MUM Europe 2020
poli5681
RB1100 Port 11/12 issues
Mon Aug 02, 2010 3:59 pm
Hello everyone,
I have the following issues on port 11 and 12:
I´ve bridged both ports with a software bridge (hardware bypass mode is off).
I enabled the "Use IP Firewall" feature on the bridge, added a few mangle rules and a queue tree.
Immediately after enabling the queue the ports go on/off every few seconds - dropping my connections and make them practically unusable. If i move the same configuration to other ports (lets say port 6/7), everything works as expected.
If i disable the queue tree, everything works on those ports; So it definitely happens only on those 2 ports and only if queue is enabled.
I have everything running (including queue and complex rules) on port 6/7 - whithout any issues.
I have no idea why that issue show on those ports only. Anybody knows?
Thanks.
Edit: It may be helpful to add, that i already disabled auto-neg and full-duplex without any result.
fewi
Re: RB1100 Port 11/12 issues
Mon Aug 02, 2010 4:05 pm
poli5681
Mon Aug 02, 2010 4:14 pm
Thank you, maybe it is...
Strangely it doesn´t happen, if i disable queue on these ports.
The ports were up and running for about a week (pushing ~8Mbit of traffic), before i enabled the queue tree today.
So i had no issues before.
GlueGuy
Mon Aug 02, 2010 6:41 pm
Normis had posted that 4.11 would fix this issue.
However, there is nothing in the 4.11 release notes to indicate that this issue has actually been fixed.
Has anyone downloaded 4.11 to see if it addresses this issue?
bp
poli5681
Tue Aug 03, 2010 10:49 am
Yes, i upgraded to 4.11; this fixed an issue with ports still showing traffic after pulling off the cable.
This happened pretty much everytime, i pulled out the cable from Port 13 (i didn´t test the other ports, because it didn´t seem to hurt in any way).
But i did´t do anything with the issues described above; I tested with 4.10 and 4.11 - no change.
meno
Tue Aug 17, 2010 3:41 pm
I had the same problem when I connected to a switch port11,12 connected without problem, but when I connected to a pc,in this case a wimax antenna, it disconnects and connects every momemnt, I tried deactivating the auto negotiation, even with 10/100 and full duplex...
please mikrotik give us a solution
meno
Wed Aug 18, 2010 3:21 pm
please mikrotik give us a solution..... my customer will not pay me until fix this
Users browsing this forum: No registered users and 27 guests
