorter scan lists.
xezen
Long time Member
Long time Member
Sat Aug 07, 2010 8:26 am
any idea on v5.0beta 6 will be avalable?
If i dont No Ask someone That Does!
uldis
Sat Aug 07, 2010 4:46 pm
most likely next week
FIPTech
Sun Aug 08, 2010 12:06 pm
How is achieved synchronisation on this TDMA system ? Is there a high precision clock on Wifi boards ? A master / slave system with a PLL on each station ?
If each station is running free wheel, how can they synchronise correctly with each other ?
angboontiong
Mon Aug 09, 2010 3:46 pm
Another issue is..
is the MPLS work with NV2, it can up to 80Mbps full duplex (TCP)...
but one thing is, when do the bandtest, it up to the 70Mbps full duplex, we stop the bandtest, the link will drop but you can see it's in the registration table, but not able to MAC telnet, MAC ping, and also telnet such thing..
and we have to wait for may be 1 min, then only the link will come back..
for more information..
is the bandtest, the throughput < 70Mbps, it will having no problem at all, the thing is, you have to keep the signal range no lower than -50 the best is -52dbm ~ -60dbm
normis
Mon Aug 09, 2010 3:47 pm
By the way, somebody should test NV2 in a Point-to-multipoint scenario, with multiple clients. This is where TDMA should really shine
Muqatil
Trainer
Trainer
Mon Aug 09, 2010 4:39 pm
While i'm impatient to test it in a real enviorment, i've to upgrade all the routers to 5.beta5 which scares me a little..
And the chance to have to go to the customer and reset the CPE is a lot of work..
Just waitin some more betas before testing it..
Just a question.. If i upgrade only one AP (on a site of 4 AP), does it interfere with the other 3?
Renato Bernardi
skype: medtech5
uldis
Mon Aug 09, 2010 5:13 pm
problem with the Nv2 link locking/stalling will be fixed in v5.0beta6, which will be released this week.
ste
Mon Aug 09, 2010 5:24 pm
This will be an interesting point to look at. As nv2 is told to be more aggressive it may do more
interference to nearby sectors.
Thanks to the new wireless settings the sector can be switched back to nstreme/plain 802.11 with one setting
at the ap ...
uldis
Mon Aug 09, 2010 5:35 pm
if you use different frequency on other APs on the same tower it will not cause any problems. And even if they are on the same frequency, usually they point to different directions. And as ste wrote, you can easy change from Nv2 to Nstreme/802.11 with one command, as in the client side you can specify the wireless-protocol=any
FIPTech
Mon Aug 09, 2010 9:52 pm
"By the way, somebody should test NV2 in a Point-to-multipoint scenario, with multiple clients. This is where TDMA should really shine"
that's true. TDMA is absolutly unusefull on duplex point to point links, when a different channel is used for transmitt / receive.
TDMA is interesting really when multiple stations want to go online at the same time. Then each one take a time slot without collision. This does allow a true QOS.
As opposite, CDMA based systems exhibit collisions as soon as the number of clients and consummed bandwith rise. CDMA can be compared to an Ethernet networks with hubs instead of switches.
Nevertheless, i doubt that conventionnal Wifi hardware can do a true TDMA network, because there is no precision master clock like a GPS clock on each station. Something we can find on GSM networks.
I suppose that the pseudo TDMA mode of wifi does use the access point as the master clock, and the clients synchronise on it with a PLL.
In this case, the clients need to have a good reception, to have a clean signal to extract clock from.
chainsawman
Mon Aug 09, 2010 10:19 pm
Currently NV2 works perfectly for me.
Even the links that were not functioning due to interference now are ok.
Is there any provision for correction of WDS?
Muqatil
Trainer
Trainer
Tue Aug 10, 2010 10:22 am
Testing NV2 on a troublesome link over sea
The link is done with dualpol antennas and R52Hn.
Without nv2 the link was unstable due the evaporation and other shit related oversea links. max rates were 52mbps-HT, dropping frequently.
With nv2 rates jumped to 216mbps-HT and really stable. As already noticed, the link locks up. Waiting for the next release.
Renato Bernardi
skype: medtech5
wildbill442
Wed Aug 11, 2010 12:12 am
Well done MT!
I tested on the following hardware (identical @ both sides)
RB411A
R52N
ARC Dual Pol Antenna/Enclosure (2x2 MIMO)
Link distance ~7miles
ROS V: 5.0beta6
I ran the bandwidth tests FROM the router, so if i had tested through the router I may have been able to achieve higher throughputs.
NSTREME ENABLED
Polling: ENABLED
Disable CSMA: ENABLED
Framer Policy: None
Framer Size: 3200
Signal: -74/-75
No load Latency:
112 packets sent 112 received 0 lost
min: 0 avg: 0 max: 3ms
TX TEST:
10s AVG: 25.1Mbps
AVG: 26Mbps
Latency: 113/113 sent/received min: 27 avg: 39 max: 89ms
RX TEST:
10s AVG: 31.9Mbps
AVG: 31.2Mbps
Latency: 110/110 sent/received min: 15 avg: 24 max: 40ms
TX/RX TEST:
10s AVG: 15.0/14.0Mbps
AVG: 11.8/12.3Mbps
Latency: 112/112 sent/received min: 42 avg: 96 max: 344ms
NV2 ENABLED
2ms TDMA period size
Signal -74/-73dB
No load Latency:
170 packets sent 170 received 0 lost
min: 1 avg: 5 max: 8ms
TX TEST:
10s AVG: 37.2Mbps
AVG: 35.6Mbps
Latency: 94/94 sent/received min: 2 avg: 9 max: 32ms
RX TEST:
10s AVG: 38.2Mbps
AVG: 38.0Mbps
Latency: 132/132 sent/received min: 3 avg: 11 max: 53ms
TX/RX TEST:
10s AVG: 13.5Mbps / 24.7Mbps
AVG: 13.5Mbps / 25Mbps
Latency: 129/129 sent/received min: 4 avg: 16 max: 60ms
As you can see there's a definite increase in throughput and QOS - latency is much more consistent even on a PTP link w/ the new TDMA powered NV2. The results, again, might be limited to the RB411A's processor because I ran all tests from the RB411A. However, it served the purpose of showing consistent throughput and latency w/ NV2 enabled.
I'll see if I can find an area to test NV2 in a PTMP environment.
