normis
RouterOS v5 beta 6
Wed Aug 11, 2010 9:20 am
What's new in 5.0beta6 (2010-Aug-10 13:22):
*) sstp - fixed memory leak;
*) wireless - changed band setting and added channel-width setting
*) wireless - support for 11n rates in 5&10mhz channels
*) wireless nv2 - fixed multiple problems including occasional tx stall;
*) made gps accessible through SNMP;
*) snmp - added GETBULK support, no more table caching - solves problems
with huge tables, routing tables currently are not available;
*) ssh - fixed public key authentication in case
when client is not verifying if server will accept the key;
*) fixed problem - MetaROUTER did not work on RB800, RB1000 & RB1100;
*) intel 82576 (uncommon expensive chip) crash/reboot to be fixed in next release
*) RouterOS supports up to 16 cores in your PC system (previous limitation was 8)
Issues:
*) user manager is not working - will be fixed in next version;
*) switch menu is gone from Winbox, fix will be soon
Newsletter: http://download.mikrotik.com/newsletter27.pdf
martini
Re: RouterOS v5 beta 6
Wed Aug 11, 2010 9:39 am
release date of RouterOS v5 beta7 with fixed i82576 problems ?????????????
normis
Wed Aug 11, 2010 9:40 am
which ones you mean?
martini
Wed Aug 11, 2010 9:53 am
QOS with enabled multicore
normis
Wed Aug 11, 2010 9:57 am
yes, we are working on it.
xezen
Long time Member
Long time Member
Wed Aug 11, 2010 10:17 am
is the snmp odi for gps been set in this version?
In RouterOS v5.0beta6 the will be SNMP support for GPS.
If i dont No Ask someone That Does!
martini
2 normis - found that when i map every tx and rx ethernet queue (i82576) to processor core (disable automatic sharing) - queue start working, and global-in and global-out also working (multicore enabled)
sergejs
Wed Aug 11, 2010 10:49 am
The values available over SNMP for gps,
/system gps> print oid
date-and-time: .1.3.6.1.4.1.14988.1.1.12.1.0
longitude: .1.3.6.1.4.1.14988.1.1.12.2.0
latitude: .1.3.6.1.4.1.14988.1.1.12.3.0
altitude: .1.3.6.1.4.1.14988.1.1.12.4.0
speed: .1.3.6.1.4.1.14988.1.1.12.5.0
sattelites: .1.3.6.1.4.1.14988.1.1.12.6.0
is-valid: .1.3.6.1.4.1.14988.1.1.12.7.0
xezen
Long time Member
Long time Member
Wed Aug 11, 2010 12:36 pm
does it support 5GHz-turbo
with nv2
as i have 433ah with 3 radios
5ghz
5GHZ-turbo
2.4g-only
i want to try it with the 2.4g-only but not shore if it will affect the 5ghz-turbo
mars
Wed Aug 11, 2010 1:19 pm
memory leak still there in x86 and leak very fast
angboontiong
Wed Aug 11, 2010 3:23 pm
Normis..
Just wonder know the 7Ghz 26Mhz channel bandwidth microwave can provide <1ms latency.
anywhere Mikrotik can make it happen?
angboontiong
Wed Aug 11, 2010 6:25 pm
Normis...
Another problem found...
with RouterOS v5 beta 6, i set it running on the MPLS + NV2 and apply the NV2-qos-default.
the dude manager is not able to read the snmp.
when i downgrade back to the RouterOS v5 beta 5, then i having no issue with it.
axiang
Wed Aug 11, 2010 8:39 pm
IRQ cause new problems can not be upgraded
Figure specify the CPU upgrade package can not be upgraded configuration upload no response after reboot
CPU power into the system to restore it to normal and auto reboot after the upgrade
translate.google
新的问题 IRQ 引起 无法升级
如图 指定CPU 配置 上传升级包无法升级 reboot 后无响应
断电进入系统 恢复 CPU 为 auto 后 reboot 才正常 并升级
我是中国人
wildbill442
Wed Aug 11, 2010 9:47 pm
Normis...
I too noticed SNMP data is not available for all interfaces (ethernet, wireless, etc).
System info / CPU / mem / etc seems to work fine..
