frogale
OSPF failure resetator
Tue Aug 17, 2010 10:51 am
We have problem with our routerboards. Sometimes OSPF stops working and "route print" command get stuck (endless running with no results). I've trying solve this problem with Mikrotik support but they are not able to help us. This problem occurs randomly and repeatedly only on some routerboards even with new softwares and firmwares.
Is possible to make script which can reboot routerboard in case of this ospf failure? Maybe somehow detect "route print" running time and reboot in case of stuck.
Many thanks for help!
Chupaka
Re: OSPF failure resetator
Tue Aug 17, 2010 12:26 pm
maybe something like
/system scheduler
add name=schedule1 start-date=jan/01/1970 start-time=00:00:00 interval=5m on-event=":global fine; :set fine false;"
add name=schedule2 start-date=jan/01/1970 start-time=00:00:05 interval=5m on-event=":global fine; /ip route print; :set fine true;"
add name=schedule3 start-date=jan/01/1970 start-time=00:00:20 interval=5m on-event=":global fine; :if (!$fine) do={ /system reboot };"
add necessary policies to the schedules - I don't have a time to test...
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
frogale
Tue Aug 17, 2010 1:00 pm
Great idea. Thanks!
Chupaka
Tue Aug 17, 2010 1:08 pm
karrrma? =)
frogale
Tue Aug 17, 2010 2:04 pm
Of course :)
blake
Wed Aug 18, 2010 2:34 am
karrrma? =)
Just continue posting on every single topic…post count matters more than anything.
IT consultant. Network manager. Packet junkie.
1-928-328-1509
Chupaka
Wed Aug 18, 2010 4:46 pm
http://forum.mikrotik.com/viewtopic.php ... 67#p204567
look at the screenshot :D
normis
Thu Aug 19, 2010 3:02 pm
Chupaka already has the biggest post count, so he has the next target - best karma :)
http://forum.mikrotik.com/memberlist.ph ... &sk=d&sd=d
frogale
Mon Aug 23, 2010 7:32 pm
Mind the time interval after restart (OSPF needs same time to start and scheduler restarting over and over) 8)
Chupaka
Tue Aug 24, 2010 7:41 pm
well, good remark, but in that case, "/ip route print" should work even if OSPF is not started yet =)
frogale
Tue Aug 24, 2010 7:58 pm
I don't really know yet.. But after last OSPF failure routerboard ended in restart loops.. I had only 3 seconds for quick mac-telnet login and disable commands..
Users browsing this forum: No registered users and 38 guests