William Burnett
Network Engineer
wildbill442
Wed Aug 11, 2010 12:23 am
Will NV2 support full duplex links?
I have a NSTREME DUAL link I'd like to try this on... Not sure if NV2 was designed or ready for this type of implementation...
William Burnett
Network Engineer
wildbill442
Wed Aug 11, 2010 4:05 am
I did some PTMP tests with 2.4GHz-G only mode 20MHz channels...
only 3 CPE's connected to the AP, but the average latency when throwing everything i had at the CPE's was still 16ms...
And I was able to get 2.5Mbps synchronous off an RB133 board... about 6-7Mbps asynchronous... If only I had a higher powered board at this site I bet I could post better throughput results. I'm excited to see this go to stable release!
I have another site that has about 25 clients with some heavy users (3Mbps+) in the 2.4GHz band currently using NSTREME.. if this proves stable enough on the smaller deployment i'll test it out on the larger.
William Burnett
Network Engineer
wildbill442
Wed Aug 11, 2010 4:21 am
@NORMIS or ULDIS
Found a little bug:
When using NV2 protocol - security profiles are overridden. I use RADIUS for MAC-Authentication and it will not authenticate when mode is set to NV2. ROS only consults the local ACL and if the MAC is not present it rejects authentication from the client.
If I have it set to 802.11 or NSTREME they connect and authenticate via RADIUS just fine...
William Burnett
Network Engineer
normis
Wed Aug 11, 2010 7:50 am
William, in beta6 we have a new latency optimization system, see newsletter
wildbill442
Wed Aug 11, 2010 8:08 am
Yeah the newsletter is what prompted me to test the newer beta release. Any ideas on the RADIUS issue? Do you need a supout?
Also SNMP appears to be broken in 5.0beta6...at least for monitoring interfaces.
William Burnett
Network Engineer
angboontiong
Wed Aug 11, 2010 5:04 pm
Normis...
Nowday, If the last miles latency is higher than 10ms, customer will keep asking on it and they starting to compare it, and this also one of the UAT benchmark for them.
The latency is possible to make it <5ms no matter what throughput running on the wireless bridge? hope can heard the good news from Mikrotik in the next release.
and the other issue is, as what we tested, the max throughput for the RB433 in NV2 is...
1) TCP: 23 Full duplex (up 23Mbps and down 23Mbps concurrent),
2) UDP: 40 Full duplex (up 40Mbps and down 40Mbps concurrent).
Is this due to the processor issue? and Is the RB433AH can double up the throughput?
aprinou
Thu Aug 12, 2010 5:03 am
well this was my first test with the new protocol using only NV2 with a rb 433, R52N card, a distance of 20km, there are tests using a network in MPLS-VPLS-OSPF, test mode 5Ghz N-20Mhz, Channel 5745 . Now also did the test mode 5Ghz only on the same channel 20Mhz 5745.
ANDRÉ PRINOU.
SUPORTE TÉCNICO REDES E INFRAESTRUTURA DE SISTEMAS.
CONSULTOR OFICIAL MIKROTIK MTCNA, MTCTCE, MTCRE.
CERTIFICADO DCP WIRELESS D-LINK.
ADMINISTRADOR DE REDES MICROSOFT, LINUX.
065-9241-0294
NOVANET PROVEDOR DE CAMPO NOVO PARECIS.
ste
Thu Aug 12, 2010 3:59 pm
Hi MT,
some questions regarding NV2:
- How does TDMA Period Size work?
Default is 2 seems to give ping 5-6ms on idle link
Set it to 1 gives ping 3ms on idle link but lowers bandwidth test results.
Seems to be the slice duration until the next station is allowed to send?
So what happens when there are 10 stations registered but idle. Does ping
increase to up to 20? (Station waits at max 10 slots to send ping and at
max 10 slots to receive answer).
- CPU impact compared to nstreme / plain 802.11
Does it make sense to use nv2 or nstreme or 802.11 when there are old 133-Boards
as clients?
- Pinging from station to bridge/ap gives much higher response times than the
other way round. Is there a way to bring this down below 10ms?
Using nstreme pings are at 2ms switching to nv2 its between 18 and 37.
1 AP 2 clients connected, no traffic.
Thanxs,
Stefan
aprinou
Thu Aug 12, 2010 6:05 pm
What I realized was that following this first test of the season to ping the ap-bridge the ping varies between 5 and 12 to 15ms, while ap-bridge station to ping below 5ms with traffic is stable pings below 6ms, this still does not know how I can because I am in mellhorar test further believe that without traffic has to be below 3 ms, because without using the NV2 that my test drop below that much of a tip as the other.
ANDRÉ PRINOU.
065-9241-0294
wildbill442
Thu Aug 12, 2010 6:14 pm
Another issue in 5.0beta6 w/ NV2
In the two ptmp environments i've installed it on the users disconnect after about 12hrs and will not reconnect unless the interface is disabled/re-enabled.
I forgot the disassociation message that appeared in the logs - but it was pretty generic.
The point to point link I have setup seems to work fine w/o issue.
William Burnett
Network Engineer
normis
Fri Aug 13, 2010 1:42 pm
Are both sides beta6? can you send us the supout.rif files that you made after the disconnection has happened, before restoring the connection?
aprinou
Fri Aug 13, 2010 5:15 pm
Another thing I noticed when the test is in the TCP cpu goes 100% even auditioning for band 5mb in both.
ANDRÉ PRINOU.
065-9241-0294
wildbill442
Fri Aug 13, 2010 8:31 pm
Yes all sides were beta6. I forgot to make the supout.rif -- I'll switch them back to NV2 (standard NSTREME was more stable) and generate it when they disconnect. You should have it in about 24hrs.
Also -- Any idea why RADIUS MAC authentication doesn't work w/ NV2? It seems to work fine with any other protocol, just not w/ NV2.
William Burnett
Network Engineer
Equis
Forum Veteran
Forum Veteran
Sat Aug 14, 2010 12:09 am
I seen this also, it seems the more clients the quicker it happens
x86 ap
b6
wildbill442
Sat Aug 14, 2010 8:37 am
Just submitted a supout.rif.
William Burnett
Network Engineer
iw4eky
Mon Aug 16, 2010 4:38 pm
Hi guys,
as I did for 802.11n protocol (look at this post), I post below some screenshots of my test link using Nv2.