William Burnett
Network Engineer
wbhampton
Wed Aug 11, 2010 11:02 pm
I have found that WDS mode does not work using any of the nv2 protocols.
Walter B. Hampton
McCookNet Internet Service
308-350-1419
ManyX
Wed Aug 11, 2010 11:52 pm
I can not choose 40MHz channel width Band:5GHz-only-N I gets incompatible band and channel-width
Check "channel width" M h z
Arlic
Thu Aug 12, 2010 12:36 am
the routeros v5 has added G turbo and 5Ghz Turbo for AR5413 and AR5212, coz the specification of the chipsets says, the chipsets support turbo mode, AR5413 support 2.4Ghz turbo and 5Ghz turbo, AR5212 support 2.4Ghz turbo mode
angboontiong
Thu Aug 12, 2010 3:35 am
Mikrotik have highly this in the RouterOS v5 beta 5.
angboontiong
Thu Aug 12, 2010 3:41 am
translate.google
1) 新的问题 IRQ 引起 无法升级
2) 如图 指定CPU 配置 上传升级包无法升级 reboot 后无响应
3) 断电进入系统 恢复 CPU 为 auto 后 reboot 才正常 并升级
Wish you allow me me help for some correction for this translation ^_^:
1) The IRQ cause the system not able to upgrade.
2) As shown in the photo, if using manual setting for the CPU. there is no respond after upload the files and reboot the system for upgrading purpose.
3) Recycle the power, after enter the system, restore back the CPU setting to auto, then it can upgrade the system.
normis
Thu Aug 12, 2010 7:49 am
Yes, there are some issues with the multicore IRQ selection, it's fixed in beta7
Yes, there are also some SNMP issues that are fixed in beta7
angboontiong
Thu Aug 12, 2010 8:34 am
Normis..
So far the beta6 is perform good if we ignore that few issue which will fix in the next release.
BTW, can be the latency bring down to <5ms?
normis
Thu Aug 12, 2010 8:38 am
You say that "if using manual setting for the CPU. there is no respond after upload the files and reboot the system for upgrading purpose", but RouterOs v5beta6 is the Newest version. What are you upgrading to ?
omidkosari
Trainer
Trainer
Thu Aug 12, 2010 9:58 am
What about Ticket#2010062166000111 or http://forum.mikrotik.com/viewtopic.php?f=2&t=42698 PPPoE options like DHCP options ?
mangust
Thu Aug 12, 2010 12:02 pm
Feature request:
Backup file should have hostname instead of "Mikrotik-" (or option to do that).
I use arag & drop to save backup configs and tired to rename backup file :).
normis
Thu Aug 12, 2010 12:15 pm
more practical would be to use a script that saves with custom name and automatically emails you the files :)
/system backup save name=whatyouwant
but I will see if we can change the default name to the identity name + timestamp for example.
mangust
Thu Aug 12, 2010 2:06 pm
It's all true. But sometimes I'm too lazy to write a such long command :) (plus timestamp is a keyword).
So, identity name + timestamp as a default name for backup file will be just great!!!
gustkiller
Fri Aug 13, 2010 2:01 am
how did you set tc /rx queue in mikrotik? what command?
Mikrotik Certified Consultant
wispwest
Fri Aug 13, 2010 3:28 am
I see posted TCP throughput increase using Nv2 on 802.11n, but is there any increase on 5Ghz Turbo as well?
NetworkPro
Fri Aug 13, 2010 8:17 am
OMG confirmed
on a RB433AH - stable though...
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
axiang
Fri Aug 13, 2010 10:39 am
bonding might be some problems sometimes can not follow the desired work and cause system crashes, such as interfaces lost. . . .
pppoe mode can not have the desired effect?
NIC 82546EB X 2
Switch HP 2650(J4899B)
我是中国人
tanxw998
Fri Aug 13, 2010 6:37 pm
please update kernel to 2.6.35 , atuo save irq problem 、improve netwokr performence
palese !!!
tanks
Chupaka
Fri Aug 13, 2010 10:21 pm
palese !!!
tanks
http://forum.mikrotik.com/viewtopic.php ... 28#p221228
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
avantwireless
Sat Aug 14, 2010 6:07 pm
We tested on a simple 10mhz wide link with 2.4 radios sr2 and KXS30SG radios and they would only connect in B no matter what was set. quickly went back to 5b5 all better...
dibatech
Re: RouterOS v5 beta 6 110 Km Link.
