mohmedkasem
problem with xen
Thu Oct 14, 2010 8:08 am
hi
i'm new user i have some problem with xen
sorry for my bad english
mohmedkasem
Re: problem with xen
Fri Oct 15, 2010 7:32 am
please help
janisk
Fri Oct 15, 2010 11:14 am
my suggestion would be to use KVM instead of XEN as XEN was hit or miss - either it worked and you had few problems, or it never worked.
mohmedkasem
Fri Oct 15, 2010 5:54 pm
it never worked I do not know my settings is right or wrong
janisk
Mon Oct 18, 2010 8:30 am
reinstall completely your router, so you do not have traces of xen left and go for KVM, that is, if your CPU supports cirtualization.
Users browsing this forum: No registered users and 28 guests