Compared to 802.11n results in the very same conditions and hardware in use, I got better results with this new Nv2 protocol expecially on fullduplex links (100Mbit/s instead of the previous 65Mbit/s with 802.11n!!!), CPU usage is higher but ping time is much much lower. I got worse results only on TCP speeds, but that was limited by CPU and I would have got better results if I cascaded two RB1000 after my test boards.
Well, so far a very good improvement from Mikrotik, thank you guys!
SCENARIO
AP and STATION: RB433AH and R52n radios inside outdoor metal boxes with u.fl-N pigtails
Antennas: Jirous JRC-24 DuplEX
Distance: 4km with perfect LOS
Mikrotik parameters (see my previous post for details)
Security profile: WPA2-PSK AES
Wireless protocol: Nv2
Hw retries: 15
RESULTS:
Highest UDP half duplex speed: 200Mbit/s stable and simmetric on downlink, 165M avarage on uplink, CPU average load @ 33%, average ping @ 13ms
Highest TCP half duplex: 59Mbit/s stable on downlink and 61Mbit/s on uplink , CPU average load @ 100%, average ping @ 5ms
Highest UDP full duplex speed reached: 100Mbit/s stable on both downlink and uplink, CPU average load @ 71%, average ping @ 8ms
Highest TCP full duplex speed: 40Mbit/s stable on both downlink and uplink, CPU average load @ 100%, average ping @ 5ms
Bye,
mattia
lallo
Tue Aug 17, 2010 10:14 am
Hey iw4eky! A very good result!
If we could meet during the next MUM I would be very proud to shake your hand!
Stay on the piece!
Bye.
LALLO
Muqatil
Trainer
Trainer
Tue Aug 17, 2010 1:16 pm
I experienced the same problem, but forgot to supout.
Will make it next time it happens
Renato Bernardi
skype: medtech5
mercurial
Wed Aug 25, 2010 6:48 pm
We installed a 16 km link PTP in side A RB433, with a card RB52Hn, 32dbi solid dish, on the side B RB600 with Xr5 card and 32dbi solid dish
signal strength -81 dBm
CCQ% 90
Noise: -103 dBm
protocol: NV2 Nstreme
band: 5ghzA
TxRate: 14mbps
TrRate: 12Mbps
juliano
Thu Aug 26, 2010 9:44 am
We put this new NV2 to work in 2 different set of links:
1st: I'ts a 16km long link.
2nd: It's our newest darling, 100km long link.
In the 1st one, it has been working flawlessly for 3 days in a row and we got for our complete surprise (since it's a PTP it does not get all the benefits of TDMA) a huge increase not only in bandwidth availability (in order of 30/40 increase) but ping times seems to stay very stable even when running at full speed and not a sign of the usual disconnections when you reach max bandwidth limit.
In the 2nd one, sadly we got no results since the station refuses to stay connected to the AP when setting the wireless-protocol to the NV2 or NV2-nstreme.
When enabled the NV2 option will generate several in a row messages:
03:10:54 wireless,info 00:0C:42:XX:XX:BA@wlanV established connection on 5395, SSID BrAP1
03:10:59 wireless,info 00:0C:42:XX:XX:BA@wlanV: lost connection, ranging timeout
03:10:59 wireless,debug wlanV: must select network
03:10:59 wireless,debug 00:0C:42:3A:XX:XX: on 5395 AP: no SSID BrAP1 caps 0x0 rates 0x0 basic 0x0 MT: no
03:10:59 wireless,debug wlanV: no network that satisfies connect-list, by default choose with strongest signal
03:10:59 wireless,info 00:0C:42:XX:XX:XX@wlanV established connection on 5395, SSID BrAP1
03:11:06 wireless,info 00:0C:42:3A:XX:XX@wlanV: lost connection, synchronization timeout
We got several ranging/sync timeout messages, we tried all kind of settings in both the AP/station.
Link runs smoothly when "old-nstreme" is set.
uldis
Thu Aug 26, 2010 10:21 am
juliano, make the support output files from both ends after the link is disconnecting and send it to the support@mikrotik.com so we could analyze them why they are disconnecting.
angboontiong
Thu Aug 26, 2010 4:54 pm
Hi Mikrotik..
another issue is, the hidden ssid feature is not working.
edege
Sun Aug 29, 2010 6:12 am
hello I have been using Nv2 in v5.0beta6 for about a week now. I have a PTMP with 3 Clients on it. I loaded Nv2 in v5.0beta6 on the Clents as of the AP and updated the bootloader as well. It dose seems to work alot better when it works after about 30mins or so the AP Locks up and I have to go in there and reset the wlan1 and then everything comes back up for 30mins or so. I have tryed it under Nv2 Nstreme would run for like 5 to 15mins and then under Nv2 Nstreme 802.11 worked alot better. Any ideas why it would do that I do know that it was doing this on the clinets. "just giving you all some feed back" but for now I moved it back to Nstreme normal ver.
AP is a 433AH w/ xr9 at 10mhz (No over Clocking)
Clients are running 411AH w/ xr9 at 10mhz (No over Clocking)
normis
Mon Aug 30, 2010 8:49 am
when something "locks up" you should make a supout.rif file and send to us
juliano
Mon Aug 30, 2010 9:20 am
Uldis, support files sent!
Equis
Forum Veteran
Forum Veteran
Mon Aug 30, 2010 9:50 am
I also sent but had no response (except automated one)
ejansson
Mon Aug 30, 2010 5:25 pm
Is there any info or does anyone know the technical differences between the different Nv2 type (Nv2, Nv2 802.11, Nv2 Nstreme)
Any ETA on the next release and for 5.0 release ?
blake
Mon Aug 30, 2010 9:16 pm
http://forum.mikrotik.com/viewtopic.php ... 82#p219282
IT consultant. Network manager. Packet junkie.
1-928-328-1509
Erastus
Fri Sep 03, 2010 2:22 am
The reason why I use different products is that we have constant problems with the R52HN they got so hot it melt the socket of the 433AH.
normis
Fri Sep 03, 2010 1:05 pm
we have not hear about anything like that. can you send pictures to support ?
