singh
2 links
Mon Aug 09, 2010 10:29 pm
Is there a way of having 2 links terminated to a router OS, so that when one goes down it automatically picks from the second provider.
Ibersystems
Re: 2 links
Mon Aug 09, 2010 10:47 pm
Look for bonding interfaces or ospf, it depends on what you need to do.. Perhaps with static routes its possible too. Need more info. Adsl link, wired? Wireless?
Martín Ruiz
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in:
MTCNA - MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE - MTCSE
singh
Re: 2 links
Tue Aug 10, 2010 4:02 pm
Here is the scenario.
I have a Wimax from my provider which is terminated to my RouterOS via cable on ethernet1.
My capacity is 512kb up and down.
I then have my hotspot on ethernet2 which my users are connecting to for browsing the internet.
The problem is when the link is down then my customers have to suffer.
I want to take a connection from a different provider as well, which again will be cabled and terminated to ethernet3 to act as a backup link.
Since it is going to be rare for both links to go down at the same time, customers will enjoy better uptime.
How can I configure both the links to work togather....
Chupaka
Re: 2 links
Tue Aug 10, 2010 4:04 pm
in the simpliest case you should just add two default routes with different distance
also you may need to use something like http://wiki.mikrotik.com/wiki/Advanced_ ... _Scripting
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: htdbnbj, iw2ngg, llubik, webix and 120 guests