Sun Aug 15, 2010 7:34 pm
Point A: RB433AH
Point B: RB411
Only good old fashioned NStreme works as nv2 ,nv2 nstreme and nv2 nstreme 802.11 briefly ascotiates, but disconnects almost immediatly.
log:
00:28:01 wireless,info 00:0C:42:3A:XX:XX@wlan1 established connection on 5520, SSID XXX
00:28:06 wireless,info 00:0C:42:3A:XX:XX@wlan1: lost connection, ranging timeout
00:28:06 wireless,info 00:0C:42:3A:XX:XX@wlan1 established connection on 5520, SSID XXX
00:28:11 wireless,info 00:0C:42:3A:XX:XX@wlan1: lost connection, ranging timeout
00:28:11 wireless,info 00:0C:42:3A:XX:XX@wlan1 established connection on 5520, SSID XXX
00:28:16 wireless,info 00:0C:42:3A:XX:XX@wlan1: lost connection, ranging timeout
00:28:17 wireless,info 00:0C:42:3A:XX:XX@wlan1 established connection on 5520, SSID XXX
Ping times looks ok though with 5 beta 6 with nstreme.
Packet size=30
[admin@Megs_2] > /ping 172.21.200.33
HOST SIZE TTL TIME STATUS
172.21.200.33 56 64 3ms
172.21.200.33 56 64 2ms
sent=7 received=7 packet-loss=0% min-rtt=2ms avg-rtt=2ms max-rtt=3ms
Packet size=1500
[admin@Megs_2] > /ping 172.21.200.33 size=1500
172.21.200.33 1500 64 7ms
172.21.200.33 1500 64 10ms
172.21.200.33 1500 64 9ms
172.21.200.33 1500 64 6ms
sent=8 received=8 packet-loss=0% min-rtt=6ms avg-rtt=8ms max-rtt=10ms
babbage
Trainer
Trainer
Sun Aug 15, 2010 9:10 pm
Hello normis,
You may have a look at ticket #2010072666000136
Nobody told me about beta5 upgrade problem (IRQ stuff). Check mine and support replies. Of course I am going to test new betas but with installing on another system...
digitexwireless
Tue Aug 17, 2010 5:59 am
There is no P Throughput on the Signal tab when monitoring a connection using Nv2. We are using a RB433UAH with a single XR3 for testing. Is this by design or a bug?
uldis
Tue Aug 17, 2010 10:58 am
Please provide us with the support output file from your setup.
Send it to support@mikrotik.com
What band you have configured? You need to use 2Ghz-only-G band.
avantwireless
Tue Aug 17, 2010 1:58 pm
Wilco... it was set for g only...
mangust
Wed Aug 18, 2010 9:50 am
Any news about next release :) ?
gustkiller
Wed Aug 18, 2010 4:25 pm
i hope it get here before our new hp dl servers with those nics arrives.
odie
Wed Aug 18, 2010 5:09 pm
just upgraded a production link in our network with beta6 und R52Hn cards
built in Huber&Suhner 23 Antennas using only 1 channel about 13 KM
seems to work fine ;-))
getting up to 35 Mbit with conservative settings and low power setting
also latency is very low...
waiting for finals....
angboontiong
Thu Aug 19, 2010 6:25 am
Normis..
The watch dog feature seem not work properly...
InoX
Sun Aug 22, 2010 3:44 am
since beta 6 my server with 2x82557/8/9/0/1 Ethernet Pro 100 (rev: 8 ) is not working anymore. Realtek gigabit card was ok. Downgraded to beta5. Working now. Card were enabled but no traffic was passing. Tried to Disable/Enable but cards staid disabled with error 6...and also Stop button from torch page, is missing.