Erastus
Fri Sep 03, 2010 3:05 pm
Normis,
I returned a couple like that already and the unit was returned via the channels
normis
Fri Sep 03, 2010 3:18 pm
tell me the serial numbers and I will check the reason for the problem
Erastus
Fri Sep 03, 2010 3:26 pm
will get it
cybernet
Mon Sep 06, 2010 12:10 pm
Is it possible mikrotik-engineers and programers make package wireless NV2 for ROS 4.11 (or other stable version)?
normis
Mon Sep 06, 2010 12:36 pm
it's not possible, because it relies on many new things in v5.
cybernet
Mon Sep 06, 2010 1:51 pm
Cannot wait for ROS 5.x stable and NV2 WDS support. :)
jberen
Trainer
Trainer
Mon Sep 06, 2010 5:03 pm
which is the better configuration for the parameter tdma-period-size?
you can tell me any example?
Javier
CIBERNEK
pacman
Tue Sep 07, 2010 12:46 am
Just been trying out nv2 in my "lab" (well, ok the corridor of my flat!). It looks very promising - lovely stable pings at very high throughputs.
Does Mikrotik have any idea yet on when security will be possible with nv2? By that I mean, for example, wpa2.
cheers
Peter
Loop Scorpio Ltd
providers of rural broadband
uldis
Tue Sep 07, 2010 4:38 pm
Javier
CIBERNEK
here is some small info on Nv2 added, maybe it might help you:
http://wiki.mikrotik.com/wiki/Manual:In ... reless#Nv2
dibatech
nv2-cell-radius
Sun Sep 12, 2010 10:21 am
I'm trying to get 110Km link working with nv2. Getting lots of range timeouts. With usual nstreme the link is performing as expected.
Read that nv2-cell-radius might be the setting to tweak. I cannot find it in cmd neither gui.
Access is available for Mikrotik if they want to evaluate long distance performance as this is not a production link yet.
Any input appreciated.
temuri426
Sun Sep 12, 2010 11:22 pm
dibatech
you can manipulate with tdma-period size...
see link in the previous post........
dibatech
Mon Sep 13, 2010 9:01 am
Period size is not exactly the tool you would use to fix this. Size was adjusted up 10ms with no improvements.
Thank you in any case.
uldis
Tue Sep 14, 2010 1:42 pm
Please write to support, we will provide you with a test version where you could specify the range.
dibatech
Wed Sep 15, 2010 10:10 am
Tested a BETA version of the Version 5.0RC1 package to see if the the nv2-cell setting helps to fix the range-timeouts on a 110km link.
Guess what, it works. Well done guys.
Results:
Setup:
RB411U -> RB433AH
R52Hn Cards both ends.
29 dB Parabolic Dishes single feed.
Signal levels -77dB to -80dB
18Mbps/18Mbps clamped on card rates
Frequency: 5220Mhz
Length: 110 Km
TDMA period size = 4
Working well with nv2, nv2-nstreme and normal wireless protocol.
5GHz-20MHz Band Works
5GHz-10MHz Band Works
5GHz-5MHz Band Works
Bugs:
Cell radius in Winbox is wrong. Always reports 10km, but works via CMD.
Wireless registration quality of signal probably needs more work.
Stability 100% over last 14 Hours.
Further results:
[test@test] > /ping 172.21.200.34
HOST SIZE TTL TIME STATUS
172.21.200.34 56 64 5ms
172.21.200.34 56 64 4ms
172.21.200.34 56 64 7ms
172.21.200.34 56 64 6ms
sent=6 received=6 packet-loss=0% min-rtt=4ms avg-rtt=5ms max-rtt=7ms
*(While doing around 1 Meg. Bi-Directional)*
Bandwidth Test Results:
Receive TCP: 5Mbps
Send TCP: 8.9 Mbps
Both TCP 3.2/3.9 Mbps
ejansson
Thu Sep 16, 2010 4:18 pm
Any ETA on the release? We have a few sites we want to test the P2MP on (in WDS mode if possible) and are in dire need of more capacity on our AP's. Be happy to test and provide feed back on the previously mentioned wireless update.
tgrand
Long time Member
Long time Member
Thu Sep 16, 2010 8:39 pm
Been using RC1 for P2MP works great.
AP did freeze with neer frequency interference which was resolved.
ejansson
Fri Sep 17, 2010 2:58 am
WDS, Routed.... what type of setup are you using.... can you send me a copy?
ste
Fri Sep 17, 2010 10:38 am
I would like to use ap/client tx rates (access-list).
Users with lower tx-rates get fewer TDMA slots.
This will match better with price-modells.
Polky
Fri Sep 17, 2010 11:23 am
Hi, please where can I download the RC1?
Thank you, also tests P2MP.
npero
Fri Sep 17, 2010 11:42 am
Contact support and ask for test version.
Polky
Fri Sep 17, 2010 4:23 pm
Hey, the RC1 is still not functional bridge or WDS? (with NV2)
I tried AP brigde ---> pseudobridge station, but failed.
tgrand
Long time Member
Long time Member
Sat Sep 18, 2010 6:55 am
Torch always has 0 bps for TX.
WatchDog Timer will trigger if an IP address is specified, even though enabled is unchecked.
NV2 still freezes from time to time.
uldis
Mon Sep 20, 2010 4:57 pm
pseudobridge isn't working with Nv2. Use station-wds on the client side.
Polky
Mon Sep 20, 2010 9:11 pm
Thanks,
I have RB411AH (Nstreme) (5RC1) ----> RB600 (with RB604) (5RC1)
RB600 has 5 miniPCI.
1st Station - Nstreme
2.AP Bridge - 5 Ghz (802.11) (P2MP)
3 AP Bridge - 2.4 GHz (P2MP)
4 AP Bridge - 5 GHz (Nstreme) (P2MP)
5 AP Bridge - 5 GHz (Nstreme) (P2MP)
If the 5th AP Bridge switch to NV2 (all clients 5rc1) .. so after a few hours there is a wide irregular reboot RB600. If the switch back to 5.AP Nstreme, RB600 currently holds longer uptime 24 hours.
xxiii
Mon Sep 20, 2010 9:35 pm
There are actually two watchdogs, which isn't entirely clear from the winbox interface.
One, controlled by the enabled checkbox, which monitors the router itself, and the ping watchdog, which monitors an IP address. Its enabled if an IP address is present in the box, independently of the enabled checkbox. Some text or layout should probably be added to the winbox dialog to make this more clear.
jcremin
Tue Sep 21, 2010 7:45 am
Wow, I never knew that. I always just thought it was a persistent bug that it still rebooted when I unchecked the box but left the IP in there. Good to know!
mindaugasr
Tue Sep 21, 2010 8:48 am
I try 5.0rc1 and got worse results results than with 4.6 firmware and exe config wds+nstreame.
