ekkas
Long time Member
Long time Member
Status.html edit question.
Wed Sep 29, 2010 11:08 pm
ROS 4.11
I've installed yet another Hotspot, but clients are limited by Transfer limit(limit-bytes-total).
They want to be able to see how much MB they have left but I only see :
* bytes-in - number of bytes received from the user ("15423")
* bytes-in-nice - user-friendly form of number of bytes received from the user ("15423")
* bytes-out - number of bytes sent to the user ("11352")
* bytes-out-nice - user-friendly form of number of bytes sent to the user ("11352")
* packets-in - number of packets received from the user ("251")
* packets-out - number of packets sent to the user ("211")
* remain-bytes-in - remaining bytes until limit-bytes-in will be reached ("337465" or "---" if there is no limit)
* remain-bytes-out - remaining bytes until limit-bytes-out will be reached ("124455" or "---" if there is no limit)
Is there any way to show total bytes used or total bytes left (user-friendly way) so they at least can get an idea on how much used (total, not just for this session) and/or how much is left.
remain-bytes-total-nice is the variable I'm looking for...
Ekkas
PS: It sucks that transfer-limit must be entered as bytes (in usermanager web page), I tried 200mb, 200MB 200Mb but only 200000000 works...
Any possibility that it can be changed/added Mikrotik guys?
shaneau
Re: Status.html edit question.
Sat Nov 27, 2010 9:53 am
This would be great. Anybody have a solutions?
<EDIT>
Found a solution here...
http://forum.mikrotik.com/viewtopic.php?f=2&t=32874
<script language="JavaScript">
function readablizeBytes(bytes) {
var s = ['bytes', 'kb', 'MB', 'GB', 'TB', 'PB'];
var e = Math.floor(Math.log(bytes)/Math.log(1024));
return (bytes/Math.pow(1024, Math.floor(e))).toFixed(2)+" "+s[e];
</script>
<tr><td align="left">Megabytes Remaining:</td><td><script language="JavaScript">document.write(readablizeBytes($(remain-bytes-out)));</script></td></tr>
bax
Mon Jan 24, 2011 11:27 pm
Nice !
Does anybody know how to show Time remaining in status page , for users which have account with time usage?
fewi
Mon Jan 24, 2011 11:30 pm
Nice !
http://wiki.mikrotik.com/wiki/Manual:Cu ... _variables
session-time-left - session time left for the user ("5h" or "" if none)
session-time-left-secs - session time left for the user, in seconds ("3475" or "0" if there is such timeout)
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
bax
Tue Jan 25, 2011 11:47 am
[/quote]
Thanks !
I been add this line and now show time left :
<td align="left">Time Remaining:</td>
 <td> $(session-timeout) </td> </tr>
MICPROF
Tue Mar 01, 2011 6:17 am
NOt work , would you please help me , i need this script work if possible , i will wait you
Thanks!
Best Regards.
If my answer helped you and my question good too, please give me karma
cmacneill
Sat Apr 16, 2011 5:05 am
This problem seems to have been left hanging with no solution. MikroTik Support Guys, this needs a response as it appears to be a bug.
I have the same issue in that the documented $(remain-bytes-in) and $(remain-bytes-out) do not get substituted correctly when using total bytes limiting rather than separate values for in and out bytes. This has been tried on v4.10, v4.13, v4.16 and v4.17 and doesn't work in any of them.
Either needs variables to work correctly as documented or new variables provided which work when using total bytes limiting.
P.S. $(limit-bytes-in) and $(limit-bytes-out) don't work either.
Regards
Chris Macneill
ekkas
Long time Member
Long time Member
Sat Apr 16, 2011 8:58 pm
I second that. If it must be for ROS5 as that's the new official version, so be it, but we'll love to have this option regardless.
All our hotspots are on total bytes limit and a pain is the ... to constantly lookup usage for control-freak clients.
bax
Mon Mar 05, 2012 9:40 pm
Yes in latest ROS 5.xx this is not working ...
solelunauno
Tue May 27, 2014 12:24 pm
You can use limit-bytes-total as variable in status.html page.
I tested it with 6.9 firmware and it works well.
It isn't documented in http://wiki.mikrotik.com/wiki/Manual:Cu ... #Variables , but it's implemented.
SL1 Systems srl MTCNA MTCRE
omelendres
Fri Oct 03, 2014 10:58 am
The variable limit-bytes-total is also available in ROS version 5 but not documented
solelunauno
Thu Aug 06, 2015 5:01 pm
Now with Routeros 6.30.2 I tested the variables $(remain-bytes-total) and $(remain-bytes-total-nice) and they work.
So i think it's time to update http://wiki.mikrotik.com/wiki/Manual:Cu ... ng_Hotspot with those new and useful variables, in order to prevent time losses looking for other way to obtain those informations for users in status page.
Thanks Mikrotik support
corkuck
Tue Jan 19, 2016 5:55 am
If it's not working for you try this. I'm running MikroTik RouterOS ver. 6.9.
I struggled with
NaN (Not A Number) when trying the following Variables:
remain-bytes-in
remain-bytes-out
limit-bytes-in
limit-bytes-out
I kept getting nothing or NaN or not defined or showed nothing out at all.
For days this was KILLING ME........... then I found out this. So I have to share. It needs posted all over. So many of us that have or are struggled with this can be over. Works great once you do what's shown below, for the above variables shown to work.
Using your WAN IP address:
http://<WAN IP-Adds>/userman
Login:
Password:
Click Routers
Click on your router name
Click on down arrow of Radius incomming
Uncheck the CoA support: X Use CoA
It's a BOX that needs unchecked
Click Save
Click Logout
Reboot your router. The change of CoA will not take place or work unless you reboot.
It's my understanding that, with CoA checked, the User Manager sends out, nothing or zeros, for the above variables until you uncheck CoA. and reboot the router.
Good Luck so glad I'm passed this one, on to the next. What a great product........
Happy Mikrotik,,ing
/rk
melhem101
Sun Sep 16, 2018 7:13 pm
is there anyway to chamge that to gb or mb instead of bytes ?
3rdrail
Tue Jun 25, 2019 5:51 am
ROS 4.11
Ekkas
Here's my script to show the remaining mb they left. I put this code at the Status and Logout page:
$(if remain-bytes-out)
<tr>
<td>connected / left:</td>
<td>$(remain-bytes-out) / $(remain-bytes-total-nice)</td>
</tr>
$(else)
<tr>
<td>remaining data:</td>
<td>$(remain-bytes-total-nice)</td>
</tr>
$(endif)
Hope this helps!
Users browsing this forum: No registered users and 5 guests