HaQs
Sun Aug 22, 2010 5:51 pm
When a ROS beta7 is expected ?
adryfia
Mon Aug 23, 2010 12:54 pm
Just waiting sir, because so much bugs in ROS 5 beta. Just waiting :)
exebug
Mon Aug 23, 2010 1:04 pm
Also waiting ;)
iw4eky
Mon Aug 23, 2010 3:16 pm
I've just verified that two boards are not reachable if behind a bridged link with a Nv2 wireless link (like the one shown by "himmi" in his post):
DEVICE A...............DEVICE B - Station.................DEVICE C - AP...........DEVICE D
RB1100 eth1---------- eth1---wlan1 >>>>>> <<<<<<<< wlan1----eth1 --------- eth1 RB1100
BRIDGE in device B with ports "eth1" and "wlan1"
BRIDGE in device C with ports "eth1" and "wlan1"
I can see al 4 devices as Neighbors but ping is quite weird:
From D I can ping C and B, but not A
From A I can ping only B
Looks like an issue related to the "bridge" interfaces, this happens with Nv2 and Nstreme as "wireless-protocol" and I'm not using WDS since it's known as non working yet. And yes, all IP addresses are properly set!
Bye,
mattia
grahamedia
Trainer
Trainer
Mon Aug 23, 2010 3:23 pm
Using NV2 @RouterOS v5 beta6 in X86 Alix board, make the hardware freeze / deadlock, after 1-4 hours connection PTP.. and have to reboot with unplug the adaptor of the hardware..
Better but still problem in RB433AH, using NV2, there was no problem to freeze the hardware, but the connection, disconnect ofter serveral hours connection..
Looks like RouterOS v5 beta 6 still have much repairement for using NV2, and we hope in RouterOS v5 beta 7, will solved these problem
8)
uldis
Mon Aug 23, 2010 3:52 pm
iw4eky, in case of Nv2 it is just like 802.11 - you need to make a EOIP or VPLS/MPLS link over it to wireless link if you want to make transparent bridge.
grahamedia, give us more detailed info what exactly doesn't work in Nv2with alix board? Any support output files generated after lockup?
grahamedia
Trainer
Trainer
Mon Aug 23, 2010 4:16 pm
We were using MPLS for Transparent Bridging, and both side using Alix G2D2 + XR5 for PTP connection over 20 KM, with nstream mode, the throughput are 30/30 Mbps with TCP, and we were very exciting after using nv2 the throughput increasing to 40/40 Mbps..
But after 2 hours, suddenly one side of hardware lockup, and the connection loss.. we cannot remote the hardware, so we turning off and on again to make it work again.. and after 1 hour, the other side lockup too, and so on..
There was no chance to look the message report, because we have to reboot the hardware, and the log was cleared after that..
Using nstream, with same configuration have stable result, and work no problem at all
And we have tried with RB433AH + XR5 @both side, with NV2, the hardware were stable, but the connection after 1 days drop, and not reconnect after that, except we disable and enable the interface again, or change it to other mode like nstream or 802.11
digitexwireless
Mon Aug 23, 2010 10:37 pm
So we have tried the NV2 in a high interference area and it really seems to work. Took a customer who had good signal of -65 but P Throughput of less than 100 and transferred at a 2-3 meg down and 1 meg up using NV2. Looking forward to using this in the field on a permanent basis.
Any ETA on the radius authentication being added to NV2? We cannot field test without radius support. The tower I have in mind has 42 clients and interference is always an issue. If we can get the radius support, I will be glad to test it as it beats the heck out of changing out clients to another frequency.