In 4.6 firmware ping on idle link is aprox 0.7 ms
In 5.0rc1 firmware (nv,nv nstreame and others) ping on idle link is aprox 4 ms
In 4.6 firmware connection rate link is stable 270/270
In 5.0rc1 firmware (nv,nv nstreame and others) bouncing from 54 to 160 and so on
Throuput also is 2 time smaller than 4.6
Can you give some advise what we doing wrong.
I you said nv2 have some improvements, but i don't see any advantages on 5.0rc1 only problems.
Thanks for advice
Best regards
uldis
Tue Sep 21, 2010 2:28 pm
mindaugasr,
contact support about this problem - include the support output files from both versions and description about your wireless link.
byteman
Tue Sep 21, 2010 7:01 pm
sorry for my ignorance, but if i set "nv2" protocol active, can i see other stations from Motorola or other in scan or frequency-usage lists?
another question, if its possible that in the RC1 i can not select 40Mhz channel bandwith, only 20Mhz?
Thanks a lot
ejansson
Thu Sep 23, 2010 3:51 pm
We are have lockup up problems on RB532 and related boards, including a kernal panic on a 112 (not that anyone cares about a 112). We seem to get 6-12hr before it locks up. We have a large number of 532 ap out there. I do not know at this point if the 400 series are effected in the same way as we have only loaded RC1 on clients and on the remote side of the P2P that has the 532 ap. Problems is present regardless of nv2 mode.
Will send supout.rif later to day once the unit has been rebooted and is accessable.
tgrand
Long time Member
Long time Member
Fri Sep 24, 2010 3:19 am
I can verify that on 433 and 411 Routerboards all appears to be working well so far.
The posted V5rc1 is performing Excellent over the Prerelease V5rc1.
We are using NV2 nstreme on 2.4GHz-10MHz.
We also have a backhaul link we are testing using 5GHz-only-N using NV2-nstreme and wds, and it is performing remarkably well also.
xxiii
Fri Sep 24, 2010 3:32 am
We tried nv2 on an rb532 and didn't work very well. Wouldn't stay associated for more than a few seconds if I recall properly. I'm not sure if it was the 532 or the wireless card (probably an r52 or r2). Its since been replaced with an 433AH which works much better. The 433 has an 11n card. Looking back at the 5.0Bx changelogs, I suspect it might have been the r52 or r2 that was the problem before.
Raf
Fri Sep 24, 2010 8:46 am
Don't use ROS v5.x on MIPS-LE boards. Throw those old and slow boards to trash and get a newer ones.
Rafał Wójcik from AWB-NET
High Definition enthusiast
ste
Fri Sep 24, 2010 9:57 am
We have several 100s of them in the field used by our customers.
It would take some weeks of work to replace them.
They are capable to route 10-15MBit/s of Traffic which is enough for
the average internet user. Why should a newer ROS/Linux make them
unusable? I guess newer SW should be better than older ;-)).
normis
Fri Sep 24, 2010 10:00 am
You can use v5 on RouterBOARD 100/500 (MIPS-LE), but remove all unneeded packages, disable as many rules as possible, don't keep Winbox open for long time, and try to optimize configuration as much as possible. These devices have less memory and less storage space.
chronos
Sat Sep 25, 2010 1:14 pm
Testing indoor on PtP link on v5.0rc1, both chains active, bridge mode, throughput is pretty good, stability seems to be much better than older nstream, latency is better but still pretty higher than to be expected from fast link without traffic. It is possible to further improve and lower latency?
I will do some real outdoor testing...
UDP half duplex test:
UDP full duplex test:
TCP full duplex test using iperf:
ejansson
Mon Sep 27, 2010 3:48 am
We have stripped the RB100 and 532 to the bones. No improvement the 532s have plenty of mem but 100's are tight we will likely replace them. The 532 is still not stable despite the changes and the the 411ap with some rb133 cpe's has locked up a few time and we have had some strange issue with the 133. The 532 to 411 back haul does not last past 12 hr and has minimal traffic.
We have a couple of 411 back hauls we are testing on and they seem much better with no disconnects yet after a couple of days.
ejansson
Mon Sep 27, 2010 5:24 am
On P2MP clients will not attach if any "B" data rates are set when up grading (10mhz nstreme G only). Removing the B data rate allow clients to connect.
ejansson
Tue Sep 28, 2010 2:48 am
Anyone tested on a 900mhz (xr9) setup .... had to back out as nothing would register on the AP (411AH)
jbowsher
Fri Oct 01, 2010 1:30 am
Can anyone tell me why i cannot select 40Mhz channel width on the wireless interface in routeros v5 rc1? It doesn't seem to matter what cards I use or what band I set it to, it always shows the error "Couldn't change interface <wlan1> - incompatible band and channel-width (6)" I tried every band on the SR71-15 cards and got this error and I tried every band on the R52N cards and get the same result. Any ideas?
xxiii
Re: New wireless protocol: Nv2 in v5.0beta5
Fri Oct 01, 2010 3:22 am
Set it to 20mhz, then go to the HT tab and enable the extension channel.
jbowsher
Fri Oct 01, 2010 8:53 pm
I have it setup that way but it is only using 20 Mhz Channel from what i can tell. I get about 190 Mbps tcp one way and about 95Mbps tcp bi-directionally but i know it would be twice that if i can utilize 40Mhz channel width. I started trying to test Nstreme dual with N today but I must say that my first attempt is a real flop. How do you get the data rates above 54Mbps in dual Nstreme? Does anyone have a basic config that works well or any ideas? I have the same problem there too with 20Mhz channel being used but on the "HT" tab it let me set it to 40Mhz channel width and I set it to double under "HT Streams". Again any help or ideas are extremely appreciated.
popcorrin
Sun Oct 03, 2010 7:28 pm
You are running 40Mhz. You can't get 190Mbps on 20Mhz.
ricky011
Tue Oct 05, 2010 1:36 pm
here are my results, 2x RB411AH and R5nH
temuri426
Tue Oct 05, 2010 11:06 pm
hi all..
Once i've used it just for testing... i was quite satisfied, nv2 has very stable results... 80 mb ful duplex with N cards...
