uldis
v5.0beta5 user manager - fixed packages
Wed Jul 28, 2010 12:48 pm
macosoft
Re: v5.0beta5 user manager - fixed packages
Wed Jul 28, 2010 4:08 pm
I have downloaded the ppc version for my RB1100 and now the login page is ok, but after login I got this error and the browser freezes:
The following client application error has occurred:
Cannot process ServerMessage (Phase 1)
Error Name: TypeError
Error Message: librariesElement is null
Please contact your server administrator.
After that, the userman shows the same blank page as before it was fixed.
StreamR
Thu Jul 29, 2010 1:16 pm
Same here, except that I only get an empty "Error:" message after login.
adryfia
Thu Jul 29, 2010 2:24 pm
Still try.... :D
philw1
Thu Jul 29, 2010 4:11 pm
Tried today and couldn't even get a page to display :(
Have reverted back to 4.11 for time being.
adryfia
Thu Jul 29, 2010 6:52 pm
Same here sir, i can access userman but can't login, this error message "invalid/unknown respon from server"
nilesh
Mon Aug 02, 2010 9:08 am
i am not able login in http://router_ip_address/userman.
adryfia
Wed Aug 04, 2010 8:04 pm
So many bugs in user manager beta5, ican't create user againt. So just waiting the next version :( :(
skordan
Sat Aug 07, 2010 5:02 pm
I have the some problem om RB1000 .. when we have stable .. ?
adryfia
Tue Aug 10, 2010 7:44 am
Back to user manager beta4 againt sir.
macosoft
Tue Aug 10, 2010 11:42 am
User manager beta4 is working on routeros v5.0beta5 or should I need to downgrade the routeros as well to beta4?
adryfia
Tue Aug 10, 2010 6:53 pm
You must downgrade ROS to beta4 first.
macosoft
Mon Aug 16, 2010 9:39 pm
Same error on userman on v5.0beta6 too. :(
Can someone fix this pls.!
adryfia
Tue Aug 17, 2010 9:20 am
What's new in 5.0beta6 (2010-Aug-10 13:22):
*) sstp - fixed memory leak;
*) wireless - changed band setting and added channel-width setting
*) wireless - support for 11n rates in 5&10mhz channels
*) wireless nv2 - fixed multiple problems including occasional tx stall;
*) made gps accessible through SNMP;
*) snmp - added GETBULK support, no more table caching - solves problems
with huge tables, routing tables currently are not available;
*) ssh - fixed public key authentication in case
when client is not verifying if server will accept the key;
*) fixed problem - MetaROUTER did not work on RB800, RB1000 & RB1100;
*) user manager is not working - will be fixed in next version;
*) intel 82576 (uncommon expensive chip) crash/reboot to be fixed in next release
Yup user manager it' not working, Mikrotik staff already tell you in the cangelog.
macosoft
Wed Oct 06, 2010 11:18 am
It is fixed on RC1?
cleiton
Thu Mar 27, 2014 9:40 pm
I am using the user maneger rb1100x2 v6.11 and is giving problem on the page administrator put 300 users and when I switch to page 2 to see the users gave problem, I am very concerned that this will always happen because I have to restart the rb1100x2 reopen the admin page again.
This is the error:
The Following client application error has occurred.
Can not Process Server Message (Phase 1)
Error Message: Element is null libraries.
Users browsing this forum: No registered users and 6 guests