perit
Tue Aug 24, 2010 11:26 am
Hi all, I was using ROS v5b5 on a Dell PowerEdge R210. Since I upgraded to v5b6 both onboard ethernet interfaces are no more working:
This with v5b6 (same display on v5b5 follows below):
[admin@MikroTik] > interface ethernet print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP
[admin@MikroTik] /system resource irq> print
# IRQ USERS CPU ACTIVE-CPU COUNT
0 4 serial auto 3 503
1 9 acpi auto 1 0
2 14 ide0 auto 1 0
3 15 ide1 auto 1 0
4 22 usb2 auto 1 93
usb1
5 24 hpet2 auto 0 23575
6 25 hpet3 auto 1 23181
7 26 hpet4 auto 2 23166
8 27 hpet5 auto 3 23124
9 32 ahci auto 2 861
[admin@MikroTik] /system resource> pci print
# DEVICE VENDOR NAME IRQ
0 03:03.0 Matrox Graphics, Inc. MGA G200eW WPCM450 (rev... 6
1 02:00.1 Broadcom Corporation NetXtreme II BCM5716 Gi... 10
2 02:00.0 Broadcom Corporation NetXtreme II BCM5716 Gi... 15
3 00:1f.2 Intel Corporation 5 Series/3400 Series Ch... 11
4 00:1f.0 Intel Corporation 3400 Series Chipset LPC... 0
5 00:1e.0 Intel Corporation 82801 PCI Bridge (rev: ... 0
6 00:1d.0 Intel Corporation 5 Series/3400 Series Ch... 14
7 00:1c.0 Intel Corporation 5 Series/3400 Series Ch... 0
8 00:1a.0 Intel Corporation 5 Series/3400 Series Ch... 14
9 00:10.1 Intel Corporation Core Processor QPI Rout... 0
10 00:10.0 Intel Corporation Core Processor QPI Link... 0
11 00:08.3 Intel Corporation Core Processor Miscella... 0
12 00:08.2 Intel Corporation Core Processor System C... 0
13 00:08.1 Intel Corporation Core Processor Semaphor... 0
14 00:08.0 Intel Corporation Core Processor System M... 0
15 00:03.0 Intel Corporation Core Processor PCI Expr... 0
16 00:00.0 Intel Corporation Core Processor DMI (rev... 0
[admin@MikroTik]
Same commands with v5b5:
0 R ether1 1500 B8:AC:6F:8B:63:3E enabled
1 R ether2 1500 B8:AC:6F:8B:63:3F enabled
[admin@MikroTik] > system resource irq print
0 4 serial auto 3 227
1 9 acpi auto 1 0
2 14 ide0 auto 1 0
3 15 ide1 auto 1 0
4 22 usb2 auto 1 88
usb1
5 24 hpet2 auto 3 9943
6 25 hpet3 auto 2 9912
7 26 hpet4 auto 0 10147
8 27 hpet5 auto 1 9964
9 32 ahci auto 1 766
10 33 eth0-0 auto 2 102
11 34 eth0-1 auto 1 11
12 35 eth0-2 auto 1 36
13 36 eth0-3 auto 1 56
14 37 eth0-4 auto 1 8
15 42 eth1-0 auto 1 1
16 43 eth1-1 auto 1 0
17 44 eth1-2 auto 1 0
18 45 eth1-3 auto 1 0
19 46 eth1-4 auto 1 0
[admin@MikroTik] > system resource pci print
Any hint ?
Thanks in advance.
angboontiong
Tue Aug 24, 2010 8:35 pm
Hi...
would you mind to shared about the Alix G2D2 in the other topic or email?
temuri426
Thu Aug 26, 2010 12:06 pm
can i upgrade my rb333 to RouterOS v5 beta 6 ?
rpingar
Long time Member
Long time Member
Fri Aug 27, 2010 10:30 am
when will b7 be vailable?
the snmp problem is preventing us to put it in a real enviroment.
regards
ros
angboontiong
Fri Aug 27, 2010 1:17 pm
Another issue is the hide ssid not function.
netus
Sat Aug 28, 2010 12:50 pm
And another issue is the DHCP server or client not function on wireless interface.
Server is offering the lease but a client is searching forever.
Few of my clients get the IP but basicly they have status "searching..." (and on server side "offered") forever.
Wireless interface mode is:
on the server side - "ap bridge" no wds.
on the clinet side - "station".
No bridge, very simple configuration.
Hardware: RB433AH + R52nM and RB711M
NETUS Sp. z o.o.
www.netus.com.pl
netus
Mon Aug 30, 2010 10:39 am
Yes, You can.
Before upgrade the software to level 4 or 5, you need to upgrade the license key.
To do that:
1. upgrade the software to ver. 3.30.