But i couldn't see CCQ status.... it will be good if you add some features for troubleshing porpose..and need more detailed information how it works exactly
this protocol has good future :)
jcremin
Wed Oct 06, 2010 9:39 am
I have tried it a few times with really bad results. I have two 411A XR9 AP's on one tower running in 5mhz channels with regular nstreme enabled and 411's as clients. When I install 5.0 beta, throughput starts getting a little worse right off the bat. As soon as I turn on NV2, I get lots of disconnects on BOTH AP's regardless of how much channel spacing I have. I can have one set at 2427 and the other at 2442, and as soon as I pass much traffic on either radio, clients from both start disconnecting and the whole tower becomes unusable. I've changed every setting and nothing made much of a difference.
I've since downgraded the AP and all clients back to 4.11 with the old nstreme again. I never tested upgrading both AP's because if it doesn't play nice enough to change one over (even with plenty of RF spacing) NV2 is useless since I can't/won't change all towers simultaneously.
tgrand
Long time Member
Long time Member
Wed Oct 06, 2010 9:07 pm
Please fix the watchdog so that it creates a supout file.
This way the NV2 protocol can be debugged.
This would allow me to have the supout available from the client as well as the AP.
It also reboots the client and AP so minimal downtime is experienced.
Win Win.... If you can fix the watchdog.
-headstrong-
Wed Oct 13, 2010 2:24 am
What happens if I share a tower with other WISPs?
Are we now in a race to see who can implement NV2 first? If the other guys beat me to it, will my links become unusable?
charliebrown
Wed Oct 13, 2010 3:56 am
I'm interested in that comment myself, Does it mean that nv2 will be affected by interference more than normal or that it will create interference with normal 802.11 gear?
-headstrong-
Thu Oct 14, 2010 12:15 am
Exactly, all my highsites are pretty noisy so NV2 might be counter productive?? Or have we missed something?
normis
Thu Oct 14, 2010 9:42 am
From the documentation:
As NV2 does not use CSMA technology it may disturb any other networks in the same channel. In the same way other networks may disturb NV2 network, because every other signal is considered noise
http://wiki.mikrotik.com/wiki/NV2#Compa ... _protocols
colebert
Mon Oct 18, 2010 6:11 pm
News Flash: The cell radius setting is pretty important.
I couldn't get an NV2 link to work. The client side would register and then drop after only a few seconds. The AP side would never register. I had to go into the command line and set it by hand.
I am getting pretty disappointed in the v5 Winbox. It *still* doesn't have manual MCS settings and doesn't include some key NV2 configuration options.
Amateurs built the Ark.
Professionals built the Titanic.
Muqatil
Trainer
Trainer
Mon Oct 18, 2010 8:02 pm
I couldn't find it on this thread, so i repeat it:
max-station-count isn't working on nv2 pmtp
(i limited to 60 but i reached 72 users)
Renato Bernardi
skype: medtech5
normis
Tue Oct 19, 2010 8:01 am
did you email support?
Muqatil
Trainer
Trainer
Tue Oct 19, 2010 10:13 am
Sent right now.
Renato Bernardi
skype: medtech5
normis
Tue Oct 19, 2010 10:21 am
Sent right now.
I checked, and it's a known missing feature actually.
ste
Tue Oct 19, 2010 10:40 am
Are this 72 users happy? Did you run nstreme before on this AP? How does it compare?
-headstrong-
Tue Oct 19, 2010 11:04 am
How much aggregated throughput do you get?
Muqatil
Trainer
Trainer
Tue Oct 19, 2010 11:20 am
TBH they weren't happy, but there were a lot -86 users (cause i put on it users that usually don't connect on that antenna).
Right now i have 2 radios with 50 users both.. 10 mbit aggregated traffic, pings between 15ms and 100ms (a lot of jitter).
ping 10.20.100.1 count=20 interval=500ms
10.20.100.1                             56    64  22ms
10.20.100.1                             56    64  19ms
10.20.100.1                             56    64  40ms
10.20.100.1                             56    64  13ms
10.20.100.1                             56    64  46ms
10.20.100.1                             56    64  41ms
10.20.100.1                             56    64  23ms
10.20.100.1                             56    64  31ms
10.20.100.1                             56    64  36ms
10.20.100.1                             56    64  16ms
10.20.100.1                             56    64  5ms
10.20.100.1                             56    64  14ms
10.20.100.1                             56    64  28ms
10.20.100.1                             56    64  17ms
    sent=20 received=20 packet-loss=0% min-rtt=5ms avg-rtt=25ms max-rtt=46ms
This is one random user CPE ping.. looks good, 2mbit profile perfectly served.(51 users right now on AP)
As soon as i upgrade more clients, i'll will do further tests.
Renato Bernardi
skype: medtech5
-headstrong-
Tue Oct 19, 2010 1:18 pm
Would having clients connecting on a -86 affect the other clients? Surely TDMA gives each client a time slot to send/receive which makes it irrelevant if you have -86 clients or not?
Muqatil
Trainer
Trainer
Tue Oct 19, 2010 5:20 pm
Your thoughts look correct.. maybe 70 users were too much... i'll try to load the AP with more -70ish users and check again..
Renato Bernardi
skype: medtech5
uldis
Tue Oct 19, 2010 6:04 pm
Cell radius and other Nv2 options will be added to the winbox in RouterOS v5.0rc2.
Yes, you have manual MCS settings in the winbox - go to the Data-rate tab, set the configured radio button and then go to the HT-MCS tab and enable/disable any rates you like.
colebert
Tue Oct 19, 2010 11:13 pm
Sorry, I meant manual TX POWER settings for individual MCS rates.
You cannot do that in rc1 but you can in v4.11.
jcremin
Wed Oct 20, 2010 9:48 am
I've only tested NV2 twice... Both times using a tower which had two 900 mhz sectors with routerboards and XR9's running in 5 mhz channels using old Nstreme from version 4.11.
Both times were a disaster. I never got around to upgrading both routerboards on either tower. Once I had one upgraded (and even before I touched the NV2 settings) performance got worse. Then once I turned on NV2 on the one sector and associated clients, neither sector was stable. Even if I had one on the lowest supported channel and one on the highest supported channel with two channels between. If I put any traffic on either sector, clients from both sectors would drop continuously and I just couldn't use it at all.
If the protocol messes things up even when I have 10mhz of buffer between channels, it is useless for me. I downgraded as fast as possible and decided I would wait to see if I improved in the future.
uldis
Wed Oct 20, 2010 2:56 pm
Nv2 is only working in v5.x. Maybe you are confusing Nstreme with Nv2?
