mgutz2
good 2.2ghz mini-pici card?
Wed Sep 22, 2010 8:03 pm
anyone knows a good card to work on 2.2GHZ? I live in Nicaragua and i have licence for this frecuency, but the r52xx or any card in 2GHZ have not the same power in 2.2 Ghz and 2.4Ghz, usually in the 2.2Ghz have less power. thanks.
sldnkarm
Re: good 2.2ghz mini-pici card?
Thu Sep 23, 2010 3:36 am
Can you provide the exact frequencies you will need? Have you looked into the custom frequency license in MTik? Have not verified on the 2Ghz cards, but I know that the custom frequency license opens up a lot more available channels in the Ubiquiti cards when I utilize the license.
normis
Thu Sep 23, 2010 8:29 am
normally the 2.4GHz cards are 2.3-2.6
mgutz2
Thu Sep 30, 2010 11:11 pm
I can use the frecuency from 2227Mhz to 2257Mhz, I use the rb411ah whit ROS. 4.11 level 4. in superchannel mode the frecuency is present, but the power is very low in comparison to 2.4Ghz power, and i have the licence for 2.3Ghz too and the power is low in this frecuency too.
For 2.3Ghz i use a ubiquiti xr2 modified by the manufacturer, they only change a litle filter whith 2452 label by other whith 2352 label. This mini-pci found it a netkrom radio, but i don know where to buy.
adrianatkins
Long time Member
Long time Member
Thu Sep 30, 2010 11:45 pm
The 2.4Ghz cards you can buy are quite heavily targetted at the legal channels.
Performance starts to roll off sharply below 2400 Mhz, so if you have lower power available on 2.3Ghz, you really need to find a specialist manufacturer of equipment for that frequency.
Having said that, the 'normal' frequency equipment is significantly cheaper.
So, even if you have a licence for 2.3Ghz, you might find you make more money using 2.4 and 5Ghz, and have an easier time becasue you can buy many different types of equipment.
normis
Fri Oct 01, 2010 9:16 am
of course, look at the datasheets of those cards, peak power is in the centre usually. and the antennas too are not optimized for 2.2Ghz
mgutz2
Sat Oct 02, 2010 12:57 am
I'll have to find a specialized manufacturer, because the r52h I have not seen this filter can be changed.
mgutz2
Fri Oct 08, 2010 12:22 am
Well, I found a card XR2-2.3 seems to give me a 2.2Ghz 200mW and 600mW at 2.3Ghz. great!
Cepillo
Fri Jul 01, 2011 3:59 pm
Hi mgutz2!
Could you advice me any solution for 2.2-2.2xx GHz? Is it possible for xr2 card? 200mW is enough for me.
Cepillo
Mon Jul 04, 2011 11:06 am
Hi mgutz2!
Hi All!
Does anybody use radiocards in 2.200-22xxGhz frequency band?
Kindly, share with me (us) your expirience!
KR
Cepillo
Tue Jul 05, 2011 12:05 pm
Hello!
Does the R52nM card support 2.2-2.3 GHz by a super channel license?
Thank you in advance!
mgutz2
Wed Jul 06, 2011 6:30 am
the xr2-2.3 work good on 2.2ghz the power is reducted to 50% about 200mW in 2.2ghz.