2. upgrade the firmware [/system routerboard upgrade]
3. upgrade the license key useing WinBox
4. now you can upgrate the software to level 4 or 5
5. upgrade the firmware, if there is new one
NETUS Sp. z o.o.
www.netus.com.pl
mwheeler
Fri Sep 03, 2010 12:22 pm
Lads, I'm having some issues OSPF flapping into exstart mode on the new Beta 6 on a RB750G, and just recently winbox / API / web interface has dropped out. I'm guessing I have to upload a support.rif file to support@mikrotik.com ? I haven't rebooted the box yet, and telnet works. This happened a few days ago, and rebooting solved... At time of looking, HDD, Mem and CPU looked good. Mem is usually a bit higher though on this system, usually idles around 10MB free.
uptime: 2d20h23m
version: "5.0beta6"
free-memory: 4944KiB
total-memory: 29764KiB
cpu: "MIPS 24Kc V7.4"
cpu-count: 1
cpu-frequency: 680MHz
cpu-load: 0%
free-hdd-space: 21580KiB
total-hdd-space: 61440KiB
write-sect-since-reboot: 441362
write-sect-total: 554662
bad-blocks: 0%
architecture-name: "mipsbe"
board-name: "RB750G"
platform: "MikroTik"
02:47:55 route,bgp,info Failed to open TCP connection: Network is unreachable
02:47:56 route,bgp,info RemoteAddress=172.28.1.37
02:48:00 route,ospf,info OSPFv2 neighbor 172.28.1.253: state change from ExStart to 2-Way
02:48:01 route,ospf,info OSPFv2 neighbor 172.28.1.251: state change from ExStart to Init
02:48:01 route,ospf,info OSPFv2 neighbor 172.28.1.250: state change from ExStart to Init
02:48:01 route,ospf,info OSPFv2 neighbor 172.28.1.253: state change from ExStart to Init
02:48:01 route,ospf,info Database Description packet has init bit set in middle of an exchange
02:48:01 route,ospf,info OSPFv2 neighbor 172.28.1.253: state change from Exchange to 2-Way
netus
Fri Sep 03, 2010 12:57 pm
Found problem with the ARP
Clients can ping AccessPoint but can't ping each other.
Of course Default Forward and ARP on the wireless interfaces is enabled.
All devices in one network.
After setting up static ARP all work fine.
NETUS Sp. z o.o.
www.netus.com.pl
mangust
Fri Sep 03, 2010 1:21 pm
OK,
Looks like it’s a problem to get stable BETA in nearest feature.
Could somebody suggest me 4GB port adapter, which can be supported by 4.x version?
fsoaress76
Fri Sep 03, 2010 10:20 pm
power edge 510
HD ATA
Instalei em outra maquina, depois coloquei no dell, levantou só as placas Gigabit quad port.
registrei o Router-OS, tudo ok.
Quando estava configurando os ip nas interfeces, disappeared all INTERFACES
Placas de redes
2 Placa de rede Intel Gigabit Quad Port, Copper, PCIe-4
2 interfaces onboard Broadcom® NetXtreme II™ 5709c Gigabit Ethernet NIC
Help!! Help!!
birendersinghbudhwar
Tue Sep 07, 2010 9:46 am
When v5 beta7 is releasing ...?
Birender Singh Budhwar
Director Wireless Operations
BSB DATA AND INFORMATION PROCESSING SERVICES PRIVATE LIMITED
ROHTAK, 124001, HARYANA, INDIA
normis
Tue Sep 07, 2010 9:47 am
next version will be out next week
omidkosari
Trainer
Trainer
Tue Sep 07, 2010 11:17 am
new version has this feature request http://forum.mikrotik.com/viewtopic.php?f=2&t=42698 ?
yarda
Wed Sep 08, 2010 2:55 am
I would like if ask me anyone form Mikrotik team.
Please, add longitude and latitude to RoS version 4.x as static value (for example /system location ;-) ) and set some possible SNMP output. It will be usefull for administration large networks and managment through dude, trust me as ISP wit more than 800 RB on our site. Thank you very much.
Lakis
Forum Veteran
Forum Veteran
Wed Sep 08, 2010 12:13 pm
:) Finlay something hope Nv2 for wds fixed
Lakis
Forum Veteran
Forum Veteran
Wed Sep 08, 2010 12:20 pm
Hm.. I have 3 p2p (ap-bridge<->station wds) links with Hide SSID ver. 5beta6 all working, dont really sure what is not function
npero
Fri Sep 10, 2010 4:03 pm
Please first resolve bug with restart on x86 with bridge filter.
I send you now supout.rif form last non public version.
Alessio Garavano
Fri Sep 10, 2010 5:43 pm
Bridge Filter is not working on v5 really?