If you have problems running Nv2 please contact support@mikrotik.com and include the support output files and detailed info on the wireless link.
Muqatil
Trainer
Trainer
Thu Oct 21, 2010 3:38 pm
70 users (with good signals)
Ping from a client to my gateway
 ping x.x.x.x count=10
x.x.x.x                         56    63  16ms
x.x.x.x                         56    63  50ms
x.x.x.x                         56    63  44ms
x.x.x.x                         56    63  51ms
x.x.x.x                         56    63  38ms
x.x.x.x                         56    63  47ms
x.x.x.x                         56    63  41ms
x.x.x.x                         56    63  26ms
x.x.x.x                         56    63  41ms
x.x.x.x                         56    63  19ms
    sent=10 received=10 packet-loss=0% min-rtt=16ms avg-rtt=37ms max-rtt=51ms
-headstrong- looks like signals still affect the whole AP performance..
Today i'll try VoIP calls on clients of this AP
Renato Bernardi
skype: medtech5
netrat
Thu Oct 21, 2010 4:09 pm
I have a PtP link with two XR9s, a RB532A, and RB411. I didn't have much success with beta5, but the nv2 protocol seems to be working much better in rc1. My link is NLOS 1.6 miles using a 5MHz wide channel, signal strengths stay around -76 or so. With nv2 enabled I get about 500k more throughput and much stabler pings.
danletkeman
Wed Nov 03, 2010 4:07 am
2x RB411AH, R5N, 100mbit/sec tcp from just one machine copying a file across the link.
My only problem now is that I cannot stream video files properly across this system, they seem to get choppy after a while, but yet the link is still transferring the same amount of data. The video transfer rate is anywhere from 10mbit/sec to 25mbit/sec depending on the detail of the video, so its way under the bandwidth that this link can handle. Yet this was never a problem on 3.30 using 802.11a.
Is there any way to debug something like that?
Oh and it crashed if I had the cpu set to 800mhz.
adrianatkins
Long time Member
Long time Member
Fri Nov 05, 2010 11:59 pm
OK. I've woken up now, and am interested.
Will Nv2 have some kind of time synch ?
If not, it's the same as AirMax in the sense that we can't use it effectively.
Don't forget to give me at least a tenner a month, every month
adrianatkins
Long time Member
Long time Member
Sat Nov 06, 2010 12:03 am
Oooops. I have that Feature. I don't know why i stole it.
Where can i meet you to give it back.
So sorry. I don't know what came over me.
mars
Sat Nov 06, 2010 11:26 am
we are testing rc3 with nv2 protocol on n link and an a link
the n link runs fine with nv2
the a link with nv2 keeps on rebooting the rb
is the nv2 protocol only for n links
thanks
-headstrong-
Fri Nov 12, 2010 1:13 am
x.x.x.x                         56    63  16ms
x.x.x.x                         56    63  50ms
x.x.x.x                         56    63  44ms
x.x.x.x                         56    63  51ms
x.x.x.x                         56    63  38ms
x.x.x.x                         56    63  47ms
x.x.x.x                         56    63  41ms
x.x.x.x                         56    63  26ms
x.x.x.x                         56    63  41ms
x.x.x.x                         56    63  19ms
Hi MediaNet
Did you manage to try voip on the NV2 sector?
How did it perform?
adrianatkins
Long time Member
Long time Member
Sun Nov 14, 2010 10:18 pm
If it's TDMA, then it really really needs some time synch.
If it has none, it's like Airmax, and therefore of limited benefit.
I bet Skypilot rue the day they used a nano 2 and tested their TDMA code on it.
fragtion
Sun Nov 14, 2010 10:23 pm
Hi there,
Is there a known bug with nv2 when running on x86 where CPU usage will seemingly randomly shoot up, often pounding 100% hard enough to lock up the board so that telnet/winbox are unresponsive and a reboot is required? I'm experiencing this problem with both 4.13 & 5.0rc3 and on two separate x86 boards. Here's some information which might help:
[admin@fragtion-rpc] > system resource print
uptime: 17m44s
version: "4.13"
free-memory: 1914032kB
total-memory: 1945820kB
cpu: "Intel(R)"
cpu-count: 1
cpu-frequency: 3058MHz
cpu-load: 11
free-hdd-space: 416074kB
total-hdd-space: 484630kB
write-sect-since-reboot: 568
write-sect-total: 568
architecture-name: "x86"
board-name: "x86"
platform: "MikroTik"
[admin@fragtion-rpc] > system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 X dude 3.6
1 system 4.13
2 routeros-x86 4.13
3 wireless-nv2 4.13
4 X ipv6 4.13
5 X ups 4.13
6 synchronous 4.13
7 routerboard 4.13
8 X wireless 4.13
9 X hotspot 4.13
10 X dhcp 4.13
11 mpls 4.13
12 routing 4.13
13 X ppp 4.13
14 X security 4.13
15 X advanced-tools 4.13
For the most part, nv2 is awesome... some of my link throughputs nearly double with the right nv2 tuning, and cpu usage seems generally lower than nstreme... it's just when this happens that CPU surges for some reason, the log doesn't say much, and the board locks up completely requiring a reboot. Because of this bug, I can't use nv2 at the moment. It only seems to effect x86...
Any feedback would be appreciated, thanks... let me know if I should post any other information or attach anything
uldis
Tue Nov 16, 2010 9:56 am
have you tried to check if the changing multi-cpu option helps avoiding lockup?
fragtion
Wed Nov 17, 2010 1:30 pm
Thanks for the suggestion, uldis. I tried it: '/system hardware set multi-cpu=no' (it was on 'yes') then manually rebooted, but within minutes it locked up again. In fact it seems a bit more useful when set to 'yes', because then it seems to reboot itself about a minute or two after the lockup... but not the case when set to 'no' - I have to manually powercycle
Edit: the problem (still) exists even in 5.0rc4
roc-noc.com
Forum Veteran
Forum Veteran
Sun Nov 28, 2010 5:34 pm
AirMax just announced gps sync coming with their new hardware.
