MUM Europe 2020
sankarklm
Hotspot Error
Fri Aug 13, 2010 7:16 pm
Hi
Sorry if this question was asked before, I am getting a wired error while trying to configure Hotspot. Apart from the intial IP [10.5.50.0] none other IP are working. The settings are getting saved, even DHCP server allocates IP from new pool [ex 10.50.55.0], but while trying to ping gateway [EX: 10.50.55.1] it says dest net unreachable.if i disable hotspot it starts pinging fine.
Tried Version : 3 /4.9 [ Trial Edition]
Hardware : Xeon Server
Lan Card : Two [Realtek]
[On default IP Block it works find if configured on first attempt] , Is it because of hardware ? or License? Can anyone help me out.
tadpole
Re: Hotspot Error
Mon Aug 16, 2010 4:04 pm
heya sankarklm
http://www.marlwifi.org.nz/projects/basic-mt-hotspot
I found this to be a really user friendly hotspot setup page, hope it helps!
sankarklm
Re: Hotspot Error
Mon Aug 16, 2010 7:50 pm
Thanks, i have seen this earlier, here i am not using routerboard, it been installed on a x86pc with two LAN cards..
fewi
Re: Hotspot Error
Mon Aug 16, 2010 7:52 pm
Post the output of
/ip address export
/ip address print
/ip route export
/ip route print
/ip firewall export
/ip hotspot export
SurferTim
Re: Hotspot Error
Mon Aug 16, 2010 8:34 pm
Nothing works with the hotspot enabled IF you are not logged in. No ping. No email. No SSH. No telnet. Nothing. How does everything work if you are logged in?.
Users browsing this forum: No registered users and 94 guests