I upgrade a lot of RBs and the bridge filter is not working...
Alessio Garavano
http://www.isparg.com.ar
npero
Fri Sep 10, 2010 6:44 pm
On x86 working in beta 6 in some non official test version have problem when is bridge filter enabled router restart.
Working but cause reboot.
Beta 6 is not affected, only the new version. I don't tested on RB only on x86 if you what to test this new version contact support.
I already contact support I thing they resolve this problem go to public with new version.
angboontiong
Mon Sep 13, 2010 5:01 pm
i can scan the ssid from other wireless bridge, but when i fall back to the V4.11, the ssid is not able to scan anymore.
Wed Sep 15, 2010 9:03 am
When next version is coming as per normis mikrotik is supposed to release this week.
mangust
Wed Sep 15, 2010 11:20 am
+1
normis
Wed Sep 15, 2010 11:21 am
we have some complications with one big change, we are still working on it.
mangust
Wed Sep 15, 2010 12:38 pm
Normis you are the BOSS… However, ROS is not OS for Wireless only, give us a chance to test BGP, QOS and other functions on high-load X86 systems with new Intel chipsets , I’m really waiting for this from 5B2.
normis
Wed Sep 15, 2010 12:52 pm
I didn't say the change is about wireless. We are working on routing actually.
nz_monkey
Wed Sep 15, 2010 2:48 pm
ooh routing changes, exciting :)
We seem to be pushing the boundaries of routing in RouterOS at a few sites now, it will be good to see what improvements come through.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
gustkiller
Wed Sep 15, 2010 3:08 pm
wow !! lightining fast bgp and show ip bgp like commands?
Ripper
Wed Sep 15, 2010 8:29 pm
What happened with SSH protocol earlier i used R3.3 now upgrade to 5b6 and my PHP self-made billing cannot connect to MT via SSH...
    $methods = array ( 'kex' => 'diffie-hellman-group1-sha1' );
    $shell = ssh2_connect($host, 22, $methods);
I've tried your PHP MT API but no luck too... http://wiki.mikrotik.com/wiki/API_PHP_class
Thanks for any advice ….
Chupaka
Wed Sep 15, 2010 9:07 pm
no luck? why? some errors? have you enabled API port under /ip services?
Ripper
Wed Sep 15, 2010 10:20 pm
At MT3.3 my billing (PHP module ssh2) works fine ... with same settings it couldn’t connect via SSH to MT5b6
With API PHP it tried to connect «Connection attempt #5" times and sad ERROR...
I had same shit with 3.3 while i fined method diffie-hellman-group1-sha1 after that everything goes fine...
I've tried to connect via ssh from same host where php server hosts with successful result.
janisk
Thu Sep 16, 2010 11:05 am
what commands and in what way you are sending to RouterOS ssh.
in version 5.0 there is completely new SSH, so please report what you have found.
Ripper
Thu Sep 16, 2010 3:13 pm
ON 3.3 thats works perfect
SSH
function routeros_Connect($host, $username, $password) {
    if (!function_exists("ssh2_connect")) die("function ssh2_connect doesn't exist");
    ssh2_auth_password($shell, $username, $password);
    return $shell;
function routeros_SendCommand($shell, $command) {
    $stream = ssh2_exec($shell, $command);
    stream_set_blocking( $stream, true );
    $data = "";
    while( $buffer = fread($stream, 4096) ) {
       $data .= $buffer;
    fclose($stream);
    return $data;
execute
routeros_SendCommand(routeros_Connect('server_ip','server_login','server_password'),'command');
but in 5.0b6 noluck with that
When i logining thru console it sad that security protocol DSA1
I need any solution to fix it as soon as possible because my costumers can’t work (((...
SSH2 don't say any error just freezes.
As i understand in new version change security protocol to which exactly?
I've litle bit tuned PHP API and it's connect but if I use it i need do much edits on my php billing code ... ((
I need some way to fix ssh ....
honzam
Fri Sep 17, 2010 11:40 am
5.0RC1 will be this week or next to?
LAN, FTTx, Wireless. ISP operator
Users browsing this forum: 42isanswer, Baidu [Spider], Bing [Bot] and 123 guests