It is time for RouterOS to do the same.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
mars
Sun Nov 28, 2010 6:41 pm
we have the same problem on x86 and it is worse on a links and better on n links
Belyivulk
Mon Nov 29, 2010 12:11 am
Well said rocnoc - Mikrotik NEED GPS Sync, without it, UBNT will start stealing customers (at least for wireless stuff)
Beccara
Long time Member
Long time Member
Mon Nov 29, 2010 12:17 am
Tom
Just please release it STABLE
ste
Mon Nov 29, 2010 12:50 am
Tom
It's time to make 11n/nv2 working stable and solid before jumping into the next
adventure. Please dont do the same as these AirMax Guys. I dont want to hear
promises and get months later a product which is alpha quality.
I need products which just do what they promise before I get the next
advertised feature.
Beccara
Long time Member
Long time Member
Mon Nov 29, 2010 1:10 am
Alpha quality? We just popped a pair of bullets in that took us all of an hour to configure and install, 9km with 90-95mbit, Blew MT out of the water
ste
Mon Nov 29, 2010 1:42 am
I tested Rockets some month ago. Does no DFS as promised and therefor was *illegal* in
my country. Signal strength values were false and driving it with allowed power
gave useless connections. Do they still reboot when changing a parameter?
How do they perform when you colocate them with other gear. Saw that some
guys make a hobby out of building metal shields to make them work.
I need some well engineered gear which work under difficult conditions flawless
as it's my business and not my hobby.
So I need MT with stable working NV2 and when it's done I need sync.
Beccara
Long time Member
Long time Member
Mon Nov 29, 2010 2:10 am
Yeah they still reboot which is pretty lol but if i'm going to put them into production I'll put n+1 setups together to handle this and any hardware failure, DFS was working for me about 7 months ago when 5.2 just came out, Signal levels are all very close to the math done on the link. THe shields were to improve the back-to-front ratio to allow high density installs, Its and antenna thing now a radio thing.
But yes, MT should release some stable sections. New features are great but there is alot of buggy stuff that needs to be fixed first
rtl8186
Tue Dec 28, 2010 9:09 pm
Нi everyone!
I have link 4km on two RB411AH+R52Hn work in 2.4Ghz
I have a problem with "disconnected control frame timeout" sometimes.
Configure my device:
First:
/interface wireless> print
0 R name="wlan1" mtu=1500 mac-address=XX:XX:XX:XX:12:A4 arp=enabled
interface-type=Atheros 11N mode=ap-bridge ssid="xxxx" frequency=2304
band=2ghz-onlyg channel-width=20mhz scan-list=2264
wireless-protocol=nv2 wds-mode=dynamic wds-default-bridge=bridge1
wds-ignore-ssid=no default-authentication=no default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=yes
security-profile=default compression=no
Second:
0 R name="wlan1" mtu=1500 mac-address=XX:XX:XX:XX:12:9A arp=enabled
interface-type=Atheros 11N mode=station-wds ssid="XXX" frequency=2304
band=2ghz-onlyg channel-width=20mhz scan-list=2304
wireless-protocol=nv2-nstreme-802.11 wds-mode=dynamic
wds-default-bridge=bridge1 wds-ignore-ssid=no default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=default compression=no
lazerusrm
Sat Jan 29, 2011 8:06 am
EDIT: Off-Topic.
uldis
Mon Jan 31, 2011 5:19 pm
how did it locked up - were you able to get in from the Ethernet side? Have you checked if the wireless package was enabled?
ekkas
Long time Member
Long time Member
Tue Feb 08, 2011 1:34 am
You can think of it as of improved nstreme.
Does that mean NV2 will also have packet aggregation into frames (framing policy terminology?) as NStreme does?
For PTP link with 2XR52HN cards & dual pol dish antennas, which will be better throughput: NStreme or NV2?
Ekkas
hackac
Tue Apr 19, 2011 11:27 pm
I expected a strange situation. Maybe bug?
I have 2 Sxt5HnD in a dual-chain ptp link (distance ~100m). I had good performance with nv2. For testing changed to nstreme but because a worst performance switch back to nv2. But after switching back the speed was the half of first test. After that protocol changing cannot solve the problem.
I update firmware to a new 5 version. With nv2 got the good speed. Change to nstreme and back and the situation was the same - half speed. Revert firmware to 4.7 - problem solved, good speed.
The link established by this howto: http://wiki.mikrotik.com/wiki/Transpare ... using_MPLS
After that dual chain is configured and some minor tweaks.
fragtion
Fri May 13, 2011 8:38 pm
On page 4 of this thread I described a lock-up problem when running nv2 on x86 intel multicore board. I would just like to report that since upgrading to ROS 5.2, I've been able to run nv2 on all my links now for days without any problem and it seems to be working much better than before. No CPU lock-ups since then, so far. Thanks!!
lazerusrm
Sun May 15, 2011 7:58 am
Okay, so i know NV2 WDS is not supported. Not disputing it :) However,
Are there plans ever for it to be?
nz_monkey
Sun May 15, 2011 8:00 am
NV2 + WDS is supported, I am using it now ;)
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
Belyivulk
Sun May 15, 2011 8:18 am
nz_monkey...how do you find the performance?
nz_monkey
Sun May 15, 2011 8:21 am
It seems to be quite good, getting ~50mbit UDP send/receive performance from RB433AH to SXT using 802.11n 2x2 with 20Mhz channel.
There were a few issues with WDS + Bridging in the 5.x release candidates but it's good in 5.0 onwards.
Belyivulk
Sun May 15, 2011 8:25 am
Is that a single SXT to the AP? Whats the distance? we see around 27mbit MAX from a client with around 8 other clients on the same AP, all less than 1km from the site.
The AP IS only 1x ant though, vertical omni at around 950mW EIRP
nz_monkey
Sun May 15, 2011 8:28 am
Thats a bwtest to a single SXT client that is connected to a 2x2 sector with about 5 other SXT clients on it.
The range of the clients is between 1 and 3km
Belyivulk
Sun May 15, 2011 8:29 am
very very nice :) What Freq / Antenna size / Type?
nz_monkey
Sun May 15, 2011 8:50 am
5Ghz with Ubiquiti 120degree sector and R52n-M card
fragtion
Thu May 26, 2011 6:19 pm
nv2 still going strong here on x86 intel SMP... now on ROS 5.3, but it's been good since 5.2! The download page says x86 nv2 not supported, but they're probably leaving that message there while they test stability. Seems stable to me, though! :-)
Users browsing this forum: gswcomputer, JanRovner, llubik, mika9521, mluczak, roeschlo, sid5632 and 123 guests
