MUM Europe 2020
YUJOBIKA
(HELP) Regex for Static DNS
Tue Aug 03, 2010 9:51 pm
Anyone can help me how to use regex in static dns ? Mine is ROS v3.30
I want to make regex for:
1) http://abc.xyz.domain.com/folder/.....and all path beyond
2) match for www.domain2.com/..... and all path beyond, but doesn't want resolve www.abc.domain2.com
Thanks in advanced for your help.
Regards
NAB
Trainer
Trainer
Re: (HELP) Regex for Static DNS
Wed Aug 04, 2010 10:40 am
A HTTP URI as a whole has absolutely nothing to do with DNS. It looks like what you want to do (i.e. munge the URL) should be done on the web server iteself - DNS can't help you here.
Nicholas Barnes BSc(hons)
Certified Mikrotik Consultant
Certified Mikrotik Trainer
Vitell - Asterisk, Linux and network consultants
Unofficial IRC channel: #routerboard on irc.z.je
Chupaka
Tue Aug 10, 2010 4:48 pm
so, what exactly do you want to do?..
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: MSN [Bot] and 44 guests
